Wireless
8651 Discussions
Intel ax201 firmware on Linux
psystems
The wireless card on my laptop has just stopped working
Hardware:
  • Intel AX 201 Dual Band Wifi / Bluetooth
  • 40 GB ram, 512 GB SSD
  • Metabox Flo laptop based on L140CU
Operating System:
Ubuntu 20.04
Dmesg output:
[ 17.353672] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-59.ucode failed with error -2
[ 17.353704] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-58.ucode failed with error -2
[ 17.353729] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-57.ucode failed with error -2
[ 17.354000] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-56.ucode failed with error -2
[ 17.357303] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[ 17.357323] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 65.3.35.22
[ 17.357329] iwlwifi 0000:00:14.3: Found debug destination: EXTERNAL_DRAM
[ 17.357331] iwlwifi 0000:00:14.3: Found debug configuration: 0
[ 17.357689] iwlwifi 0000:00:14.3: loaded firmware version 55.d9698065.0 QuZ-a0-hr-b0-55.ucode op_mode iwlmvm
[ 17.470105] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x354
[ 17.656463] iwlwifi 0000:00:14.3: base HW address: 34:7d:f6:14:a0:0a
[ 17.756903] iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
[ 22.039658] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x0, CPU2 Status: 0x3100000
[ 22.039683] iwlwifi 0000:00:14.3: UMAC PC: 0xc00c0538
[ 22.039708] iwlwifi 0000:00:14.3: LMAC PC: 0x0
[ 22.039709] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired.
[ 22.039785] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 22.039786] iwlwifi 0000:00:14.3: Status: 0x00000000, count: 181360834
[ 22.039788] iwlwifi 0000:00:14.3: Loaded firmware version: 55.d9698065.0 QuZ-a0-hr-b0-55.ucode
[ 22.039789] iwlwifi 0000:00:14.3: 0x72544300 | ADVANCED_SYSASSERT
[ 22.039791] iwlwifi 0000:00:14.3: 0xF0005201 | trm_hw_status0
[ 22.039792] iwlwifi 0000:00:14.3: 0x0658FFEC | trm_hw_status1
[ 22.039793] iwlwifi 0000:00:14.3: 0x6916FFF4 | branchlink2
[ 22.039794] iwlwifi 0000:00:14.3: 0xA9610B48 | interruptlink1
[ 22.039795] iwlwifi 0000:00:14.3: 0xBE10360C | interruptlink2
[ 22.039796] iwlwifi 0000:00:14.3: 0xEE583F37 | data1
[ 22.039797] iwlwifi 0000:00:14.3: 0xD1FD5A28 | data2
[ 22.039798] iwlwifi 0000:00:14.3: 0x837D0BF9 | data3
[ 22.039799] iwlwifi 0000:00:14.3: 0xCFC96067 | beacon time
[ 22.039800] iwlwifi 0000:00:14.3: 0xDAEFDEFB | tsf low
[ 22.039801] iwlwifi 0000:00:14.3: 0x9AAE2B6F | tsf hi
[ 22.039802] iwlwifi 0000:00:14.3: 0x8A431AC0 | time gp1
[ 22.039803] iwlwifi 0000:00:14.3: 0x34E6614C | time gp2
[ 22.039803] iwlwifi 0000:00:14.3: 0x089FE732 | uCode revision type
[ 22.039804] iwlwifi 0000:00:14.3: 0xF6C9D1D7 | uCode version major
[ 22.039805] iwlwifi 0000:00:14.3: 0x9BF752AB | uCode version minor
[ 22.039806] iwlwifi 0000:00:14.3: 0xC3D8B069 | hw version
