Wireless
9031 Discussions
Intel Wifi Link 5300 Connection Problems
I am trying to connect my Dell Latitude E4300 laptop running Windows 7 to a Linksys WG54 AP. While WiFi connections to any other AP basically work without any problems, any authentication attempts to the above AP fail. The 5300 driver version is 13.3.0.24 and the diagnostic logs are as follows:
# EventSourceTimeError SeverityDomainUserDescription2S24EvMon09/14/2010 14:15:54InformationDriverSYSTEMAddToExclude 00:90:4c:60:04:00 agoda_guest 6 WEV_EXCLUDE_LIST_REASON_802_11_DISASSOC_4WAY_FAILURE3S24EvMon09/14/2010 14:15:54ErrorDriverSYSTEMRxDeAut 00:90:4c:60:04:00 REASON_4WAY_HANDSHAKE_TO4S24EvMon09/14/2010 14:15:50SuccessDriverSYSTEMRxAssocResp 00:90:4c:60:04:00 6 -845S24EvMon09/14/2010 14:15:50SuccessDriverSYSTEMRxAuthSuccess 00:90:4c:60:04:00 66S24EvMon09/14/2010 14:15:50InformationDriverSYSTEMATC 00:90:4c:60:04:00 agoda_guest 6 RSSI=-837S24EvMon09/14/2010 14:15:50InformationDriverSYSTEMAddToExclude 00:90:4c:60:04:00 agoda_guest 6 WEV_EXCLUDE_LIST_REASON_802_11_DISASSOC_4WAY_FAILURE8S24EvMon09/14/2010 14:15:50ErrorDriverSYSTEMRxDeAut 00:90:4c:60:04:00 REASON_4WAY_HANDSHAKE_TO9S24EvMon09/14/2010 14:15:46SuccessDriverSYSTEMRxAssocResp 00:90:4c:60:04:00 6 -8210S24EvMon09/14/2010 14:15:46SuccessDriverSYSTEMRxAuthSuccess 00:90:4c:60:04:00 611S24EvMon09/14/2010 14:15:46SuccessDriverSYSTEMRxAuthSuccess 00:90:4c:60:04:00 612S24EvMon09/14/2010 14:15:46InformationDriverSYSTEMATC 00:90:4c:60:04:00 agoda_guest 6 RSSI=-8213S24EvMon09/14/2010 14:15:46InformationDriverSYSTEMAddToExclude 00:90:4c:60:04:00 agoda_guest 6 WEV_EXCLUDE_LIST_REASON_802_11_DISASSOC_4WAY_FAILURE14S24EvMon09/14/2010 14:15:46ErrorDriverSYSTEMRxDeAut 00:90:4c:60:04:00 REASON_4WAY_HANDSHAKE_TO15S24EvMon09/14/2010 14:15:42SuccessDriverSYSTEMRxAssocResp 00:90:4c:60:04:00 6 -8016S24EvMon09/14/2010 14:15:42SuccessDriverSYSTEMRxAuthSuccess 00:90:4c:60:04:00 617S24EvMon09/14/2010 14:15:42SuccessDriverSYSTEMRxAuthSuccess 00:90:4c:60:04:00 618S24EvMon09/14/2010 14:15:42InformationDriverSYSTEMATC 00:90:4c:60:04:00 agoda_guest 6 RSSI=-8019S24EvMon09/14/2010 14:15:42InformationDriverSYSTEMAddToExclude 00:90:4c:60:04:00 agoda_guest 6 WEV_EXCLUDE_LIST_REASON_802_11_DISASSOC_4WAY_FAILURE20S24EvMon09/14/2010 14:15:42ErrorDriverSYSTEMRxDeAut 00:90:4c:60:04:00 REASON_4WAY_HANDSHAKE_TO21S24EvMon09/14/2010 14:15:38SuccessDriverSYSTEMRxAssocResp 00:90:4c:60:04:00 6 -8222S24EvMon09/14/2010 14:15:38SuccessDriverSYSTEMRxAuthSuccess 00:90:4c:60:04:00 623S24EvMon09/14/2010 14:15:38SuccessDriverSYSTEMRxAuthSuccess 00:90:4c:60:04:00 624S24EvMon09/14/2010 14:15:38SuccessDriverSYSTEMRxAuthSuccess 0...
Hi, I have the same issue.
5,S24EvMon,11/18/2012 16:54:23,Error,Driver,SYSTEM,RxDeAut 00:26:44:7e:cf:94 REASON_PRIOR_AUTH_INVALID
6,S24EvMon,11/18/2012 16:54:23,Information,Driver,SYSTEM,AddToExclude 00:26:44:7e:cf:94 PlusnetWireless7ECF94 1 WEV_EXCLUDE_LIST_REASON_802_11_AUTH_FAILURE
7,S24EvMon,11/18/2012 16:54:23,Information,Driver,SYSTEM,ATC 00:26:44:7e:cf:94 PlusnetWireless7ECF94 1 RSSI=-51
8,ZCfgSvc,11/18/2012 16:54:23,Information,Security,SYSTEM,Authenticating Wireless Profile: PlusnetWireless7ECF94
9,S24EvMon,11/18/2012 16:54:23,Success,Driver,SYSTEM,RxAssocResp 00:26:44:7e:cf:94 1 -42
It continues for about 5 minutes after boot up.. and then it eventually connects.
Can anyone help with this? Thanks.
