Wireless
8721 Discussions
New Wi-Fi software & drivers available
John_S_Intel
* Intel recommends that you obtain and use the software provided by your laptop manufacturer. Please check for the latest downloads from your OEM first. *
We have posted the latest generic version (17.13.11) of Intel® PROSet/Wireless WiFi Software and drivers to download center:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24576 Intel® PROSet/Wireless Software for Windows 8.1*
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24577 Intel® PROSet/Wireless Software and Drivers for Windows 8*
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24578 Intel® PROSet/Wireless Software and Drivers for Windows 7*
This version supports the following products:
Intel® Dual Band Wireless-AC 3160
Intel® Dual Band Wireless-AC 7260
Intel® Dual Band Wireless-AC 7260 for Desktop
Intel® Dual Band Wireless-AC 7265
Intel® Dual Band Wireless-N 7260
Intel® Dual Band Wireless-N 7265
Intel® Wireless-N 7260
Intel® Wireless-N 7265
MHern9
You guys suck.
Jose_H_Intel1
Hi Indest, I tested the command with two different systems and in both cases 802.11ac was showing up.
Let's verify VHT mode is enabled in the advanced tab of the adapter properties window. Please indicate if you have modified any settings with the Administrator Tool.
http://www.intel.com/support/wireless/wlan/sb/CS-025393.htm Intel® Wi-Fi Products — What are the advanced Wi-Fi adapter settings?
MHern9
No modification
Jose_H_Intel1
Please uninstall Intel® PROSet Wireless Software from Programs and Features and the driver from Device Manager, restart your system, and then install the latest version again.
BB4
New Contributor II
Joe, can you tell us why a radio might not be identified as AC like that in netsh, yet will still perform as it should?
MHern9
MHern9
I should add, I used iOrbit uninstaller to make sure there was no trace of the old software behind. Still the same problem.
MHern9
So joe_intel, you think ignoring the problem solves the issue?
John_S_Intel
If you're willing to do more troubleshooting, please open a support case with our contact center and ask them to escalate your issue so we can do more in-depth troubleshooting.
Should problems continue to persist, contact Intel Customer Support.
US
Worldwide
http://www.intel.com/p/en_US/support Intel Customer Support
MPell5
Hi JohnS, I'm curious about something.
When ever we have an issue with these adapters, you seem to always say "Troubleshoot with us" or ask us some ignorant question like you legitimately don't know what the issue is.
Isn't troubleshooting and releasing updates your job?
Here's a suggestion: Buy a notebook with your adapter and try using it like a normal person. You'll quickly see what we are all saying. Then, you can do your own troubleshooting! Isn't that amazing??
