Wireless
8626 Discussions
Intel WiFi 6E AX211 BT 5.3 Auracast drivers?
SAK1
I have Wi-Fi 6E AX211 BT 5.3 at BT 23.100.1-64UWD on a HP mini workstation 12 gen core i9-12900.
I want to eventually Auracast to ear pods that are enabled. HP not interested in producing a driver.
Where can I get such a driver, single-point  broadcast, OK for now. Would prefer not to dongle but will if necessary.
JedG_Intel
Hello SAK1,
I do not have an answer at this moment but I’ll investigate it and contact you back as soon as possible.
Jed G.
JedG_Intel
Hi SAK1,
I'm following up on the investigation I had conducted. Upon checking, Auracast is a feature enabled by LE Audio, allowing an audio source to broadcast one or multiple audio streams to an unlimited number of receivers.
Intel® Wireless and Bluetooth® Adapters support a wide range of codecs. However, the operating system (OS) utilizes these codecs natively on the respective peripherals, not the adapter itself. Therefore, if you encounter any issues or have further inquiries about "codec support," we recommend contacting Microsoft Technical Support.
For more information, you can refer to the following articles:
Should you have other questions or concerns, please create a new thread as this thread will no longer be monitored.
Jed G.
Rob14
Welcome to the suck.  You'll find that everyone is pointing fingers at everyone else and not solving this.
