Wireless
8653 Discussions
Killer performance suite fail installation error code 1603
LAPARAMOR
novice here...error code 1603!
Steven_Intel
Hello LAPARAMOR,
I am sorry you are having issues with the Killer Performance Suite, I will be glad to assist.
Please download the Intel® SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
Steven G.
LAPARAMOR
Hello Steven_Intel,        I don't know how to attach the file to my reply.  Will ask someone for help..THANK YOU for your response...
LAPARAMOR
Hello Steve...file in reply...I hope!...THANKS
LAPARAMOR
Hi Steve....
kdawg
Hi Steven any help would be appreciated.
DanaMSteiner
I need help as well, same error code. Here is save from my pc
VincePura
Hi steven! file in reply!
Help would be appreciated!
R0NTS4
Thiem
ScottWrobel
Steven,
I just joined the channel and am encountering the same issue.  I turned off my virus software and tried to install the update but still get the error.  I downloaded the scan software and am attaching the results text file.  Can you check my setup and let me know what is causing the error?  Thanks.
VinceP1
I fixed using Microsoft troubleshooter tool, do a search on killer suite fix using tool, don't remember where I found instructions, it's article I'd is 000058907.
YivanArchi
Same issue Steven, thanks in advance!
Steven_Intel
I appreciate your response.
After saving the SSU file, you can attach it to your reply by clicking on the Reply button, and then you can either drag and drop the file in the upload box or you can click on browse to select the file.
Steven G.
Steven_Intel
Many thanks for your response.
Is the error occurring when downloading it from the Intel Driver & Support Assistant?
Please try downloading the Intel® Killer™ Performance Suite manually from the Download Center (https://www.intel.com/content/www/us/en/download/19779/intel-killer-performance-suite.html) if you have not already.
Let me know of the outcome.
Steven G.
Brendt
I have the same situation above, but in my installed programs is the "Killer Ethernet Performance Driver Suite UWD" by Rivet Labs, ver. 2.4.1541.  It seems like this may be a customized version of the Intel Killer Ethernet Performance Driver.
However, it is unclear if this should be uninstalled so the new Intel Killer Suite can be installed instead. Any chance that you can clarify?
Brendt
LAPARAMOR
Hi BRENDT, I uninstalled the KILLER ETHERNET PERFORMANCE DRIVER SUITE UWD. I did a restart. Installed the KILLER PERFORMANCE SUITE UWD.  I did the uninstalled from the control panel...hope this is helpful....
LAPARAMOR
Hi BRENDT, I also had the KILLER ETHERNET PERFORMANCE DRIVER SUITE UWD in my installed programs....
Steven_Intel
We would like to know if you were you able to check the previous post.
Steven G.
LAPARAMOR
Hello Stteven...I got the following message when downloading from the Download Center: Killer Performance Driver Suite UWD cannot be installed with Killer Ethernet Performance Suite...
deNja2k
hello Steven G.
i have same problem with update
Installation failed with error code 1603)
