Wireless
8871 Discussions
Killer Performance Suite driver download infected
hammerrada
Norton  360 Has flagged and quarantined this driver update showing it is infected with Malware.
DownloadKillerPerformanceSuite_40.25.905.1721_Win10-11x64.exe
  • Windows 11 Family*, Windows 10, 64-bit*
  • Size: 147.9 MB
  • SHA256: 44F3CF1C8E25B6A6823915F2BE1E19DAEC23D07B51BF1E482FA08631F682284
Description:
This download record installs Wi-Fi, Ethernet drivers and Killer Software for the Intel® Killer™ products.
Version: 40.25.905 Release date: September 25, 2025 Size: 147.92 MB
hammerrada
Today, Sept 30th, the Intel driver update assistant installed an uninfected driver update.
JeanetteC_Intel
Hello hammerrada,
For your safety, only download drivers from:
To help check on this, please provide the following:
1) Based on the information you shared, please confirm that the flagged driver was downloaded from this link.
  • If this is correct, Norton's malware detection is likely a false positive. Since legitimate drivers from official pages typically don't contain malware, I recommend contacting Norton support to report this incorrect detection and get clarification on the alert.
2) Are you having wireless problems the reason why did you need this application? If yes, briefly discuss the issue you're having with so I can help further.
3) Please also share your system configuration so I can check and provide you with an accurate fix. Kindly download the Intel® System Support Utility (SSU.exe)
  • Check "Everything"
  • Click "Scan" then "Next"
  • Click "Save" and attach the file here
JeanetteC.
hammerrada
JeanetteC_Intel
Hello hammerrada,
Thank you for the update! I'm glad to hear that the Intel Driver & Support Assistant successfully installed a clean driver update on September 30th. This validates that the previous Norton detection was indeed a false positive.
Since the issue has been resolved, I'll close this thread now. If you encounter any future driver or system issues, please feel free to create a new post in Intel Communities.
Thank you for using Intel Communities!
Sincerely,
JeanetteC.
