Wireless
8660 Discussions
Intel Wifi 6 AX201 automatically disables when playing games
corndog
Hi, I've just experienced this network issue in my laptop now, but when I just browse in Edge or Chrome, I don't get the issue, but when I start a game like Valorant or Dota 2 the driver shuts down. I tried to uninstall and reinstall the driver but when I uninstall the driver and reboot my laptop it automatically installs. Also, when I try to install the latest update of the Wi-Fi driver, it shows Documentation fixing or something like that.
JeanetteC_Intel
Hello corndog,
To better understand the issue, I need more details about your system. Please provide the following information:
  1. Is your system a desktop PC or a laptop?
  2. Is the Intel® Wi-Fi 6 AX201 pre-installed on your device, or did you install it as an upgrade component?
  3. Does the issue occur only while playing games like Valorant or Dota 2, or does your wireless connection disconnect/disable in other situations as well?
  4. Was the Intel® Wi-Fi 6 AX201 working previously, and the issue has only recently appeared, or has it been problematic since you first started using it?
Additionally, I would appreciate it if you could share your system configuration to help me provide an accurate solution. You can do this by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
  • Click Scan.
  • Click Save. *Attach the SSU log file as you reply.
I look forward to your reply.
JeanetteC.
corndog
Hello, Jeanette!
1. My system is a laptop.
2. Yes, the Intel Wi-Fi 6 AX201 is pre-installed.
3. It only occurs when I play games for around 10mins or so, but when I'm just browsing in my Edge or Chrome it doesn't occur.
4. The Intel® Wi-Fi 6 AX201 is working previously, and it occurred yesterday only when I noticed when I try to play games I keep on disconnecting to my Wi-Fi that's when I realized I had a problem in my driver, I updated it this July 23rd, but it only occurred yesterday.
JedG_Intel
Hello corndog,
Thank you for sharing all this information.
Since you are using a laptop system, I would just like to inform you that we recommend utilizing the drivers from the OEM since this is altered and customized by the manufacturer to be fully compatible with your system.
To further troubleshoot the issue, please try to follow the steps below.
1. Perform a clean installation of the latest wireless drivers - Modern 14 B11M
2. Make sure you have the recommended settings for the wireless standard: Recommended Settings for 802.11ax Connectivity.
3. Confirm there are no pending Windows updates.
4. Try connecting to another network if available, and test if the issue persists.
5. Try connecting to another Access Point (AP) or router, and test if the issue persists.
6. Make sure the router or Access Point (AP) is well configured. We recommend contacting your Internet Service Provider (ISP) to ensure this.
For reference: Intel® Wireless Adapter Keeps Disconnecting from the Network
If you continue to observe the same issue, please let us know.
Best regards
Jed G.
JeanetteC_Intel
Hello corndog,
Did you have a chance to review the previous post?
Please feel free to reach out if you have any questions.
Best regards
JeanetteC.
JeanetteC_Intel
Hello corndog,
Since I haven't received any response from you recently, I will go ahead and close this thread.
Sincerely,
JeanetteC.
