Wireless
8514 Diskussionen
Intel WiFi Link 5100 AGN problem - disconnecting
Mitarbeiter
24.205Aufrufe
I'm having a problem that just started with my 2 year old laptop. The Intel WiFi Link 5100 AGN adapter keeps dropping connection.
On my laptop there is a light that shines blue when connected and orange when not connected. I boot the computer and the light will be blue. After awhile it switches to orange. I go into device manager and disable the adapter and re-enable it and it works fine for a bit and then disconnects again. A few weeks ago it was disconnecting one or two times a day. Now it is disconnecting as often as every minute or two.
Sometimes when I go into device manager the adapter isn't even listed. I try scanning for hardware changes and sometimes that will find it and I can re-enable it. Sometimes the scan will not find it and all I can do is re-boot.
I have tried using the latest version driver from the Intel site (13.4.0.9) and that has the same problem as the version that is the latest on my laptop vendors site (13.0.0.107).
I have not made any changes in the last 12 months to my wireless network settings in the router or on the computer. There are three other laptops in the home which work just fine and never drop connection.
Any help would be appreciated.
Bill
58 Antworten
Mitarbeiter
7.685Aufrufe
I have the same problem and the only solution is a reinstall of Windows.
Mitarbeiter
7.685Aufrufe
I really don't think that will do any good... I think it is a problem with the 5100 AGN and its drivers. I fixed the problem this morning. I went to Frys, bought a USB wireless adapter, disabled the 5100 AGN, installed the drivers for the new adapter and I've been going fine with no dropped connections for a couple of hours. The cost? $39 and a gallon of gas.
Mitarbeiter
7.327Aufrufe
I don't have a solution, but you may be on to something regarding the interaction between windows and the AGN. first I have two laptops that drop the connection. An HP Win7 64 and a toshiba Vista 32. The HP has the 5100AGN but the Toshiba has a Linksys EC600N card. Both are within 6 feet of the router. I correct the problem by using the network and sharing center to disconnect and reconnect for a quick solution, though my problem only occurs at most once a day. An HP desktop with WIN7 64 using a linksys WUSB600N adapter has no problem with the connection, neither does a Dell desktop running XP Pro with a Linksys WUSB600N. I know I'm just muddying the water, but someone can glean something more significant than I from the information.
Mitarbeiter
7.685Aufrufe
I have the same problem. I am using a new Linksys E2000 router and have a PRO 2915ABG wireless card. I have downloaded the most updated drivers but that did not fix the problem. The ironic thing is that I did not have this problem with my old router (linksys WRT54G). Sorry I was not able to help but I am interested if you get any good suggestions.
Mitarbeiter
7.327Aufrufe
I was having a similar problem with only two of the 5 machines on my network. Rolling back the software didn't help. My problem was cured when I replaced my Linksys WRT160N router with a Netgear WNDR4500N and connected on the 5G band. All the problems dissapeared. Maybe it's coincidence, but though the speed is slightly slower, the signal is rock solid. Expensive solution, but in my case I needed to replace the router because the Linksys was beginning to fail. (vanishing signal, difficulty getting iinto the control interface and repeatedly asking for ID authentication even after being logged in. Don't know if this helps anhyone, but it is additional info.
Mitarbeiter
7.327Aufrufe
I too had similar problems. at first the adapter wouldn't even recognize any wireless networks at all. i disabled then re-enabled from the device mgr and that worked...for a few months anyway. then it started doing the same thing again, couldn't find any networks. I've tried uninstalling the old driver and installing the newest one (14.2) to no avail. last week i ordered a brand new wifi 5100 card. after installing the new card (it's very simple to do), it now recognizeds the networks and i can connect but it still drops the connection periodically. this leads me to believe that this is a software and not a hardware problem since i'm still experiencing some of the same issues with a brand new card. I may try to find a different brand of internal wireless card since i don't like the usb ones filling up my ports. hope this helps a little.
