Wireless
공지
8581 토론
My WiFi not available during installation
직원
5,293 조회수
I am using Dell e6400 with Intel wifi link 5300 AGN with Windows 7 64bit. I downloaded the latest ProSet. I uninstalled the old ProSet. When I install the new version the option for My Wifi is not available. I see only Administrator toolkit and WMI. Any idea on what could be the reason?
0 포인트
24 응답
직원
2,385 조회수
is the Proset software from Intel or Dell? You might want to check with Dell the Proset software for the notebook.
0 포인트
직원
2,385 조회수
I've tried both - still don't see My WiFi as an option.
It drieves me crazy since my collegue with the same computer doesn't have this problem.
0 포인트
직원
2,385 조회수
is this the proset softwaer you downloaded? just to double check
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19149&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19149&lang=eng
Try check and compare the software installed on your notebook with your colleaque's see if ther is any other software that might causing this problem.
0 포인트
직원
2,385 조회수
just proceed with the installation. mwt will install automatically.
0 포인트
직원
2,385 조회수
It's very difficult to guess which software can cause such problems.
And yes, I installed this software several times (different versions: Dell, Intel) and the "My WiFi" software did not install. Or I didn't find a way to find the exe file to start it.
0 포인트
직원
2,385 조회수
did you check if mwt is in proset/wireless program? in win 7, mwt is installed by default.
직원
2,385 조회수
What is 'mwt' and how to check it?
0 포인트
직원
2,385 조회수
MWT is my wifi technology. go to start - programs - look for Intel Proset/Wiress software, MWT should be inside this folder.
0 포인트
직원
2,385 조회수
It's not there - only Administrator tools like those on the list on the setup screen.
0 포인트
Ilene_K_Intel
직원
2,385 조회수
My WiFi Technology should be installed by default. Here's how to find it:
Start Menu
Select All Programs (Windows 7)
Select Intel PROSet Wireless
Select Intel My WiFi Technology
You need to have Intel® PROSet/Wireless WiFi Software installed. You can check this by going to http://www.intel.com/support/wireless/detect.htm http://www.intel.com/support/wireless/detect.htm. This tool will tell you if the software is installed and whether you need a software update.
Ilenek
Intel Customer Support
0 포인트
직원
2,385 조회수
During installation the Intel My WiFi Technology is not available in Setup window. Logically, after installation it is not available in the Start\Intel menu. My collegue has reinstalled Windows and he is facing the same problem. Are there any Windows\Security options that can prevent me from installing Intel My WiFi Technology?
0 포인트
직원
2,385 조회수
I'm facing the same problem. I have two laptops one with Intel N 6200 AGN and the other with with 5100 AGN.
I keep trying to install the ProSet utlity but it doesnt give me an option to install My WiFi (I know older ones used to work with Vista before I upgraded to Windows 7). After installation I don't see anything to do with MyWiFi in the start menu or the Intel ProSet start menu option.
Help anyone!!
0 포인트
직원
2,385 조회수
okay funny thing,
Laptop with 64 bit windows 7 and Intel Advanced N-6200 WiFi
- when I use the Wireless Advanced Enterprise Software 13.2.2010 I get an option to install Intel MyWiFi
- however if I use the ProSet Installer 13.2.1 or 13.1.1 I don't get any option for installing Intel MyWiFi.
Intel please fix the installers!!
0 포인트
직원
2,385 조회수
this is the closest i have got, im in the same situation however, when i install enterprise, the driver is not found! i've upgraded back to proset 14.0... now my wifi has disappeared????
0 포인트
직원
2,385 조회수
Yes, same results here, the Advanced Enterprise version is the only 13.5 installer which offers me MyWiFi, and there doesn't seem to be a 14.1 Advanced Enterprise (at least as of June 28, 2011). I too am confused as to why My WiFi doesn't show up on the consumer ProSet and Basic Enterprise versions (either 13.5 or 14.1) - when plenty of documentation suggests it should.
This is on a Centrino Ultimate 6300N - actually on two different ones - a generic and a Dell-specific version, no difference. Running Win7Pro x64.
Confused,
Richard
0 포인트
RKell3
새로운 기여자 I
2,385 조회수
Richard,
I installed this on my Dell Studio 1737 with Windows 7. The instructions were vague, so try the instructions I provided at...
http://en.community.dell.com/support-forums/network-internet-wireless/f/3324/p/19332852/19700096.aspx# 19700096 Installing My Wi-Fi Technology
It explaind what you have to do to install it.
Rick
0 포인트
직원
2,385 조회수
Thanks Rick, but the problem is the 13.5 installer's "Custom" screen offers My Wifi (which I have installed successfully) while the 14.1 installer's "Custom" screen does not. I fought 13.5 like mad until finding this thread and seeing that at least for my gear, ONLY the "Advanced Enterprise" version of the installer offers My WiFi for install. So I've been successful with the 13.5 Advanced Enterprise installer but cannot move to 14.1. 13.5 seems to have a LOT of issues with the adapter losing its mind and requiring one or more "Reset ProSet" operations - so I'm hoping desperately for an improvement in 14.1.
Richard
0 포인트
RKell3
새로운 기여자 I
2,385 조회수
Richard,
I used to own a 5100 AGN and currently I am using the 6200 AGN and do not have any issues. I have used these http://en.community.dell.com/wikis/networking_internet_wireless/recommended-wireless-router-settings.aspx Recommended Wireless Router Settings I use channel 11. Sometimes people with the connection issues have found that their antenna wires have come loose.
Version 13.4.0.0 worked well, also and might have what you're looking for.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19514&lang=eng&OSVersion=Windows%207%2C%2064-bit*&DownloadType=Software%20Applications Intel® PROSet/Wireless Software and Drivers for Windows 7 64-Bit Version 13.4.0.0
Rick
0 포인트
직원
2,385 조회수
Ok, so here's the final and real correct answer - after a couple of days on and off of sweating over VM installs, log file analysis, some pure guesswork and some pure luck!
The *installer* keeps a token noting that the My WiFi has been blocked at some point, and all future installers obey that (except 13.5 Advanced Enterprise it seems).
I've placed a commented .reg file on pastie (though it doesn't seem to have a type for .reg files) so you can download, rename to .reg, and run this:
http://pastie.org/2188560 http://pastie.org/2188560
which simply contains the following to delete the "errant" value.
REGEDIT4
; ReEnableIntelMyWiFiInstallOption.reg
; Restore the missing Intel My WiFi Technology install option
; in ProSet/Wireless versions 13.5 and 14.1.1 at least, maybe
; more.
; OEM installs (like Dell's) often block My WiFi, and even
; uninstalling them doesn't return the option to the generic
; drivers. This .REG file deletes the UpgradeCode preserved
; by the Windows Installer and obeyed by even the generic
; Intel install. This code appears to ONLY be present when
; My WiFi is blocked.
; YMMV and so on.
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes\4AC91165C6D69DE419A86CDFF452E910]
"FFBD57B19EA05A2416DB668FE78A4352"=-
After running this, I can happily install My Wifi!
HTH,
Richard
P.S. I don't know how to subscribe to threads here, but I'll check in occasionally for a while to see if anyone is NOT able to make this work for them!
0 포인트
직원
2,239 조회수
Hi Richard,
This totally nailed it! Thanx a thousand times. I think I'd never found this myself....
In my case it applies to a Dell Latitude E6520, i7-2720QM, HD Graphics/NVS4200M, Intel Centrino Ultimate-N 6300.
Now only have to buy a receiver.
0 포인트
응답
