Wireless
8871 Discussions
Intel Wireless-AC 9260 160MHz wireless networks not displayed
tszpara
Intel Wireless-AC 9260 160MHz wireless card as part of ASUS TUF Gaming X570 motherboard.
Unable to connect to ANY wifi.  When I click on show available networks I get a black screen.
There should be at least a dozen networks (close neighbors) in range.
I suspect it is a windows setting but haven't found a solution.
If I go here and manually enter everything I can connect so it's not a hardware issue.
tszpara
Symantec Antivirus was the problem. Removed and replaced AV. Thanks to all who helped.
LeonWaksman
I assume that you have all necessary drivers (include WiFi Driver) installed. Open Windows Settings: Network and Internet>Network Sharing Center>Advanced sharing settings, then check if the Network discovery is on.
Leon
LeonWaksman
tszpara
Forgot to mention already tried that.
If I type
netsh wlan show networks
I see a dozen in command prompt but none when I click show available networks
tszpara
