Wireless
8657 Diskussionen
Killer intelligence Center issues
KILLA
Einsteiger
7.041Aufrufe
Few things wrong with the killer intelligence center
1.  Game fast- "auto enable when game detected" doesn't work properly. When you reboot computer it disables the feature.  You have to keep checking it manually.
2. Extreme game mode - same issue as "game fast"
reinstalled drivers same issue
1. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?  CHANGED MY ADAPTER TO THIS ONE  AX1650X
2. Is the issue present with both drivers ? NEWEST DRIVERS
3. Did you notice the issue out of the box?  YES
4. What is the operating system version and built installed? WIN 10 BUILD 19045
16 Antworten
DeividA_Intel
Mitarbeiter
6.994Aufrufe
Hello KILLA,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Killer™ Wi-Fi 6 AX1650.
1. Are you using a laptop or desktop computer?
2. What is the brand and model name of your laptop or motherboard (if desktop)?
3. Do you have any issues with Bluetooth or Wi-Fi?
Also, bear in mind that integrations (replacing original components) may cause unexpected issues. You can check more information at the following link:
Deivid A.
KILLA
Einsteiger
6.970Aufrufe
Not having issues with the card. Please see pictures. Having program issues that killer uses. "killer intelligence center" Needs to be fixed.
DeividA_Intel
Mitarbeiter
6.981Aufrufe
Hello KILLA,
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
DeividA_Intel
Mitarbeiter
6.927Aufrufe
Hello KILLA,
Thanks for your response. In order to investigate this issue, I will need the following:
Deivid A.
DeividA_Intel
Mitarbeiter
6.904Aufrufe
Hello KILLA,
Deivid A.
KILLA
Einsteiger
6.895Aufrufe
DeividA_Intel
Mitarbeiter
6.881Aufrufe
Hello KILLA,
Thanks for your response. Before we continue further, I would like to confirm if by "ya" you meant that you ran the Intel® SSU and collected the report.
If so, please attached the report to your next response.
Deivid A.
KILLA
Einsteiger
6.875Aufrufe
I can do so this week. So don't close this thread please. Would like to get this issue fixed.
KILLA
Einsteiger
6.831Aufrufe
Here ya go, thank you
DeividA_Intel
Mitarbeiter
6.768Aufrufe
Hello KILLA,
Thank you for the information provided
Deivid A.
KILLA
Einsteiger
6.683Aufrufe
Also the killer intelligence center program is buggy/ lags when switching tabs or dragging the window.
Also driver version are incorrect.. site shows 22.200.0.6. I have 22.200.2.1 installed which is from this intel page. See picture side by side.
DeividA_Intel
Mitarbeiter
6.609Aufrufe
Hello KILLA,
Thanks for your patience. Based on the investigation performed, I would like to let you know that it is intended that this feature has to be manually selected again. This is done in case a user forgets that they have it toggled and it affects their computer without them knowing.
Please let me know if you have any other questions.
Deivid A.
KILLA
Einsteiger
6.560Aufrufe
Thats why there is a auto detect games. Which doesn't work properly..
And when will there be a update to fix the buggy program?
DeividA_Intel
Mitarbeiter
6.577Aufrufe
Hello KILLA,
Deivid A.
DeividA_Intel
Mitarbeiter
6.523Aufrufe
Hello KILLA,
Thanks for your response. In this case, this behavior is not a "bug" since the tool is working as expected. As a friendly reminder, this behavior is present in case a user forgets that they have it toggled and it affects their computer without them knowing.
Intel does not have plans to change the behavior of these options for now.
Deivid A.
KILLA
Einsteiger
5.945Aufrufe
all is good. i went to ax210 no issues anymore.
Antworten
