Wireless
8721 Discussions
MSI Z590I UNIFY Thunderbolt and wifi issues
coner
I connected the EGPU via Thunderbolt on the motherboard.
However, the WIFI stopped working due to an unknown problem.
Power off the EGPU and the WIFI will work again.
I use Windows 10 and I used the Thunderbolt driver from the MSI website.
I can't quite figure out the cause. Help
DeividA_Intel
Hello coner,
Thank you for posting on the Intel® communities. I understand you are having issues with the Intel wireless adapter.
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
2. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
3. Do you see any error code at the device manager?
4. Did the adapter work with another graphics card connected?
5. Are you using the antennas?
6. Have you checked with MSI to confirm that the motherboard support is compatible with your graphics card?
Deivid A.
DeividA_Intel
Hello coner,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello coner,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
