Wireless
8658 Discussions
Intel wifi 6E AX211 stuck on 802.11a mode
Gonzalo33
I have a new Dell inspiron 16 plus and I started to notice slow internet speeds. I performed a speed test and I'm getting 20Mbps.
Other computers and phones in my network seems to be running at normal speeds (200Mbps+). I run the command "netsh wlan show interfaces" in cmd and this is the output
    Description            : Intel(R) Wi-Fi 6E AX211 160MHz
    GUID                   : 0285321a-d8d3-42b3-9f2e-******
    Physical address       : 28:****
    Interface type         : Primary
    State                  : connected
    SSID                   : NETGEAR*****
    BSSID                  : 08:****
    Network type           : Infrastructure
    Radio type             : 802.11a
    Authentication         : WPA2-Personal
    Cipher                 : CCMP
    Connection mode        : Auto Connect
    Band                   : 5 GHz
    Channel                : 153
    Receive rate (Mbps)    : 48
    Transmit rate (Mbps)   : 54
    Signal                 : 82%
    Profile                : NETGEAR7****
    Hosted network status  : Not available
My router (Netgear R6700V3) supports 2.4Ghz b/g/n and 5Ghz a/n/ac.
I tried configuring the driver parameters accordingly
802.11a/b/g Wireless Mode = 5. Dual Band 802.11a/b/g
and
802.11n/ac/ax Wireless Mode = 802.11ac
But I still get the same 805.11a (I tried other combinations for the driver parameters and I still get the same)
I also tried uninstalling the drivers, updating to last version, etc... Nothing seems to work.
DeividA_Intel
Hello Gonzalo33,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Wi-Fi 6E AX211 (Gig+).
1. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
2. Is the Bluetooth working?
3. Did you notice the issue after a system update? When did the issue start?
4. Does the issue with the laptop happen with a different network?
5. What is the operating system, as well as the version and build?
6. Do you see any errors in the device manager?
Deivid A.
Gonzalo33
I fixed the issue. For anyone having similar issues you have to activate WMM inside your router settings (usually under QoS setup or similar)
pakrat
I know it's over a year later, but I've been fighting this issue for some time and your post helped me solve the problem.
Thanks!
DeividA_Intel
Hello Gonzalo33,
Thanks for the confirmation. I am glad to know that you fix the issue by activating WMM inside the router settings
I will proceed to close this thread, however, you can open a new one in case you need further support or if you face any issues with our products.
Deivid A.
