Wireless
8695 Discussions
Intel Wi-fi 6 AX201 can't wake on wireless Lan
Raff
Hello
I am experiencing some technical challenges
I have been following several guides, tips, and documentation but I cannot manage to successfully wake my computer via Wifi by sending magic packets
From what I have been reading the card support it
I believe my windows and power options are correctly setup
I would love to hear your thoughts or if there is some user that successfully managed to wake the computer via Wifi using this card model
Raff
Jocelyn_Intel
Hello, @Raff
Thank you for posting on the Intel® communities.
I am sorry to hear what is happening with your Intel® Wi-fi 6 AX201, I will gladly assist you here.
Did you make sure you have followed all the steps to enable it in Windows and BIOS? For WoL (Wake on wireless LAN) to function, your computer's BIOS and operating system need to be set up correctly.
We recommend you to contact your Motherboard Manufacturer to enable the Wake on wireless LAN in BIOS.
For Windows 10, follow these steps:
  1. Open Device Manager by selecting the Windows button and typing, Device Manager
  2. Expand the Network Adapters section and double-click the Wireless device.
  3. Select the Advanced tab.
  4. Make sure Wake on Magic Packet is enabled (this is the default setting).
If the PC won't Wake on wireless LAN after completing the steps detailed above, try disabling Fast Startup in Windows:
  1. Type Power Options in the Search bar.
  2. Select Choose what the power buttons do
  3. Select Change settings that are currently unavailable
  4. Uncheck Turn on fast startup in the Shutdown settings section.
  5. Click Save changes
Jocelyn M.
Alan18
Same problem here.   Wake on Wireless On doesn't work after making below changes.
I have enabled Wake on Lan in BIOS / UEFI
I am missing the Power Management Tab in driver properties.
Changed the options to Enable in Advanced tab: Wake on Magic Packet & Pattern Match
Alan
VARADHARAJAN
Valued Contributor II
Jocelyn_Intel
Hello, @Raff
We are checking this thread and we would like to know if you were able to review our previous post. If you need further assistance, please do not hesitate to contact us back.
Jocelyn M.
Jocelyn_Intel
Hello, @Raff
We have not heard back from you, so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jocelyn M.
