Wireless
8779 Discussions
Intel Wi-Fi 6 AX-200 not able to connect Wi-Fi Direct to Miracast TV (LG OLED EG920V)
Den_1978
My PC
Motherboard: ASUS Rog Strix  Z370h-Gaming
Operating System: Windows 10 Pro 64-bit (10.0, Build 19042) (19041.vb_release.191206-1406)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: 2402 (type: UEFI)
Processor: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz (12 CPUs), ~3.7GHz
Memory: 16384MB RAM
Available OS Memory: 15286MB RAM
Page File: 12023MB used, 35263MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 106 DPI (110 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: 1.0.8
DxDiag Version: 10.00.19041.0546 64bit Unicode
Display Devices 1
Card name: Intel(R) UHD Graphics 630
Manufacturer: Intel Corporation
Chip type: Intel(R) UHD Graphics Family
DAC type: Internal
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_8086&DEV_3E92&SUBSYS_872F1043&REV_00
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 7771 MB
Dedicated Memory: 128 MB
Shared Memory: 7643 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
HDR Support: Not Supported
Display Topology: Internal
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.635742,0.333984), Green(0.308594,0.622070), Blue(0.149414,0.066406), White Point(0.312500,0.328125)
Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
Monitor Name: Generic PnP Monitor
Monitor Model: HP ENVY 23
Monitor Id: HWP310B
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Advanced Color: Not Supported        Driver Version: 27.20.100.9030
DDI Version: 12
Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.7
Hardware Scheduling: Supported:False Enabled:False
Graphics Preemption: Triangle
Compute Preemption: Thread
Miracast: Supported
Detachable GPU: No
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Virtualization: Paravirtualization
Block List: DISABLE_HWSCH
Catalog Attributes: Universal:False Declarative:True
Driver Attributes: Final Retail
Driver Date/Size: 27.11.2020 06:00:00, 1450864 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B78E66-7DD2-11CF-B550-4BA7BBC2D635}
Vendor ID: 0x8086
Device ID: 0x3E92
SubSys ID: 0x872F1043
Revision ID: 0x0000
Driver Strong Name: oem0.inf:5f63e5340f714335:iCFL_w10_DS:27.20.100.9030:PCI\VEN_8086&DEV_3E92
Rank Of Driver: 00CF2001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
Display Devices 2
Card name: NVIDIA GeForce GTX 1080 Ti
Manufacturer: NVIDIA
Chip type: GeForce GTX 1080 Ti
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_1B06&SUBSYS_374C1458&REV_A1
Display Memory: 18771 MB
Dedicated Memory: 11128 MB
Current Mode: Unknown
HDR Support: Unknown
Display Topology: Unknown
Display Color Space: Unknown
Color Primaries: Unknown
Display Luminance: Unknown
Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_a51067c0ac557884\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_a51067c0ac557884\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_a51067c0ac557884\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_a51067c0ac557884\nvldumdx.dll
Driver File Version: 27.21.0014.6089 (English)
Driver Version: 27.21.14.6089
DDI Version: 12
Hardware Scheduling: Supported:True Enabled:True
Graphics Preemption: Pixel
Compute Preemption: Dispatch
Miracast: Not Supported by Graphics driver
Detachable GPU: No
Hybrid Graphics GPU: Not Supported
Block List: No Blocks
Driver Date/Size: 11.12.2020 06:00:00, 1049800 bytes
WHQL Logo'd: Yes
Device Identifier: Unknown
Vendor ID: 0x10DE
Device ID: 0x1B06
SubSys ID: 0x374C1458
Revision ID: 0x00A1
Driver Strong Name: oem25.inf:0f066de35d9aeff6:Section044:27.21.14.6089:pci\ven_10de&dev_1b06
Video Accel: Unknown
Sound Devices
Description: Realtek Digital Output (Realtek High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_1168&SUBSYS_10438723&REV_1000
Manufacturer ID: N/A
Product ID: N/A
Type: N/A
Driver Name: RTKVHD64.sys
Driver Version: 6.0.8746.1 (English)
WHQL Logo'd: Yes
Date and Size: 02.07.2019 06:00:00, 6886992 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Emulation Only
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Выход SPDIF (SB Recon3D PCIe)
Hardware ID: HDAUDIO\FUNC_01&VEN_1102&DEV_0011&SUBSYS_11020013&REV_1009
Product ID: N/A
Type: N/A
Driver Name: cthda.sys
Driver Version: 6.0.101.62 (English)
WHQL Logo'd: Yes
Date and Size: 18.06.2015 06:00:00, 1058600 bytes
Other Files:
Driver Provider: CREATIVE
Cap Flags: 0xF1F
HW Memory: 0
Description: Динамики (SB Recon3D PCIe)
Default Sound Playback: Yes
Default Voice Playback: Yes
Product ID: N/A
Type: N/A
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
 netsh wlan show driver
Microsoft Windows [Version 10.0.19042.685]
(c) Корпорация Майкрософт (Microsoft Corporation), 2020. Все права защищены.
