Wireless
Avisos
8575 Discusiones
Killer performance suite fail installation error code 1603
LAPARAMOR
Novato
33.505 Vistas
novice here...error code 1603!
Etiquetas (1)
0 kudos
51 Respuestas
Steven_Intel
Moderador
22.239 Vistas
Hello LAPARAMOR,
I am sorry you are having issues with the Killer Performance Suite, I will be glad to assist.
Please download the Intel® SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
Steven G.
LAPARAMOR
Novato
22.183 Vistas
Hello Steven_Intel,        I don't know how to attach the file to my reply.  Will ask someone for help..THANK YOU for your response...
LAPARAMOR
Novato
22.127 Vistas
Hello Steve...file in reply...I hope!...THANKS
LAPARAMOR
Novato
22.111 Vistas
Hi Steve....
kdawg
Principiante
17.619 Vistas
Hi Steven any help would be appreciated.
DanaMSteiner
Principiante
16.251 Vistas
I need help as well, same error code. Here is save from my pc
VincePura
Principiante
15.849 Vistas
Hi steven! file in reply!
Help would be appreciated!
R0NTS4
Principiante
14.894 Vistas
Hello Steven
Thiem
Principiante
9.809 Vistas
ScottWrobel
Principiante
4.590 Vistas
Steven,
I just joined the channel and am encountering the same issue.  I turned off my virus software and tried to install the update but still get the error.  I downloaded the scan software and am attaching the results text file.  Can you check my setup and let me know what is causing the error?  Thanks.
VinceP1
Principiante
4.565 Vistas
I fixed using Microsoft troubleshooter tool, do a search on killer suite fix using tool, don't remember where I found instructions, it's article I'd is 000058907.
YivanArchi
Principiante
3.268 Vistas
Same issue Steven, thanks in advance!
Steven_Intel
Moderador
22.162 Vistas
I appreciate your response.
After saving the SSU file, you can attach it to your reply by clicking on the Reply button, and then you can either drag and drop the file in the upload box or you can click on browse to select the file.
Steven G.
Steven_Intel
Moderador
22.052 Vistas
Many thanks for your response.
Is the error occurring when downloading it from the Intel Driver & Support Assistant?
Please try downloading the Intel® Killer™ Performance Suite manually from the Download Center (https://www.intel.com/content/www/us/en/download/19779/intel-killer-performance-suite.html) if you have not already.
Let me know of the outcome.
Steven G.
Brendt
Principiante
20.039 Vistas
I have the same situation above, but in my installed programs is the "Killer Ethernet Performance Driver Suite UWD" by Rivet Labs, ver. 2.4.1541.  It seems like this may be a customized version of the Intel Killer Ethernet Performance Driver.
However, it is unclear if this should be uninstalled so the new Intel Killer Suite can be installed instead. Any chance that you can clarify?
Brendt
LAPARAMOR
Novato
20.018 Vistas
Hi BRENDT, I uninstalled the KILLER ETHERNET PERFORMANCE DRIVER SUITE UWD. I did a restart. Installed the KILLER PERFORMANCE SUITE UWD.  I did the uninstalled from the control panel...hope this is helpful....
LAPARAMOR
Novato
20.018 Vistas
Hi BRENDT, I also had the KILLER ETHERNET PERFORMANCE DRIVER SUITE UWD in my installed programs....
Steven_Intel
Moderador
22.015 Vistas
We would like to know if you were you able to check the previous post.
Steven G.
LAPARAMOR
Novato
21.953 Vistas
Hello Stteven...I got the following message when downloading from the Download Center: Killer Performance Driver Suite UWD cannot be installed with Killer Ethernet Performance Suite...
deNja2k
Principiante
16.878 Vistas
hello Steven G.
i have same problem with update
Installation failed with error code 1603)
Responder
