Have noticed when I change router channel width to 160mhz wifi switches from 5G network to 2.4G tried changing preferred channel to 5Ghz in device manager but that doesn't seem to have an effect. However if I change the channel width to the 80mhz width it connects to 5G no problem even with no preference set. Curious if anyone has had a similar issue and what the cause might be and some possible fixes? Have driver version 22.200.2.1
Hello, @coxca2113 .
Thank you for posting on the Intel® communities. I will gladly assist you here.
Please, answer these questions to have a better perspective of this issue:
- Is the Intel Wi-Fi 6 AX200 the pre-installed wi-fi card in your motherboard/laptop or is it an integration (upgrade/ not the original card in the computer)?
- Is it a Desktop or a laptop? What is the model of your laptop or motherboard (whichever applies)?
- How are you checking the bandwidth? Could please send us screenshots showing this issue from the program/tool/platform you are seeing it?
- What is the model of your Router?
Jocelyn M.
It is desktop Wifi came with motherboard it is a ASUS X570 Crosshair hero VIII (Wi-Fi) running a Ryzen 9 5900X. Router is tp-link Archer AX73 (AX5400) WIFI 6 Checking bandwith 3 different ways using a WIFI analyzer, the modem settings through the router login through IP address/tp tether app which is basically the mobile app for accessing router settings, and running a speed test through speedtest.net. Have 1gbps fiber and whenever the router 5G channel width is changed to 160mhz wifi analyzer shows it switch to connected to 2.4G as well as router showing it in connected clients on 2.4G and speedtest drops from around around 600-700mbps to around 50. Changing the intel wifi to prefer 5G has no effect and this is instantly remedied by switching channel width to 80mhz. Including screenshots of router settings with Wifi analyzer and router showing 2.4G as well as the difference when all that is changed is 160mhz changed to 80mhz, as well as device manager showing preference for 5G band
Hello, @coxca2113 .
- Make sure your router's firmware is up to date, and choose correctly your hardware version. This is an important process, contact your Router Manufacturer if you need assistance doing this step.
- Perform a Clean Installation of Wireless Drivers, using the latest wireless driver. Note: Make sure to check you have all the Windows updates before doing the driver installation. Also, make sure to do this step disconnected from the internet (wi-fi or wired connection) since Microsoft updates drivers automatically and prevents doing the clean installation successfully.
Jocelyn M.
Hello, @coxca2113
We are checking this thread and we would like to know if you were able to review our previous post. If you need further assistance, please do not hesitate to contact us back.
Jocelyn M.
Tried fresh install of drivers and issue persists. There's no problem if I change preferred band to 5Ghz in device manager settings but as soon as I change router channel to 20/40/80/160mhz option it disconnects and switches to 2.4Ghz
Hello, @coxca2113 .
- Have you updated your router's firmware? Choose correctly your hardware version. This is an important step to do.
- Have you tried to perform a Clean Installation of Wireless Drivers, using the latest OEM Wi-Fi driver? Make sure to select your OS.
Note: We recommend checking with your System Manufacturer and using the driver software provided by them to avoid potential installation incompatibilities. Intel supplies generic versions of Graphics Drivers for general purposes. Computer manufacturers might have changed the features, incorporated customizations, or made other changes to the graphics driver software or software packaging.
Jocelyn M.
Yes did both of these have most recent router firmware and also did a clean install of Wifi drivers and tested again, same results.
Hello, @coxca2113 .
Just to confirm, did you perform the Clean Installation of Wireless Drivers, using the latest System Manufacturer's wi-fi driver too?
If you did, please run this utility and provide us with the report:
Intel® System Support Utility for Windows.
Note: Make sure to mark the box that says "everything" before pressing the Scan button. After that, click on "Next>" and select "Save" and then, attach the .txt file.
Jocelyn M.
Hello, @coxca2113
Jocelyn M.
Hello, @coxca2113 .
I will investigate this issue, as soon as I have updates, I will post them here.
Jocelyn M.
Hello, @coxca2113 .
Thank you for your time.
Does this issue happen with another router or Access Point(AP)? Is it possible for you to try another router?
Have you ever been able to connect as expected without issues before?
Jocelyn M.
Hello, @coxca2113
Jocelyn M.
every other device on my network works fine without issue, its only this intel chip that wont receive an ip configuration if the channel width is set to 160mhz. trying to set a static ip also fails with the message "cant save ip settings"
changing the channel width to anything but 160mhz makes the wifi chip work, but that is not a solution.
i have tried clean installing the latest drivers from 1. the motherboard manufacturer (asrock), 2. windows update and 3. intel itself and none of these drivers have resolved the issue.
i have narrowed down the problem further to using channel 36 (50), which is the only 160mhz channel available in australia. if i set my router to ignore the restrictions to use channel 114 instead the wifi adaptor seems to connect okay, but this is not a solution either as it is highly illegal.
i do not have another router to test with, but considering every other device on my network works as expected it is clearly the wifi adaptor at fault.
the issue persists even with the computer right next to the router with nothing between them.
this is all on windows 10 ltsc.
hopefully this is enough information for you to track down and resolve the issue promptly with a new firmware update.
Hello, @coxca2113
As a final recommendation, we recommend you to update your BIOS to the latest version. If you need help with this step, contact your System Manufacturer to do this process.
Jocelyn M.
Hello, @ibrokemypie
I am sorry to hear what is happening with your Wi-Fi card.
Please submit a new thread describing your issue with your System specifications as they are different from this thread so we can give more personalized assistance.
Have a nice day.
Jocelyn M.
![](/skins/images/9701FEC4E90D143B667C09F3DB2F340F/responsive_peak/images/icon_anonymous_message.png)
