Wireless
8515 討論
Intel driver for Samsung Quick Share
ksardy
初學者
32,186 檢視
Info from Microsoft Store for the Samsung Quick Share App:
Mit Quick Share kannst du schnell und einfach verschiedene Inhalte wie Fotos, Videos und Dokumente mit anderen teilen.
Support-Spezifikationen
• Betriebssystem: Windows 10 Version 2004 (Seriennummer 19041) oder höher
• Bluetooth-Treiber: (Intel) Version 22.50.02 oder höher
• WLAN-Treiber: (Intel) Version 22.50.07 oder höher
I cannot find these 2 driver Versions on the Intel download driver page
Many thanks in advance for your help
0 積分
1 解決方案
n_scott_pearson
超級使用者
3,460 檢視
The Wireless-AC 8265 adapter has been discontinued by Intel and the driver that you have (20.70.32.1) is the final version that will be made available. If you are looking for capabilities (including bug fixes) beyond those provided by this final driver, then you are out of luck. Your only option, if replacement of the adapter is supported in your laptop (i.e., is a socketed component), is to upgrade to a newer, more capable wireless adapter. Many people have successfully replaced the Wireless-AC 8265 adapter with the Wireless-AX AX200 (WiFi 6) or Wireless-AX AX210 (WiFi 6e) adapters.
Hope this helps,
在原始文章中檢視解決方案
9 回應
AlHill
超級使用者
32,181 檢視
First, you need to update Windows which is more the three years out of date.
Then, so the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
ksardy
初學者
32,069 檢視
Many thanks for your reply:
Edition Windows 11 Home
Version 22H2
Installiert am ‎25.‎09.‎2022
Betriebssystembuild 22621.1928
Leistung Windows Feature Experience Pack 1000.22644.1000.0
incl. all latest updates
as wished the Intel SSU-report in annex
DeividA_Intel
員工
31,894 檢視
Hello ksardy,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Dual Band Wireless-AC 3165.
Based on your wireless adapter, the latest driver version would be "20.100.9.8" for Bluetooth and "19.51.40.1" for Wi-Fi. You can use the following links to install the drivers:
If the app does not work with the latest Intel drivers, I recommend you to get in contact with the app developer to confirm if it is compatible with the Intel® Dual Band Wireless-AC 3165 and with Dell to get the proper drivers for their laptop.
If you have any questions, just let me know.
Deivid A.
Jaimon
初學者
3,486 檢視
Hey quick share is saying upgade your wifi driver it its showing its the latest
this is the one my lap have
Intel(R) Dual Band Wireless-AC 8265
the driver is at 20.70.32.1
so wht should i doo?
ksardy
初學者
31,765 檢視
Thank you for the tech-support.
As recommended, I first uninstalled the existing drivers and performed a clean installation. Unfortunately, these new drivers do not work either. But it's not so important to me. I will wait for Win 12, maybe the Samsung app will work in the new Win version.
Thank you so much
DeividA_Intel
員工
31,745 檢視
Hello ksardy,
Thanks for your response. Based on the information provided, Samsung Quick Share requires Bluetooth version 22.50.02 and your Intel® Dual Band Wireless-AC 3165 latest Bluetooth version is 19.51.40.1. This could mean that your system might not meet the minimum requirements, I recommend you check with the app developer to confirm if it can work with your laptop.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
usamakamboh
初學者
18,295 檢視
same issue
n_scott_pearson
超級使用者
3,461 檢視
Hope this helps,
ksardy
初學者
3,331 檢視
Danke für die Info. Seitdem habe ich mein Betriebssystem auf Windows 11 und mein Telefon auf Android 14 aktualisiert, und Quick Share funktioniert jetzt über Smartphone Link.
回覆
