Wireless
8652 Discussions
Netwaw16 Has determined that the network adapter is not functioning; adapter stopped working
Wifi7Guy
My ASUS TUF 17 laptop has been upgraded with Intel WiFi7 BE200 320Mhz network card. I have download and installed the latest driver (Windows® 10 and Windows 11* Wi-Fi package drivers 23.80.1 for the Intel® Wi-Fi 7/Wi-Fi 6E/Wi-Fi 6) from from https://www.intel.com/content/www/us/en/products/sku/230078/intel-wifi-7-be200/downloads.html
Upon startup of the laptop, network adapter does not function. In event viewer, Windows System log, there is an Event ID Error 5002 - 0000280001000000000000008A1300C0000000000000000000000000000000000000000000000000940000000600000004000000F2560100000000040F27000F16502A0016502A000000000042462C00 : Has determined that the network adapter is not functioning properly. Restarting the laptop does not help resolve the problem.
The network card is detected as seen below. More info on laptop spec below. The network card works fine on Ubuntu 24.04.1 LTS. Hope you can help advise. Thanks.
n_scott_pearson
Did you remember to completely uninstall the driver packages (Wireless and Bluetooth both) before upgrading the hardware? If not, you need to do a clean installation of the drivers. Here is my process for doing so:
  1. If you haven't already, download - but do not install just yet - the latest Bluetooth and Wireless driver packages for your adapter. Here are the current links for downloading these drivers: Wireless: https://www.intel.com/content/www/us/en/download/19351 and Bluetooth: https://www.intel.com/content/www/us/en/download/18649.
  2. Most important! Disable Internet access. Unplug Ethernet cable and/or disable wireless. Keep disabled until told to re-enable. Note: This Wireless disable *must* be of type that will persist (i.e. stay disabled) across reboots.
  3. From the Apps & Features applet, check for instances of Intel PROSet/Wireless Software and Intel Wireless Bluetooth. If none, skip forward to Step 6.
  4. Uninstall each instance of Intel PROSet/Wireless Software and/or Intel Wireless Bluetooth that is present. When prompted, choose to "Discard Settings".
  5. Manually reboot your computer, keeping Internet access disabled throughout.
  6. From the Device Manager applet, check the Network Adapters section for an entry for Intel WiFi 7 BE200 and check the Bluetooth section for an entry for Intel Wireless Bluetooth that has an Intel driver associated with it. If neither is the case, skip forward to Step 12.
  7. Right click on the entry for Intel WiFi 7 BE200 and select Uninstall Device. In the dialog that is then presented, choose to (checkmark) Delete the driver software for this device.
  8. Repeat step 7 until the option to Delete the driver software for this device is not offered (i.e., is greyed out).
  9. Right click on the entry for Intel Wireless Bluetooth and open its properties. If it has an Intel driver associated with it, then uninstall it, choosing to (checkmark) Delete the driver software for this device.
  10. Repeat step 9 until the option to Delete the driver software for this device is not offered (i.e., is greyed out).
  11. Go back to Step 5.
  12. Install the downloaded Bluetooth driver package you downloaded earlier (my rule: always install Bluetooth first).
  13. Install the downloaded Wireless driver package you downloaded earlier.
  14. Manually shutdown and reboot your computer.
  15. Reenable Internet access. Restore Ethernet cable and/or reenable wireless.
  16. Test.
Note that it sometimes takes multiple uninstall (and reboot) cycles to clean out the old installations, so don't give up on the process. If you get to, say, 10 cycles, stop there and attempt the installation of the latest drivers.
Hope this helps,
Wifi7Guy
Thanks for advice. Will give it a shot and update
Wifi7Guy
Tried suggest solution. Uninstalled with one cycle, after reboot, don't see the old installations of  Intel PROSet/Wireless Software and/or Intel Wireless Bluetooth on Device Manager.
Then installed latest drivers downloaded.
Tested and no joy. Problem remains unresolved
n_scott_pearson
Ok, the alternative possibilities are:
  1. The adapter is a dud and needs to be replaced.
  2. The laptop is preventing the use of the adapter (via, for example, inclusion/exclusion lists in BIOS).
  3. The laptop is configured for CNVi card usage and cannot tolerate non-CNVi cards (this is a stretch; I mention it because of issues in previous generations).
  4. There is something else wrong with the laptop.
The obvious next-step is to replace the card and see if this alleviates the issues.