Mitarbeiter
7.327Aufrufe
I rolled back to the earlier version of the software but that sdidn't help. The new Netgear WNDR4500N solved the problem and gave me better distance signal strength with a solid signal on 5G. The gigabit wired connections on the 4500 do tend to drop onece in a while but haven't proved too troublesome, so far. I'm hoping router software updates will eventually fix that problem,
Mitarbeiter
7.327Aufrufe
I tried everything mentioned out here and some other forums too, nothing worked for me. I was not inclined to use a usb adapter, with something sticking out always and not to mention the discomfort putting the laptop in a carry case. Also, the discomfort of carrying it where ever I move. So, I ordered intel 5100 512AN_HMW, which is the internal wifi adapter for my dell studio 1555 laptop, from ebay for $17 and installed it myself. Touch wood its working fine now.
Its a hardware problem. With so many people having this issue, Intel should do something to help end point users.
Mitarbeiter
7.685Aufrufe
I have had the same issue for months! with this wireless adaptor. My laptop is an HP Probook 4411s of a little under 2 years. A few days ago, I re-installed Windows 7 and it was fine until yesterday after a large number of Windows 7 updates were installed. I decided to find a fix for it this time. Updating latest drivers didn't solve it. I suspected the problem might have lied in one of the updates. I spent literally hours removing as many updates as possible. When the device isn't listed, it doesn't even show in BIOS, also updated to the latest downloaded from HP. I have switched to Windows 7 64bit recently. I don't remember I had this with Windows 7 32bit. However, I didn't use wireless as intensively on this laptop as now.
It is either the product is faulty, which has been out of warranty in my case, or Windows 7 64bit is showing what it is once again. Luckily, I have a Mac book pro.
I am going to give it up myself. Get a USB wireless adaptor if you need to connect wirelessly.
Mitarbeiter
7.685Aufrufe
And I thought I had a crappy router, as the wireless kept dropping and I had to restart the router once, twice a day. Now I still have the same problem with my new router... I've had this laptop for over a year.. How is it possible that there isn't a fix for this problem yet??? Frustrating!
Mitarbeiter
7.685Aufrufe
Yes, this is a persistent and prevalent problem and having had it for at least a month I've yet to find the correct solution. I've tried all driver updates. My connection can stay on for as little as a few minutes and as long as several hours at a stretch, and when the 5100 disconnects my only solition is a restart. The profile appears nowhere and the device isn't listed until I reboot.
It worked fine for over a year. It's difficult to imagine that this is a physical problem with the device as opposed to related to some kind of software update or incompatability issue .. too many people have logged in with the same complaint after having the thing work fine for a long while out of the box.
Mitarbeiter
7.685Aufrufe
Just an update.... I bought a USB wireless adapter on 1/25 and haven't had a single disconnect since then. Problem solved.
Mitarbeiter
7.685Aufrufe
I have no doubt that using an external USB wireless device will solve the problem. But I would prefer to exhaust all possibilities for fixing the onboard card. Particularly since the 5100 worked perfectly well for a solid year before showing problems. It would seem connected to an update or compatability issue. And it's definitely this card, as no other devices using the hub lose connection. Most frustrating is the aspect of having to restart the machine, sometimes several times, to locate the device. I find it hard to believe that someone at Intel hasn't identified the specifics of this problem, with so many users complaining about the same thing.
Mitarbeiter
7.685Aufrufe
-hi,
I am 100% sure this adapter model is defunct in some way. I have (like 1000 other people) experienced the same problems.
I have 8 computers connected to my access point - and ONLY the 1 with Intel WiFi Link 5100 AGN drops out every few minutes.
This particular pc has both Win7-32 and Linux parttions and the problem is exactly the same on both OS's. Therefore it cannot
be driver related. At least on Linux I wrote a script to reinitilialize adapter every time it disconnects. But that can hardly be called a solution.
Unfortunately the adapter is a built-in in a laptop, so the only way is an external USB adapter (hate it!).
The problem some times gets even worse since it occationally confuses the AP router which then resets all ports. Very nice!
If only Intel would admit that this adapter is defunct (or provide working firmware if possible). Then we could all stop wasting our time....
regards
/Peter B.
Mitarbeiter
7.685Aufrufe
I have little doubt that this is an adapter issue, but what's puzzling is that the adaptor worked perfectly for over a year before starting to malfunction. The problem seems to be that the adaptor disconnects when it drops the signal, and is unrecognized until the computer is restarted .. sometimes requirng multiple restarts. Also curious is that this adapter performed flawlessly for several hours at a remote location, and yet all other laptops and wireless devices work perfectly on the hub that this unit fails on repeatedly at home. All of this leads me to believe it's a flaw in the unit combined with situational circumstances.
