Wireless
8563 Discussions
Intel Wi-Fi 6 AX201 Coded PHY Support
JolonBMT
Does The AX201 support Bluetooth coded PHY? This is the optional long-range feature of Bluetooth 5. In the product brief it says:
> Bluetooth® 5.2 provides 4x[6] range over Bluetooth® 4.2 using the same Tx power, enabling coverage throughout the home. Bluetooth® 5.2 also doubles data rate speed for faster transmissions, thereby reducing the overall power consumption[6]. Additionally, Bluetooth® 5.2 adds new, enhanced data broadcasting, enabling seamless location-based services and simpler pairing for Bluetooth® devices.
That little 6 after it says "4x" brings you to a note saying:
> Bluetooth® 5.2 Feature overview, https://www.bluetooth.com/wp-content/uploads/2020/01/Bluetooth_5.2_Feature_Overview.pdf. Only mandatory
features are supported.
LE Coded PHY is the feature that would provide the extra range. Page 27 of the linked Bluetooth overview says:
> Support for LE Coded is optional.
So now I'm confused. LE Coded is an optional Bluetooth feature and the AX201 only supports mandatory features. But the AX201 specification says that it provides 4x the range, but it cannot do that if it doesn't support Coded PHY.
So, does it support it or not?
If anyone in the community has an AX201 connected to a Linux machine, could you run the following command and let me know the output. I want to confirm before I make a purchase.
sudo btmgmt phy
For example, the output I get from a Bluetooth dongle that does support Coded PHY is (note the LECODEDTX and LECODEDRX)
Supported phys: BR1M1SLOT BR1M3SLOT BR1M5SLOT EDR2M1SLOT EDR2M3SLOT EDR2M5SLOT EDR3M1SLOT EDR3M3SLOT EDR3M5SLOT LE1MTX LE1MRX LE2MTX LE2MRX LECODEDTX LECODEDRX
Configurable phys: BR1M3SLOT BR1M5SLOT EDR2M1SLOT EDR2M3SLOT EDR2M5SLOT EDR3M1SLOT EDR3M3SLOT EDR3M5SLOT LE2MTX LE2MRX LECODEDTX LECODEDRX
Selected phys: BR1M1SLOT BR1M3SLOT BR1M5SLOT EDR2M1SLOT EDR2M3SLOT EDR2M5SLOT EDR3M1SLOT EDR3M3SLOT EDR3M5SLOT LE1MTX LE1MRX LECODEDTX LECODEDRX
Mike_Intel
Hello JolonBMT,
  1. What is the brand and model of the system?
  2. May I know why are you asking for this feature? Can you further elaborate the use of the feature that you are asking?
  3. Did you manually install the AX201 on the system or is it embedded in the system?
Michael L.
JolonBMT
Hi Mike_Intel,
I don't really have a good answer to questions 1 and 3. The hardware may vary. I don't mind whether it comes preinstalled or needs to be installed manually. It'll definitely be running Linux (Ubuntu 24). The hardware depends on what can support coded PHY.
To answer question 2, I need a Bluetooth module that can support coded PHY so it is able to communicate with Bluetooth devices over a long distance (up to a few hundred metres). Coded PHY is an optional feature of Bluetooth 5+, so many devices don't support it. It may also be referred to as "S=8" or "125 kHz".
Coded PHY needs to be supported on both devices (central and peripheral). The AX201 would ideally be used as the central device with ublox NINA Bluetooth modules as the peripherals. The data being transmitted will be small packets of binary data (no audio streams). In the past, we've used a USB Bluetooth dongle, but with the move to new hardware, we want to see if we can have something installed inside the PC.
I hope this answers your questions. Thanks
Mike_Intel
Hello JolonBMT,
Michael L.
Mike_Intel
Hello JolonBMT,
Thank you for the update.
For me to further investigate this, please help provide the SSU logs of your system. Kindly refer to the link below on where to download the utility:
Intel® System Support Utility for the Linux* Operating System
Michael L.
JolonBMT
Sorry, I don't understand. As I mentioned, I haven't purchased the hardware yet. I want to verify that the AX201 will be suitable for my needs. I have provided a Linux command in my original post that someone with the hardware can run to confirm the information I need
Mike_Intel
Hello JolonBMT,
Thank you for the clarifications.
I will do further research on this matter and post the response on this thread once it is available.
Michael L.