If it doesn't, you've never mentioned what the adapter was that you removed. Was it an Intel CNVi-based card (AC9560, AX201, AX203 or AX211)?
Wifi7Guy
Thanks for suggestions. The puzzling thing is the card has totally no issue on Ubuntu as my laptop is on dual boot. Think the card is ok. The card replaced was AX201
Seriously think is some bug on the driver. Not sure if there are any driver developers here who can check out the issue. Can provide any log files if needed.
Wifi7Guy
ThomasWAspCom
Interesting. I have a very  recent Dell XPS 9640, also having the identical Wifi adapter. I searched for Netwaw16 and found this thread to match exactly what I am experiencing.
Problem happens typically after waking up, but more recently also when booting up the computer. I noticed it happening occasionally in the first few months after purchasing the computer and didn't pay much notice. but now the problem has escalated and happens at least once a day. The computer freezes and the eventlog shows warnings and errors stating like above.
I run the latest update from Microsoft on Windows 11, v. 10.0.26100 and keep my drivers updated using Dell SupportAssist. Next step is to contact Dell Pro-Support for an explanation.
Here are event logs (Logs are flooded with these):
Log (Warning):
The description for Event ID 6062 from source Netwaw16 cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
The message resource is present but the message was not found in the message table.
Details:
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Netwaw16" />
<EventID Qualifiers="32768">6062</EventID>
<Version>0</Version>
<Level>3</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2025-01-20T19:36:44.1096851Z" />
<EventRecordID>21808</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="21036" />
<Channel>System</Channel>
<Computer>XXXXXX-Laptop</Computer>
<Security />
</System>
- <EventData>
<Data />
<Binary>000000000100000000000000AE170080000000000000000000000000000000000000000000000000</Binary>
</EventData>
</Event>
Log (Error):
0000280001000000000000008A1300C0000000000000000000000000000000000000000000000000BF28000106000000040000000200000032000000EFBEADDEAE962B00AE962B000000000014532C00 : Has determined that the network adapter is not functioning properly.
Log details:
- <System>
<EventID Qualifiers="49152">5002</EventID>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2025-01-20T19:31:03.4797900Z" />
<EventRecordID>21806</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="33444" />
<Security />
</System>
- <EventData>
<Data />
<Binary>0000280001000000000000008A1300C0000000000000000000000000000000000000000000000000BF28000106000000040000000200000032000000EFBEADDEAE962B00AE962B000000000014532C00</Binary>
</EventData>
</Event>
5urg3
Similar issue
What’s with not having human readable event logs, Intel?
Giving us event IDs and then not telling us what they mean is borderline useless
My event logs too, have the same things all over them
if you want my two cents, I also believe this to be a driver bug
I was able to temporarily fix my issue by forcing the adapter in Wi-Fi 6 (AX) mode, using the device manager properties for the adapter
i am using it with a Ubiquiti WiFi 7 access point, so obviously this is not ideal…but at least it works
ALSO, this problem only occurs on Windows 11 and ONLY with the *latest* drivers from Intel
Linux works fine (also using Ubuntu)
Garthmaul
I have a Killer Wifi 7 BE1750x (BENGW200) and ma also having the Netwaw16 EventID 6062.  Will see if putting it to the AX mode works as well.
5urg3
What access point  are you using?
Did it just start happening now or has it never worked properly?
I’m STILL dealing with this sadly
Ubiquiti is no help at all and Intel won’t even talk to me really
chris53
I have the Thinkpad X1 Gen13 with the Intel Wi-Fi 7 BE201 and it also gives me the same problems with Netwaw16 crashing, when i select "random Hardware adresses" but for one network not it cannot connect with that specific network.
5urg3
Grab the latest Win 11 driver from Intel. It fixed it for me. I think it came out two weeks ago.
chris53
You mean the Version 23.130.1, right?
I installed it and still have those problems. It is annoying cause the laptop is just 2 days old.
Stevie112
I exactly have the same problem with my 3 weeks old Lenovo Thinkpad X1 Gen 13. All drivers are on the current version, bluetooth and wifi driver are 23.160.0
The network adapter will close every 30 seconds with Netwaw18
0000280001000000000000008A1300C00000000000000000000000000000000000000000000000000940102007000000040000001100102BB1000000EFBEADDE000000000000000000000000AA0808C0 : Fehlfunktion des Netzwerkadapters wurde ermittelt.
