Wireless
8563 Discussions
Intel WiFi 6 AX200 160Mhz Driver 22.200.0.6 Windows 10Pro 22H2
mladjo85
Intel WiFi 6 AX200 160Mhz Driver 22.200.0.6 Windows 10Pro 22H2 . Diese Version vom Treiber finde ich nicht bei Intel, aber bei Windows Update ist automatisch instaliert. Weiß jemand mehr Infos über den Treiber 22.200.0.6? Danke
DeividA_Intel
Hello mladjo85,
Thank you for posting on the Intel® communities. I understand that you need information about a driver for your Intel® Wi-Fi 6 AX200.
In this case, we can only offer you the driver available on our website (22.160.0, 22.170.0, 22.180.0, 22.190.0). The driver that you mentioned that Windows is installing could be from your computer manufacturer (MSI, HP, Dell, Acer, etc).
Bear in that our drivers are generic and the ones from the laptop/computer manufacturer are customized to work perfectly with their system based on BIOS and board limitations. I recommend you check with your computer manufacturer or Microsoft to get more information related to this driver that is being updated automatically.
Here you can check our drivers:
Here you can check more about our drivers:
If you have any questions please let me know, otherwise, I will close the thread.
Deivid A.
