- « Previous
- Next »
Hello DEIVID A, I type Killer Performance Suite in the Apps&feature and I get a No FEATURE FOUND....
Hello LAPARAMOR,
Thanks for the confirmation, I will check if there are any additional steps that we can follow in order to help you further. As soon as I have any details I will get back to you.
Deivid A.
Hello LAPARAMOR,
Thanks for your patience. In this case, you can try the clean install from the device manager even though it does not show up in apps and features.
You may troubleshoot by avoiding step "3. Uninstall the Intel Killer Performance Suite manually", if you get any error or warning please take a picture and send it.
Also, can you please take a picture of the error received while performing the "Killer Performance Driver Suite UWD Cannot Be Installed with Killer Ethernet Performance Suite" steps?
Deivid A.
Hi DEIVID A, Working on the fix...I'll get back to you. Thank You...
Hello LAPARAMOR,
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
Hello DEIVID A,
I uninstall the Killer Ethernet Performance Driver Suite UWD in the control panel. Did a restart and install the Killer Performance Suite UWD. This fix was suggested before but I was missing something in the process. Sorry about that...Thank You for your support and patience. Happy beginner here...
Hello LAPARAMOR,
Thanks for your response. Before I continue further, can you confirm if the issue is fixed? If not, please let me know.
Deivid A.
Hello DEIVID A,
Killer Performance Suite fail installation error code 1603...issue is fixed. I can confirm this to you and was able to install more updates after the fix...L A PARAMOR-beginner...
Hello LAPARAMOR,
Thanks for the confirmation. I am glad to know that you have fixed the issue with the steps provided.
I will proceed to close this thread, however, you can open a new one in case you need further support or if you face any issues with our products.
Deivid A.
I read the whole string but I am unable to resolve this issue.
1) I attempted to install the available update i.e. Intel Killer Performance Suite and got an error
see attached file SW_Update_Error.jpg.
2) Uninstall "Killer Ethernet Performace Driver Suite UWD 2.0.1167" through Apps & Features. Installation starts then cancel itself at the end.
I tried to "Manually download and install the latest driver but I got the same error that the two suites can not coexist.
Please advise.
Soren
I get error code 1714 when trying to install from a direct download and 1603 when installing by auto detect. I cannot uninstall Killer Suite as that doesn't work in order to start all over.
Did you managed to solve the issue?
- « Previous
- Next »
