Wireless
8563 Discussions
Intel Wireless AC 9560 not working on 5 GHz - log says the device is not functioning properly
RD000
I have this very annoying problem with my Intel 9560 wifi adapter. I have a ASUS RoG GL703GM and when I try to connect to my 5 GHz network, the adapter most of the time immediately disconnects, or sometimes works, but just for a while and then fails.
I have tried updating the driver from the manufacturer, roll back to the default one, tried updating through the intel website, through the intel driver and support assistant, uninstalling, reinstalling, nothing helped.
I'm desperate. I have a 866 mbps wifi router and 300 mbps fiber connection and I need to have 5 GHz connection, that's why I bought a notebook with such a powerful wifi adapter, yet this is what happens.
I also have other devices that can use 5 ghz wifi, like my phone and my iPad and they don't have absolutely any problem connecting, even from afar, they still deliver whopping 300 mbps stable wifi connection, so it's definitely not an issue of the router.
I have also tried running linux and there the 5 ghz connection works, but it's mostly slow. I have once got it to 300 mbps, but just once, most of the time it's just 50 - 30 mbps, even while sitting next to the router.
2.4 GHz connection works mostly fine, I have also another router that's only 2.4 GHz and it also works fine with the computer. It's just the 5 GHz that's failing and considering the event log, it's a problem of the card or of the drivers.
Any help will be appreciated.
Thanks!
QUICK UPDATE:
Just tried installing Linux directly on my machine and have to confirm the WiFi works like a charm (almost), 5 GHz connects well and the speed is nicely 250 mbit on average, which is plausible and acceptable.
I have also tried connecting an external WiFi antenna Edimax AC600 (under Windows) and voila, it works nicely, even on 5 GHz - around 200 mbps, which is understandable as it isn't a high-end adapter.
So the conclusion is that it's definitely a problem with the Intel WiFi adapter drivers.
UPDATE 2:
Just tried a different 5 GHz router - the issue still persists. I was able to connect for a while, but then the connection dropped. So it's not an issue of the one specific router.
Leonardo_C_Intel
Hello RD000
Thank you for posting in the Intel Community.
In order to look in to the issue that you are having please provide me with the following information:
·        Please fill up the information request on the attach document.
·        Please attach to this thread the TXT file the Intel® System Support Utility will generate: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
·        Steps to save the report:
1-   Run the utility.
2-   Click on “Scan” to get the scanned system.
3-   Once the scan is complete click on “next”.
4-   Use the “save” option, save the report to your desktop.
5-   To attach a file, you must click the “Attach” option on the bottom left-hand corner of the response box.
Hope this helps.
Leonardo C.
Under Contract to Intel Corporation
RD000
here it is. Still, the most weird thing about this seems to be that it's basically working in Linux.
Thanks for your reply
RD000
Plus the form.
Leonardo_C_Intel
Hello RD000 Thank you for the information. After reviewing the information on the reports I am noticing that you have the driver 20.60.2.1625 currently installed, please try the Intel® wireless driver version: 21.0.0 on the system (https://downloadcenter.intel.com/download/28687/Windows-10-Wi-Fi-Drivers-for-Intel-Wireless-Adapters?product=99446). Try completing a clean installation of the driver on the system following the instructions on the following link: https://www.intel.com/content/www/us/en/support/articles/000022173/network-and-i-o/wireless-networking.html Please let me know the outcome. Hope this helps. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
RD000
Tried that already, didn't help. But because you asked, I tried it one more time with that specific driver version you said.
It didn't help. There's no change. Btw there's also a newer version through the Intel DSA, tried that one too - it didn't change anything.
Leonardo_C_Intel
Hello RD000 Thank you for completing the testing, allow me to investigate the behavior that you are having, I will be posting back as soon as possible Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
RD000
Thank you. I think the most helpful are the first two log screenshots, we have to figure out what they mean.
Leonardo_C_Intel
Hello RD000 Thank you for the information. Please provide me with the Windows system event log and WLAN-AutoConfig log Steps to collect system event log and WLAN-AutoConfig log 1. In Windows search, search for “event” and select “Event Viewer” 2. On the left pane, expand “Windows Logs” 3. Right click on “System” and select “Clear Log…” 4. Expand “Applications and Service Logs” -> “Microsoft” -> “Windows” -> “WLANAutoConfig” 5. Right click on “Operational” and select “Clear Log…” 6. Reproduce issue. 7. Reference above steps (instead of Clear Log… choose Save All Events as…) to save the system event and WLAN-AutoConfig logs in .evtx format. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
RD000
done that. You can't upload .evtx files here so i .zipped it. :)
Slight explanation about what happened (for easier reading of the event log):
event from 10. 5. - notebook was turned off
11. 5.:
  1. notebook was turned on
  2. notebook connected to the 2.4 GHz network TP-Archer, it worked
  3. I disconnected it from the 2.4 GHz network to connect it to the 5 GHz network, TP-Archer5G
  4. it worked for a while then it disconnected and doesn't work anymore
BTW. i'm using the oldest possible drivers right now (stock ones), because with these, it AT LEAST sometimes works on the 5 GHz, all the newer just don't work at all.
Thanks for your effort :)
Leonardo_C_Intel
Hello RD000 Thank you for the information, allow me to investigate the behavior that you are reporting I will be porting back as soon as possible. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
Leonardo_C_Intel
Hello RD000 Thank you for waiting. • Have you tried using OEM drivers instead of generic? Reference link https://www.asus.com/me-en/Laptops/ROG-Strix-GL703/HelpDesk_Download/ (search with you system model or SKU). • Please set the Advanced Intel® Wireless Adapter Settings https://www.intel.com/content/www/us/en/support/articles/000005585/network-and-i-o/wireless-networking.html to comply with the router settings. • By the way does the Intel® Wireless-AC 9560 come pre-installed on the system? Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
Leonardo_C_Intel
Hello RD000 Have you tried the steps provided? Does the Intel® Wireless-AC 9560 come pre-installed on the system? Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
Leonardo_C_Intel
Hello RD000 I haven’t heard back from you; please contact us if you have any additional questions. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
letvinov28
I have same situation! But I noticed that this only happens when I charge the laptop and use Nvidia GPU! If I'm running on battery everything is fine. Wifi module changing not help!(official RMA) . On linux same situation! Please help! I wont use my wi-fi on full speed!
Asus UX533FD
