Wireless
8900 Discussions
Netwtw08.sys BSOD loop trying fresh windows install.
Jepsii
Hello, so I recently had a Wi-fi 6 AX200 160MHZ #2 Error code 10 issue. It kept giving me the BSOD repeatedly. Due to the wi-fi card being built into the motherboard, I was unable to remove it. This computer is a little under a year old and didnt have issues until a week ago. It would keep BSODing and do a few boot cycles until finally running.
So I decided to just wipe everything and do a fresh windows install. I deleted the whole M.2 drive with all the OS and all the partitions and reformatted it and even cleared the CMOS to factory. However, when I try to install a fresh windows, I still keep getting a BSOD due to an issue with a netwtw08.sys error and keeps me in this loop.
What can I do to remedy this and get a fresh install? Current MOBO I have is ASRock X570 Phantom Gaming-ITX/TB3 Mini ITX AM4 Motherboard
Thank you
Alberto_R_Intel
Jepsii, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance matter, we just wanted to confirm a few details about your system:
Did you build the computer?
Was it working fine before?
Did you make any recent hardware/software changes that might cause this problem?
By any chance, do you have the BSOD error code?
Which Windows* version are you using?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
Alberto_R_Intel
Hello Jepsii, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Hello Jepsii, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