[ 22.039807] iwlwifi 0000:00:14.3: 0x899B2CFC | board version
[ 22.039808] iwlwifi 0000:00:14.3: 0xBD042CD7 | hcmd
[ 22.039809] iwlwifi 0000:00:14.3: 0x0B560D49 | isr0
[ 22.039810] iwlwifi 0000:00:14.3: 0xD8664FAF | isr1
[ 22.039811] iwlwifi 0000:00:14.3: 0x1CE9F4AC | isr2
[ 22.039812] iwlwifi 0000:00:14.3: 0x9999FE6A | isr3
[ 22.039813] iwlwifi 0000:00:14.3: 0x97E39D9D | isr4
[ 22.039814] iwlwifi 0000:00:14.3: 0x486C98E7 | last cmd Id
[ 22.039815] iwlwifi 0000:00:14.3: 0xC4403986 | wait_event
[ 22.039816] iwlwifi 0000:00:14.3: 0xB625ABA8 | l2p_control
[ 22.039817] iwlwifi 0000:00:14.3: 0x074D4EED | l2p_duration
[ 22.039818] iwlwifi 0000:00:14.3: 0xEA8BD708 | l2p_mhvalid
[ 22.039819] iwlwifi 0000:00:14.3: 0x486F29C6 | l2p_addr_match
[ 22.039820] iwlwifi 0000:00:14.3: 0xA54FEBF5 | lmpm_pmg_sel
[ 22.039821] iwlwifi 0000:00:14.3: 0xC767346F | timestamp
[ 22.039821] iwlwifi 0000:00:14.3: 0x953278B2 | flow_handler
[ 22.039856] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 22.039857] iwlwifi 0000:00:14.3: Status: 0x00000000, count: -1798015353
[ 22.039858] iwlwifi 0000:00:14.3: 0xAB62A5AF | ADVANCED_SYSASSERT
[ 22.039859] iwlwifi 0000:00:14.3: 0xB99A0007 | umac branchlink1
[ 22.039860] iwlwifi 0000:00:14.3: 0x92F6F7CD | umac branchlink2
[ 22.039861] iwlwifi 0000:00:14.3: 0x124F254F | umac interruptlink1
[ 22.039862] iwlwifi 0000:00:14.3: 0x3289AAF5 | umac interruptlink2
[ 22.039863] iwlwifi 0000:00:14.3: 0x0F11770E | umac data1
[ 22.039864] iwlwifi 0000:00:14.3: 0x99B7B157 | umac data2
[ 22.039865] iwlwifi 0000:00:14.3: 0x528DC7E7 | umac data3
[ 22.039866] iwlwifi 0000:00:14.3: 0x92FAE962 | umac major
[ 22.039867] iwlwifi 0000:00:14.3: 0xEAB15273 | umac minor
[ 22.039868] iwlwifi 0000:00:14.3: 0xBAE3E48A | frame pointer
[ 22.039869] iwlwifi 0000:00:14.3: 0x588C1D39 | stack pointer
[ 22.039870] iwlwifi 0000:00:14.3: 0x738BEFF8 | last host cmd
[ 22.039870] iwlwifi 0000:00:14.3: 0x37426123 | isr status reg
[ 22.039888] iwlwifi 0000:00:14.3: Fseq Registers:
[ 22.039890] iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
[ 22.039893] iwlwifi 0000:00:14.3: 0x00290033 | FSEQ_TOP_INIT_VERSION
[ 22.039896] iwlwifi 0000:00:14.3: 0x00090006 | FSEQ_CNVIO_INIT_VERSION
[ 22.039898] iwlwifi 0000:00:14.3: 0x0000A482 | FSEQ_OTP_VERSION
[ 22.039901] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[ 22.039903] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 22.039906] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[ 22.039908] iwlwifi 0000:00:14.3: 0x01300504 | FSEQ_CNVR_ID
[ 22.039911] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[ 22.039945] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_AUX_MISC_CHIP
[ 22.040012] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 22.040078] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 22.042477] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 4 fired.
