Wireless
8661 Discussions
Intel WiFi6 ax201 5Ghz speed is decreasing !!
EngHosam
Using Router: 5 Ghz (2x2 MU-MIMO Enabled - Speed 866.7 Mbps)
1. HP655 with Win 7x64 Professional With 1 Gbps Lan connected to the router
2. HP450G7 Win 10 x64 connecting to the 5ghz with my ax201
3. Usnig SMB sharing
transferring start at a high speed and decreasing !! when i press pause and then start it increase and decrease again , WHY ??!!
the data rate still same:
n_scott_pearson
This sounds more like an issue with disk caching. Are there versions of the Wireless drivers that you have seen work well in this testing scenario?
EngHosam
prev version 22.100
updated to 22.110
same problem .....
n_scott_pearson
EngHosam
yes, you are right
the result in testing with SSD:
tested again,... the problem seems to be in the HDD, thanks
unstable condition discussed here:
https://community.intel.com/t5/Wireless/New-driver-22-110-1-1-very-slow/td-p/1357671