C:\WINDOWS\system32>netsh wlan show driver
Имя интерфейса: Беспроводная сеть 3
Драйвер : Intel(R) Wi-Fi 6 AX200 160MHz
Производитель : Intel Corporation
Поставщик : Intel
Дата : 20.10.2020
Версия : 22.10.0.7
INF-файл : oem3.inf
Тип : Собственный драйвер Wi-Fi
Поддерживаемые типы
радиомодулей : 802.11b 802.11g 802.11n 802.11a 802.11ac
Поддерживается режим FIPS 140-2: Yes
Защита кадров управления 802.11w поддерживается: да
Поддержка размещенной сети : нет
Методы проверки подлинности и шифрования, поддерживаемые в режиме инфраструктуры (infrastructure):
Открыть Нет
Открыть WEP-40bit
Открыть WEP 104-разрядный
Открыть WEP
WPA-Enterprise TKIP
WPA-Enterprise CCMP
WPA-Personal TKIP
WPA-Personal CCMP
WPA2-Enterprise TKIP
WPA2-Enterprise CCMP
WPA2-Personal TKIP
WPA2-Personal CCMP
Открыть Определяется поставщиком
WPA3-Personal CCMP
Определяется поставщикомОпределяется поставщиком
WPA3-Enterprise GCMP-256
OWE CCMP
Наличие службы независимого поставщика оборудования: Да
Уникальный код адаптера
оборудования: [00 00 00], тип: [00]
Путь к библиотеке DLL расширяемости
от независимого поставщика оборудования: C:\WINDOWS\system32\IntelIHVRouter08.dll
ClSID расширяемости пользовательского интерфейса независимого поставщика оборудования: {00000000-0000-0000-0000-000000000000}
CLSID диагностики независимого
Поддерживается беспроводной дисплей: Да (Графический драйвер: Да, драйвер Wi-Fi: Да)
ДОБАВИЛ В РАЗРЕШЕНИЯ БРАНДМАУЭРА WINDOWS 10 ПРОЦЕСС
C:\Windows\System32\WUDFHost.exe
СО ВСЕМИ ПОРТАМИ
Allow In/Out connections for TCP and UDP, Ports: All.
КАК Я ПОНЯЛ ТРАНСЛЯЦИЯ ЭКРАНА ПО MIRACAST ПОДДЕРЖИВАЕТСЯ ВСЕМ МОИМ ОБОРУДОВАНИЕМ
ВИДЕОКАРТА GTX 1080ti ОТКЛЮЧЕНА ВО ВРЕМЯ ТРАНСЛЯЦИИ БЕСПРОВОДНОГО МОНИТОРА  ( ЧЕРЕЗ ДИСПЕТЧЕР УСТРОЙСТВ)
ПОМОГИТЕ РЕШИТЬ ПРОБЛЕМУ, Я ПОКУПАЛ ВАШ МОДУЛЬ WI_FI ИМЕННО ДЛЯ ТРАНСЛЯЦИИ ЭКРАНА И НЕ ДЛЯ ЧЕГО БОЛЬШЕ.
https://youtu.be/iso6jVQH8xI
Den_1978
BUT MY PHONE HTC ONE m8  connect to this TV without problems, and my notebook HP OMEN 5010nr connect to this TV through Intel  Wi-Di without problems!!!!!!!!
Jose_V_Intel
Hello Den_1978,
Thank you for posting on the Intel Community.
Based on the information that you provided please follow the next information:
  • Intel WiDi was based on the Miracast* standard for wireless display capabilities. This standard is natively supported in Windows® 10 and Windows 8.1* and may be used to accomplish wireless display without additional software. Customers using Windows 7* can continue using an operational Intel WiDi configuration or upgrade to a newer release of Windows.
If you need assistance with Miracast, contact Microsoft for support.
Regards.
Jose V.
Den_1978
