Wireless
8659 Discussions
Missing firmware for Intel(R) Wi-Fi 6 AX201
zpp1
I just got a new Laptop (Redmi Book 15 pro 2025) with Intel Wi-Fi adapter AX201.  It does not work with the newest Linux kernel.
Here is output of "sudo dmesg | grep iwlwifi"
[ 4.734665] iwlwifi 0000:00:14.3: Detected crf-id 0x1300504, cnv-id 0x80930 wfpm id 0x80005b30
[ 4.734672] iwlwifi 0000:00:14.3: PCI dev 7740/0274, rev=0x461, rfid=0x10a100
[ 4.734674] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz
[ 4.734927] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-bz-b0-hr-b0-94.ucode failed with error -2
[ 4.735067] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-bz-b0-hr-b0-93.ucode failed with error -2
[ 4.735082] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-bz-b0-hr-b0-92.ucode failed with error -2
[ 4.735083] iwlwifi 0000:00:14.3: no suitable firmware found!
On the 15th, the firmware was added, but it is iwlwifi-bz-b0-hr-b0-96.ucode , which is too high.
May I ask when you're going to release the firmware for these devices?
Mike_Intel
Hello zpp1,
Thank you for the update.
Kindly refer to the following links for supported firmware: h​ttps://wireless.wiki.kernel.org/en/users/drivers/iwlwifi ​ or https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/ for the latest versions.
If the steps above do not identify or resolve the issue, please proceed with the following:
Type: # dmesg | grep ASSERT​
If the output is empty, kindly refer to this link: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi/debugging to extract dmesg and trace-cmd.
If the output contains values, please also collect the firmware dump from the wiki and kindly send it back to me for further checking.
Michael L.
Mike_Intel
Hello zpp1,
  1. What is the original OS of your laptop?
  2. What is the exact Linux OS that you are using right now?
  3. Can you share the screenshot of the error of there is one?
  4. Are you having connectivity issues right now?
Michael L.
zpp1
Hello Mike_Intel,
Actually, you only need to provide:
[4.734927] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-bz-b0-hr-b0-94. ucode failed with error -2
These three firmware issues can be easily resolved.
zpp1
zpp1
你好,Mike_Intel,
1.The original operating system was Windows 11.
2.The Linux operating system currently in use is Fedora41, 6.13.5-200.fc41.x86_64.
3.This is an incorrect screenshot:截图 2025-05-22 10-51-15.png
4.Now my computer cannot recognize the WiFi firmware, resulting in a lack of wireless network identification on the computer.
I hope you can help me solve the problem!
JeanetteC_Intel
Hello zpp1,
Thank you for providing the requested information. I truly appreciate you providing us the information we need to properly investigate this issue. I just hope to clarify some more information, so we can fully isolate the root cause of the issue. Please help share the following:
  1. Can you confirm that the AX201 wireless adapter was properly detected by the system device and works fine with Windows OS?
  2. Please confirm if this is the actual system device that you have. https://www.mi.com/redmibook/pro15/specs
 I hope to hear from you so I may continue with the investigation.
JeanetteC.
zpp1
Hello JeanetteC
Thank you for your follow-up. Regarding the information you need to confirm, my response is as follows:
AX201 adapter status confirmation:
The device has been correctly recognized by the Windows 11 system (Device Manager shows "Intel (R) Wi Fi 6 AX201 160MHz")
Basic functions are normal (able to scan Wi Fi networks and connect).
Equipment model correction:
The actual device is Redmi Book Pro 14 2025 model (correct specification page: https://www.mi.com/prod/redmi-books/14-pro-2025/specs)Different specifications from the previously mistakenly sent Redmi Book Pro 15.
Looking forward to your further guidance.
zpp1.
JeanetteC_Intel
Hello zpp1,
Thank you for providing the requested information. Let me further check on this internally for now and I will post an update, once it is available.
JeanetteC.
zpp1
Hello JeanetteC
Thank you!Would like to be informed when the firmware is released.
zpp1
Mike_Intel
Hello zpp1,
Michael L.
zpp1
Dear Michael,
Thank you for your prompt support and detailed guidance. The issue has been successfully resolved after following the recommended steps.
I appreciate your assistance and the resources you provided.
If I encounter any further issues, I will be sure to reach out. Thanks again for your expertise!
zpp1
momo123
你好,请问官方提供给您的固件是iwlwifi‑bz‑b0‑hr‑b0‑92.ucode吗?我怎么没有找到呢。我目前缺少的固件是90-92
zpp1
你好,他们提供的是96和98,具体步骤你可以查看官方给出的解决方案:community.intel.com/t5/Wireless/Missing-firmware-for-Intel-R-Wi-Fi-6-AX201/m-p/1692905#M60106
Mike_Intel
Hello zpp1,
Appreciate the update and I am glad that the issue is now fixed.
Since your system is working fine now, I need to close this inquiry.
Michael L.
