This forum is for Intel NUCs only, wrong forum...
The support in this forum is in English only but there is option to translate it.
Explain better with more details the issue and provide the following
1-SSU report, save the file (txt) and attach it to your reply:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
2- The wireless card came from factory with your laptop or did you add it
3- How long it worked? Is your laptop new? Was there any hardware/Windows update?
Hello jmiri
Thank you for posting in the Intel Community.
1- Can you provide me more details about the issue that you are having?
2- Do you have any error code on Windows® device manager?
3- Please attach to this thread the TXT file the Intel® System Support Utility will generate: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Steps to save the report:
1- Run the utility.
2- Click on “Scan” to get the scanned system.
3- Once the scan is complete click on “next”.
4- Use the “save” option, save the report to your desktop.
5- To attach a file, you must click the “Attach” option on the bottom left-hand corner of the response box.
We only provide support in English and we use a translation tool for your post.
Leonardo C.
A Contingent Worker at Intel
Hello jmiri
Have you been able to collect the information requested?
Leonardo C.
Hello jmiri
I would recommend following the steps for the error codes that you are having on device manager:
Error code 10:
Code 10 in Device Manager for Bluetooth or Wireless device
Error code 43:
Error codes in Device Manager in Windows
In addition, you can contact Microsoft® support for additional steps to take on the error codes, in case none of these steps solve the issue I would recommend contacting the ASUS* support for warranty/replacement.
Leonardo C.
Merci beaucoup pour votre aide.
J'ai essayé la fonction repair de l'application intel Bluetooth Wireless. J'ai également stoppé les mises à jour automatiques pour un mois. J'ai supprimé aussi l'application "intel pros wireless"
Cela a fonctionné. Depuis 2 jours, le wifi tient.
Je ne sais pas vraiment pourquoi mais cela fonctionne.
Merci encore.
Cordialement
JPM
Hello jmiri
Thank you for sharing the updates, I am glad to know that the system is working fine
Leonardo C.