[ 22.042481] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
[ 22.042482] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
[ 30.424025] iwlwifi 0000:00:14.3: WRT: Failed to dump region: id=4, type=5
[ 30.424031] iwlwifi 0000:00:14.3: WRT: Failed to dump region: id=6, type=5
Driver and other info:
lshw -C network
*-network UNCLAIMED
description: Network controller
product: Wireless-AC 9462
vendor: Intel Corporation
physical id: 14.3
bus info: pci@0000:00:14.3
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix cap_list
configuration: latency=0
resources: memory:91318000-9131bfff
modinfo iwlwifi
filename: /lib/modules/5.11.0-25-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license: GPL
author: Intel Corporation <linuxwifi@intel.com>
description: Intel(R) Wireless WiFi driver for Linux
firmware: iwlwifi-100-5.ucode
firmware: iwlwifi-1000-5.ucode
firmware: iwlwifi-135-6.ucode
firmware: iwlwifi-105-6.ucode
firmware: iwlwifi-2030-6.ucode
firmware: iwlwifi-2000-6.ucode
firmware: iwlwifi-5150-2.ucode
firmware: iwlwifi-5000-5.ucode
firmware: iwlwifi-6000g2b-6.ucode
firmware: iwlwifi-6000g2a-6.ucode
firmware: iwlwifi-6050-5.ucode
firmware: iwlwifi-6000-6.ucode
firmware: iwlwifi-7265D-29.ucode
firmware: iwlwifi-7265-17.ucode
firmware: iwlwifi-3168-29.ucode
firmware: iwlwifi-3160-17.ucode
firmware: iwlwifi-7260-17.ucode
firmware: iwlwifi-8265-36.ucode
firmware: iwlwifi-8000C-36.ucode
firmware: iwlwifi-9260-th-b0-jf-b0-46.ucode
firmware: iwlwifi-9000-pu-b0-jf-b0-46.ucode
firmware: iwlwifi-SoSnj-a0-mr-a0-59.ucode
firmware: iwlwifi-ma-a0-mr-a0-59.ucode
firmware: iwlwifi-ma-a0-gf-a0-59.ucode
firmware: iwlwifi-SoSnj-a0-hr-b0-59.ucode
firmware: iwlwifi-SoSnj-a0-gf-a0-59.ucode
firmware: iwlwifi-SoSnj-a0-gf4-a0-59.ucode
firmware: iwlwifi-ty-a0-gf-a0-59.ucode
firmware: iwlwifi-so-a0-gf-a0-59.ucode
firmware: iwlwifi-so-a0-hr-b0-59.ucode
firmware: iwlwifi-so-a0-jf-b0-59.ucode
firmware: iwlwifi-cc-a0-59.ucode
firmware: iwlwifi-QuQnj-b0-jf-b0-59.ucode
firmware: iwlwifi-QuZ-a0-jf-b0-59.ucode
firmware: iwlwifi-QuZ-a0-hr-b0-59.ucode
firmware: iwlwifi-Qu-b0-jf-b0-59.ucode
firmware: iwlwifi-Qu-c0-hr-b0-59.ucode
firmware: iwlwifi-QuQnj-b0-hr-b0-59.ucode
firmware: iwlwifi-Qu-b0-hr-b0-59.ucode
i have tried later ucode files on Fedora 34 and have tried an earlier OS of Fedora 32, which this card did work with for a period of time.
The wireless card is firmly installed with screw and tape over the antenna connections/wires.
iw dev  produces no output, and no network interface is created.
DeividA_Intel
Hello psystems,
1. Is the Bluetooth working?
2. Have you update your drivers and BIOS?
3. Did you noticed the issue after a system update?
4. Run the following commands and send us the outcome:
· modinfo iwlwifi > If there is no output, then the module isn’t installed this is the distribution installation issue.
· lsmod | grep iwlwifi > If the result is empty, the driver hasn't been loaded. Most likely to be a distribution issue.
· To verify, please type: dmesg | grep iwlwifi > If the result is empty, the driver wasn’t initialized and this is a distribution issue. If there is a result populated, proceed with the next step.
· dmesg | grep “no suitable firmware found!” > If the result is not empty, it means you don't have a suitable FW (API mentioned in the dmesg).
· Please visit here: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi for supported FW, or here https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/ for the latest versions.
5. If the above steps don't work, collect the debug data:
Type: dmesg | grep ASSERT
If the output is empty, please follow this wiki: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi/debugging to extract dmesg and trace-cmd.
If the output has value, please collect it from the wiki FW dump too.
Deivid A.
