Wireless
8636 Discussions
Intel Wireless Bluetooth, state constantly toggles after a driver update pushed to Windows 10 64 1909. Have tried everything
User1589699940172478
I Have an Asrock 390m-itx/ac mobo. Everything was fine, but then these automatic updates were pushed to my pc, and now the intel wireless bluetooth is screwed up. You can see the little usb icon in the systray toggling on/off continuously, and if you look in device manager, the icon is constantly disappearing and reappearing, and you can hear the windows new connection sound effect constantly going off. Intolerable.
To delete or uninstall it, I first have to disable it, otherwise I get an error that it’s in use. I have tried: removing from device manager, uninstalling from programs, sfc /scan now, update driver, roll back driver, roll back windows updates, using generic driver, using intel driver from asrock website, using latest driver from intel’s website, in-place upgrade. Unfortunately, restore points were not turned on.
Microsoft is now recommending I do a full clean install now. Intel, do you have anything for me to try first?
OK so here’s the crazy thing. Here’s the solution apparently. https://answers.microsoft.com/en-us/windows/forum/all/intel-bluetooth-reconnecting-loop/472698b0-17cb-45ab-8bf0-30161e8de11e
It appears that when your Intel Bluetooth gets stuck, turning the pc off and Unplugging so as to drain the power from the computer seems to be the fix. Merely shutting it down and starting it up again doesn’t change anything even if you uninstall the drivers.
I would really love for Intel Bluetooth engineers to see this. As you can see from that solution answer, it has helped 80 people so it seems to be a fairly common occurrence out there. I’m so glad I saw that before I spent four hours reinstalling that computer from scratch.
n_scott_pearson
To perform a Clean WLAN Install:
  1. Download the latest Bluetooth and WiFi drivers for your adapter. Here are links to these drivers for all non-Legacy adapters: https://downloadcenter.intel.com/download/28685/Intel-Wireless-Bluetooth-for-Windows-10?product=94854 and https://downloadcenter.intel.com/download/28687/Windows-10-Wi-Fi-Drivers-for-Intel-Wireless-Adapters?product=94854
  2. Disable Internet access. Unplug Ethernet cable and/or disable wireless. Keep disabled until told to re-enable.
  3. From Apps & Features, uninstall any instances of the Intel PROSet/Wireless Software and/or Intel Wireless Bluetooth packages present. If prompted, choose to Discard Settings.
  4. Manually shutdown and reboot your computer.
  5. In Device Manager , expand the Network Adapters; if there is no entry for your Intel Wireless adapter, go to Step 8.
  6. Right-click on the Intel Wireless adapter and select Uninstall device. Make sure to check the option to Delete the driver software for this device.
  7. Go to Step 4.
  8. Clear out your temporary files using the Windows Clean Disk tool.
  9. Install the driver packages downloaded in step one. Install Bluetooth first, followed by Wireless.
  10. Manually shutdown and reboot your computer.
  11. Enable Internet access.
  12. Test.
Hope this helps,
Hi
I just had a repeat of my problem. I tried your steps a few times and each time I got the problem back. This time, I can’t connect it to a recent Windows update. The only thing that changed was I installed a new VR Helmet, the Valve Index. Everything was fine for a few days, and then I go to find this terrible curse is back.
I’m on the verge of another painful reinstall from scratch, so please let me know if there’s anything I should try.
I should note that when I see intel wireless in my device manager, i can uninstall, but there is no checkbox to delete files as well. This does exist on Intel Bluetooth. When I reboot, the Intel Wireless driver is already reinstalled.
chuim
I created an account only to say thank you for recording this fix! 4 years later and it fixed my Intel Bluetooth too!
I had recently updated Intel BT drivers and after that no BT device would connect to my desktop PC anymore. The BT on/off toggle had disappeared form that right-side panel accessible from the taskbar. When I opened Device Manager, the entire tree of devices would keep on refreshing every 2 seconds, until I manually disabled the Intel BT adapter (which was being continuously reset or something). I tried all manners of drive removal/upgrade/downgrade to no avail. Of course I tried rebooting the computer and even messed a bit with BIOS configs for nothing.
But as described, fully shutting down, disconnecting everything from the wall plugs, and waiting ~15 min did the trick! Thanks!
I just wanted to say thank you. I wound up reinstalling Windows to 1903 and then updating to 1909, this time with an image backup in case anything went wrong. The driver situation did not recur. But if I am stuck in that hole again in the future, I’ll refer to these steps. Thank you very much.
Geeter
Yep. Like many others, I created an account to say thank you- roughly four years after this thread was created. The solution is still relevant, and it's far and away much easier and less time consuming than any of the other "solutions" I tried.
Edit: It might be important to add that different machines might require a longer or shorter interruption in the power supply for this to work. I've seen one person in this thread who unplugged their machine for 15 minutes, but I only unplugged mine for about 30 seconds.
