Wireless
8846 Discussions
Killer WiFi 6 AX1650i driver error
davidcoffey
I am on Windows 11 Home 24H2.   After the a recent upgrade my system will no longer connect to the 5ghz wireless network whle the 2.4 ghz wireless still works.     I have installed/reinstalled the killer drivers to no avail.   Guidance needed to get the 5 ghz wireless working again.
Have tried manually installing the latest killer drivers, tried a rollback.....  nothing seems to address the issue.
DarwinC_Intel
Hi davidcoffey,
Apologies for the inconvenience that may have cause regarding the issue you are having into you Wireless Wi-Fi connection. For us to further help you kindly provide the following information.
  • Is there any error message on the device manager (If yes could you send us sample image):
  • Is this a laptop or desktop system? (If laptop could you send us exact model):
  • Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
  • Have you checked if this issue happens on different networks?
  • May I know the recent upgrade you've done into the system?
  • May I know where did you downloaded the driver and how did you manually install it?
You can find the download link here:
      1. Download and launch SSU.exe.
      2. Check the box for "Everything."
      3. Click "Scan."
      4. When the scanning is complete, click "Next."
      5. Click "Save."
      6. Please send the saved file to us.
That information would greatly help us understand the issue.
Darwin C.
davidcoffey
Device manager shows the following error:
Device settings for PCI\VEN_8086&DEV_06F0&SUBSYS_16521A56&REV_00\3&11583659&0&A3 were not migrated from previous OS installation due to partial or ambiguous device match.
Last Device Instance ID: BTH\MS_BTHPAN\6&1b9d5375&0&2
Class GUID: {4d36e972-e325-11ce-bfc1-08002be10318}
Location Path:
Migration Rank: 0xF000FFFFFFFFF122
Present: false
Status: 0xC0000719
Desktop or Laptop?  Desktop system.  Dell XPS 8940
Original adapter? Yes
Checked other networks?  No, I have not.  All the other 5gig devices on my home network work as expected and show no issues.  This is the only device that cannot connect to the 5gig network.
Recent upgrade?   Win 11 24H2 on 1/31/2025 but this was after this problem showed up.   There are 3 cumulative updates: 2025-01 on 2/27/2025 (after the issue showed up) and 2025-02 on 211/2025 and then 2024-12 on 12/17/2024, newest to oldest.   Could be one of these two....    I don’t have a specific record when it showed up because my system defaulted to the 2.4gig network and it was not noticed immediately.
Drivers?  I have installed both the Intel supplied driver set and then the Dell supplied driver.   Prior to the install of the Intel driver set I completely deleted and uninstalled the Killer app and all services.  KillerPerformanceSuite_36.24.12162_Win10-11x64.exe (Intel I think) and then Killer-BE1750-AX1690-AX1675-AX1650-and-Intel-BE202-BE201-BE200-AX411-AX211-AX210-AX201-AX200-9560-9462-9260_P766C_WIN64_23.90.0.8_A51_03.EXE  (Dell)
Additional Comments:  My SSIDs are mercury-24g and mercury-5g    Only mercury-24g shows active in the report.   The 5gig radio cannot connect to my network, hence it is not in use and not shown.
DarwinC_Intel
Hi davidcoffey,
Thank you for providing detailed information. Allow me to further investigate this matter on our end and coordinate internally. I will thoroughly look into this issue and replicate it in our lab to isolate the problem or identify any needed improvements and developments on the drivers.
While there is no ETA for when an update will be posted, please rest assured that I will work diligently on your case. I will provide an update to you as soon as possible once our investigation is complete. Your patience is greatly appreciated, and we aim to ensure a better user experience for you.
Darwin C.
DarwinC_Intel
Hi davidcoffey,
As per discussion with the team, we will be releasing aa new Wireless driver by Tomorrow and as per our Intel Engineers they suggest using it once it was available to check if the issue will persist on the new Wireless Driver.
If you have any questions or clarifications kindly let us know so that we could further assists you.
Darwin C.
DarwinC_Intel
Hi davidcoffey,
I hope you're doing well! I was wondering if you've had a chance to look over the Information I sent you. Whenever you have a moment, could you let me know your thoughts? It would really help us figure out the best way to move forward and tackle this issue together.
Darwin C.
davidcoffey
I am aware that an updated driver has been released and I  will be happy to install it.   I have been traveling for the last week on family business that is why I have not responded.   I will install it this week and respond to you.  Will it find it on the intel website in the downloads section?
David
DarwinC_Intel
Hi davidcoffey,
I hope this message finds you well. Thank you for reaching out and informing us about your recent travels. We understand that personal commitments can sometimes delay responses, and we appreciate your communication. To answer your question, yes, you can find the updated driver in the downloads section of the Intel website. Please follow the link provided above to access the latest version. Intel® Killer™ Performance Suite download page.
Once you have installed the driver, we would appreciate your feedback on its performance. Should you have any questions or require further assistance, please do not hesitate to contact us.
Thank you for your continued support and understanding.
Darwin C.
davidcoffey
I have installed the rcent driver, dated 3/4/2025.   There is no change in the behaviour.   I complted the automated install, rebooted my computer and the 5gig network was visible.   I switched the connection, supplied the password and the message dispoayed was "Unable to connect to the network.
No improvement.
David Coffey
DarwinC_Intel
Hi davidcoffey,
Thank you for the information. I will investigate the issue further and coordinate internally. We will attempt to replicate the problem in our lab to identify the cause or any necessary driver improvements. Although I can't provide a timeline for updates, I assure you that I am working diligently on this case. I will update you as soon as our investigation is complete. Your patience is appreciated as we strive to enhance your user experience.
Darwin C.
DarwinC_Intel
Hi davidcoffey,
I hope you're doing well. Based on our investigation, we recommend performing a clean installation of the operating system. This will simplify the troubleshooting process since the system is new. For assistance with the product key, please reach out to the laptop manufacturer.
Please note that we will not be monitoring this thread further, as the next steps will be handled by your laptop manufacturer. We are closing your case now. If you have any new questions or need further assistance, please submit a new ticket, and we will be glad to help.
Darwin C.