DeividA_Intel
Hello psystems,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
 Hello psystems,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
adell
Same problem here. It randomly stops working, sometime after months or hours after it's on. If I restart the laptop it still doesn't work. If I completely shut down and then reboot it works. Dell forum has several other people with same problem with this card
Dell Latitude 7420, AX201
lspci
00:14.3 Network controller: Intel Corporation Wi-Fi 6 AX201 (rev 20) Subsystem: Intel Corporation Device 4070 Flags: bus master, fast devsel, latency 0, IRQ 16 Memory at 605319c000 (64-bit, non-prefetchable) [size=16K] Capabilities: [c8] Power Management version 3 Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+ Capabilities: [40] Express Root Complex Integrated Endpoint, MSI 00 Capabilities: [80] MSI-X: Enable+ Count=16 Masked- Capabilities: [100] Latency Tolerance Reporting Capabilities: [164] Vendor Specific Information: ID=0010 Rev=0 Len=014 <?> Kernel driver in use: iwlwifi Kernel modules: iwlwifi
- Yes, Bluetooth is working even when wifi stops
- yes, latest drivers
- no, it happens since I bought the laptop 2 years ago
filename:       /lib/modules/6.0.5-200.fc36.x86_64/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko.xz
license:        GPL
iwlwifi               413696  1 iwlmvm
cfg80211             1097728  3 iwlmvm,iwlwifi,mac80211
- see the dmesg below
- not present
dmesg
[56160.063997] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[56160.064144] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[56160.064147] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6
[56160.064151] iwlwifi 0000:00:14.3: Loaded firmware version: 71.058653f6.0 QuZ-a0-hr-b0-71.ucode
[56160.064154] iwlwifi 0000:00:14.3: 0x00000FA2 | ADVANCED_SYSASSERT
[56160.064158] iwlwifi 0000:00:14.3: 0x000022F0 | trm_hw_status0
[56160.064160] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[56160.064162] iwlwifi 0000:00:14.3: 0x004CBE06 | branchlink2
[56160.064164] iwlwifi 0000:00:14.3: 0x004B5520 | interruptlink1
[56160.064166] iwlwifi 0000:00:14.3: 0x004B5520 | interruptlink2
[56160.064168] iwlwifi 0000:00:14.3: 0x004C66CC | data1
[56160.064170] iwlwifi 0000:00:14.3: 0x00000000 | data2
[56160.064172] iwlwifi 0000:00:14.3: 0x00000000 | data3
[56160.064174] iwlwifi 0000:00:14.3: 0x67C0E660 | beacon time
[56160.064176] iwlwifi 0000:00:14.3: 0x00000000 | tsf low
[56160.064178] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[56160.064179] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[56160.064181] iwlwifi 0000:00:14.3: 0x98799F38 | time gp2
[56160.064183] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[56160.064185] iwlwifi 0000:00:14.3: 0x00000047 | uCode version major
[56160.064188] iwlwifi 0000:00:14.3: 0x058653F6 | uCode version minor
[56160.064190] iwlwifi 0000:00:14.3: 0x00000351 | hw version
[56160.064192] iwlwifi 0000:00:14.3: 0x00489001 | board version
[56160.064194] iwlwifi 0000:00:14.3: 0x8096FA00 | hcmd
[56160.064196] iwlwifi 0000:00:14.3: 0x00020000 | isr0
[56160.064198] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[56160.064199] iwlwifi 0000:00:14.3: 0x08F80002 | isr2
[56160.064201] iwlwifi 0000:00:14.3: 0x44C3429C | isr3
[56160.064203] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[56160.064205] iwlwifi 0000:00:14.3: 0x052E001C | last cmd Id
[56160.064207] iwlwifi 0000:00:14.3: 0x004C66CC | wait_event
[56160.064209] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[56160.064211] iwlwifi 0000:00:14.3: 0x00000000 | l2p_duration
[56160.064213] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
[56160.064215] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[56160.064217] iwlwifi 0000:00:14.3: 0x0000004B | lmpm_pmg_sel
[56160.064218] iwlwifi 0000:00:14.3: 0x00000000 | timestamp
[56160.064220] iwlwifi 0000:00:14.3: 0x00004838 | flow_handler
[56160.064306] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[56160.064308] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 7
[56160.064310] iwlwifi 0000:00:14.3: 0x2000031C | ADVANCED_SYSASSERT
[56160.064313] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[56160.064315] iwlwifi 0000:00:14.3: 0x80455B7C | umac branchlink2
[56160.064317] iwlwifi 0000:00:14.3: 0x804721A2 | umac interruptlink1
[56160.064319] iwlwifi 0000:00:14.3: 0x00000000 | umac interruptlink2
[56160.064321] iwlwifi 0000:00:14.3: 0x00000001 | umac data1
