Wireless
8624 Discussions
N 2230 and win 8.1, 'its taking longer than usual to connect to this network'
mjons
I don't know if this is a windows or driver error, but when i connect to my wireless the charm bar is stuck at 'its taking longer than usual to connect to this network' even though I'm connected. On the latest drivers from Windows update.
Have to point out I also have the drop out issue, wifi stops working sometimes while connected.
Jose_H_Intel1
Marjo, so I understand you are using the latest Windows* 8.1 drivers. If you are not using Intel® drivers or Intel® Proset then the issue is related to your operating system or Microsoft* driver and therefore you may contact them.
We will be releasing a compatible driver for Windows* 8.1.
You guys have 8.1 Drivers already, I've downloaded, tested them (someone here gave me the link because I couldn't find it myself, they aren't in the download list at least then), and he's right, the driver both loads really slow and a webpage will take like 10 seconds to load when normally it takes 1 second.
Something is wrong with your 8.1 drivers, let alone the dropping issue on all drivers.
Man, it's like you don't even know your own services.
mjons
The driver is 15.10.3.2, provided by Intel from windows update. I did try the previous driver and Intel software but same issue.
Jose_H_Intel1
Such driver is not yet publicly available since it has not been officially released. Please also note that Windows* 8.1 is still a preview at this time.