I did order a USB adapter .. but if necessary, how difficult would it be to replace the onboard adapter with something else? It's in a Lenovo X200. Isn't it just a matter of accessing the old one and hooking the new one up?
Mitarbeiter
7.685Aufrufe
- hi again,
I think you are right. There has to be an obscure set of circumstances to trigger the problems. My pc also used to more stable.
For Windows 7 this can be explained by certain "important" updates. It has been suggested that problems are related to
"Microsoft Virtual WiFi Miniport". This is not a bad idea. Microsoft expect all adapters (even old ones!) to comply with their new
"standard". This cannot always be the case. I have experimented with this but not really achieved convincing results.
It does not explain why I have the same problems on Linux (Ubuntu Lucid).
Only thing that changed in my network is that more clients were added over time. Because of this I upgraded AP's firmware (D-link) to the latest
version but to no avail.
I now use a D-link DWA-140 USB adapter I had "left-over" and it works flawlessly.
I dare not try to disassemble my ACER laptop :-) Not sure what to replace adapter with anyway.
regards
/peter b.
Mitarbeiter
7.685Aufrufe
Yeah, I too purchased a Medialink USB wifi adapter and it works flawlessly, but I'd much rather have my onboard 5100 agn perational. It doesn't make sense that these problems wouldn't present out of the box if it wasn't a situational issue. I noticed that the Intel adapter worked flawlessly for several hours at another location last week. But the issue can't be soley in my wireless router because every other computer, hand held device etc works perfectly and as I said, so does my USB plug-in.
I can pinpoint the day when this started happening a few months back. Maybe if there's some way to check the history of installed updates I can then track down which might have caused the 5100 to enter this mode of frequent disconnection. If all it did was disconnect that would be one thing, but the fact that the system fails to identify the device unless a restart is performed is particularly annoying. And sometimes it requires several restarts.
It's frustrating when an issue is so widespread yet not acknowledged, addressed or fixed by the manufacturer. If it's a physical problem with the adapter due to over-heating with time, I'd be OK with that too and just replace the thing. But it's kind of a delicate operation on a laptop and it would good to have some definitive answer from Intel either way. It definitely isn't specific to any one brand of computer.
Mitarbeiter
7.287Aufrufe
I've been troubled by a similar problem for a few years, and have just noticed the possible cause - sitting in an office which slowly fills up with colleagues starting up their own lap-tops, the card suddenly dies - saying no network available. Then I move to a quieter area and all is well again.
Hence I guess it's radio interference from the other laptops - anyone else have a similar experience?
Mitarbeiter
7.685Aufrufe
I have used this in my old Dell Studio 1737 without issues. I had Vista 32-bit/64-bit and Windows 7 64-bit installed and it worked with no problems. Here are http://en.community.dell.com/support-forums/network-internet-wireless/f/3324/p/19332585/19697701.aspx# 19697701 My Intel WiFi 5100 AGN Connectivity Settings
When I install it on Windows 7, for the initial setup, I used the Vista 64-bit drivers from my manufacturers website and installed the drivers in the Vista SP2 http://en.community.dell.com/support-forums/software-os/w/microsoft_os/compatibility-mode.aspx Compatibility mode I later updated the drivers at http://www.intel.com/support/wireless/detect.htm Intel® Driver Update Utility for Intel® wireless adapters I was helping someone else with an issue and I then tried http://en.community.dell.com/support-forums/network-internet-wireless/f/3324/p/19332852/19700096.aspx# 19700096 Installing My Wi-Fi Technology
My wireless router was using these http://en.community.dell.com/wikis/networking_internet_wireless/recommended-wireless-router-settings.aspx Recommended Wireless Router Settings, I use channel 11. Having the router of auto channel can pose problems with connecting, as well as the 2.4gh cordelss phones.
Rick
Mitarbeiter
7.685Aufrufe
Hello
I am having the same problems with my 5100 AGN WiFi card. I see that it disconnects when 802.11 n is enabled on my router. If enable only 802.11 a/b/g I do not have disconnections. The problem probably is that 5100 AGN supports 802.11 Draft N and not the final protocol of 802.11 n. with my older router I did not have any problems.
Kostas
Antworten