[56160.064322] iwlwifi 0000:00:14.3: 0x0030A624 | umac data2
[56160.064324] iwlwifi 0000:00:14.3: 0x00000000 | umac data3
[56160.064326] iwlwifi 0000:00:14.3: 0x00000047 | umac major
[56160.064328] iwlwifi 0000:00:14.3: 0x058653F6 | umac minor
[56160.064330] iwlwifi 0000:00:14.3: 0x98799F81 | frame pointer
[56160.064332] iwlwifi 0000:00:14.3: 0xC0887F0C | stack pointer
[56160.064334] iwlwifi 0000:00:14.3: 0x0085019C | last host cmd
[56160.064336] iwlwifi 0000:00:14.3: 0x00100020 | isr status reg
[56160.064412] iwlwifi 0000:00:14.3: IML/ROM dump:
[56160.064414] iwlwifi 0000:00:14.3: 0x00000003 | IML/ROM error/state
[56160.064475] iwlwifi 0000:00:14.3: 0x000056BB | IML/ROM data1
[56160.064588] iwlwifi 0000:00:14.3: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[56160.064642] iwlwifi 0000:00:14.3: Fseq Registers:
[56160.064669] iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
[56160.064705] iwlwifi 0000:00:14.3: 0x80290033 | FSEQ_TOP_INIT_VERSION
[56160.064741] iwlwifi 0000:00:14.3: 0x00090006 | FSEQ_CNVIO_INIT_VERSION
[56160.064777] iwlwifi 0000:00:14.3: 0x0000A482 | FSEQ_OTP_VERSION
[56160.064831] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[56160.064879] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[56160.064933] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[56160.064969] iwlwifi 0000:00:14.3: 0x01300504 | FSEQ_CNVR_ID
[56160.065005] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[56160.065043] iwlwifi 0000:00:14.3: 0x01300504 | CNVR_AUX_MISC_CHIP
[56160.065081] iwlwifi 0000:00:14.3: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[56160.065119] iwlwifi 0000:00:14.3: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[56160.065348] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
[56175.650235] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x58a3, CPU2 Status: 0x3
[56175.650369] iwlwifi 0000:00:14.3: WFPM_LMAC1_PD_NOTIFICATION: 0x0
[56175.650494] iwlwifi 0000:00:14.3: HPM_SECONDARY_DEVICE_STATE: 0x742
[56175.650618] iwlwifi 0000:00:14.3: WFPM_MAC_OTP_CFG7_ADDR: 0x0
[56175.650659] iwlwifi 0000:00:14.3: WFPM_MAC_OTP_CFG7_DATA: 0x0
[56175.650759] iwlwifi 0000:00:14.3: UMAC PC: 0x80471ce8
[56175.650884] iwlwifi 0000:00:14.3: LMAC PC: 0x14fac
[56175.650888] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[56175.651304] iwlwifi 0000:00:14.3: Loaded firmware version: 71.058653f6.0 QuZ-a0-hr-b0-71.ucode
[56175.651308] iwlwifi 0000:00:14.3: 0x00000000 | ADVANCED_SYSASSERT
[56175.651311] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status0
raknerak
I have same problem with the same hw on ubuntu 22.04.3
lspci | grep Network
[ 6297.896842] wlp0s20f3: disconnect from AP 50:eb:f6:a8:07:b4 for new auth to 50:eb:f6:a8:07:b1
[ 6297.987526] wlp0s20f3: authenticate with 50:eb:f6:a8:07:b1
[ 6297.987539] wlp0s20f3: 80 MHz not supported, disabling VHT
[ 6297.989343] wlp0s20f3: send auth to 50:eb:f6:a8:07:b1 (try 1/3)
[ 6298.017499] wlp0s20f3: authenticated
[ 6298.024264] wlp0s20f3: associate with 50:eb:f6:a8:07:b1 (try 1/3)
[ 6298.029841] wlp0s20f3: RX ReassocResp from 50:eb:f6:a8:07:b1 (capab=0x1411 status=0 aid=23)
[ 6298.037924] wlp0s20f3: associated
[ 6298.060593] wlp0s20f3: deauthenticated from 50:eb:f6:a8:07:b1 (Reason: 7=CLASS3_FRAME_FROM_NONASSOC_STA)
modinfo iwlwifi | more
filename: /lib/modules/6.2.0-39-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license: GPL
parm: swcrypto:using crypto in software (default 0 [hardware]) (int)
parm: 11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm: amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K (16K buffers) 4: 2K (default 0) (int)
parm: fw_restart:restart firmware in case of error (default true) (bool)
parm: nvm_file:NVM file name (charp)
parm: uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm: enable_ini:0:disable, 1-15:FW_DBG_PRESET Values, 16:enabled without preset value defined,Debug INI TLV FW debug infrastructure (default: 16)
parm: bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm: led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm: power_save:enable WiFi power management (default: disable) (bool)
parm: power_level:default power save level (range from 1 - 5, default: 1) (int)
parm: disable_11ac:Disable VHT capabilities (default: false) (bool)
parm: remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
parm: disable_11ax:Disable HE capabilities (default: false) (bool)
parm: disable_11be:Disable EHT capabilities (default: false) (bool)
