I have a Wi-Fi adapter Killer Wi-Fi 6 AX1650i 160MHz Wireless Network Adapter. The product works fine on Windows, but on Debian sid I cannot find the required firmware to make it work.
I tried installing iwlwifi firmware to make it work, but that's not enough. Below is the output from dmesg.
dmesg output
Or the text equivalent of the above output.
[ 5.117046] Intel(R) Wireless WiFi driver for Linux
[ 5.117073] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 5.118227] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-67.ucode (-2)
[ 5.118240] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[ 5.118250] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-67.ucode failed with error -2
[ 5.118255] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-66.ucode (-2)
[ 5.118264] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-66.ucode failed with error -2
[ 5.118267] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-65.ucode (-2)
[ 5.118276] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-65.ucode failed with error -2
[ 5.118280] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-64.ucode (-2)
[ 5.118289] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-64.ucode failed with error -2
[ 5.118293] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-63.ucode (-2)
[ 5.118302] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-63.ucode failed with error -2
[ 5.118305] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-62.ucode (-2)
[ 5.118313] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-62.ucode failed with error -2
[ 5.118316] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-61.ucode (-2)
[ 5.118325] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-61.ucode failed with error -2
[ 5.118328] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-60.ucode (-2)
[ 5.118337] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-60.ucode failed with error -2
[ 5.118341] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-59.ucode (-2)
[ 5.118349] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-59.ucode failed with error -2
[ 5.118352] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-58.ucode (-2)
[ 5.118361] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-58.ucode failed with error -2
[ 5.118364] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-57.ucode (-2)
[ 5.118373] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-57.ucode failed with error -2
[ 5.118377] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-56.ucode (-2)
[ 5.118385] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-56.ucode failed with error -2
[ 5.118388] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-55.ucode (-2)
[ 5.118397] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-55.ucode failed with error -2
[ 5.118400] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-54.ucode (-2)
[ 5.118409] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-54.ucode failed with error -2
[ 5.118412] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-53.ucode (-2)
[ 5.118420] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-53.ucode failed with error -2
[ 5.118423] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-52.ucode (-2)
[ 5.118432] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-52.ucode failed with error -2
[ 5.118435] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-51.ucode (-2)
[ 5.118444] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-51.ucode failed with error -2
[ 5.118447] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-50.ucode (-2)
[ 5.118457] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-50.ucode failed with error -2
[ 5.118460] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-49.ucode (-2)
[ 5.118469] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-49.ucode failed with error -2
[ 5.118471] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-48.ucode (-2)
[ 5.118480] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-48.ucode failed with error -2
[ 5.118483] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-47.ucode (-2)
[ 5.118492] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-47.ucode failed with error -2
[ 5.118495] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-46.ucode (-2)
[ 5.118503] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-46.ucode failed with error -2
[ 5.118507] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-45.ucode (-2)
[ 5.118515] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-45.ucode failed with error -2
[ 5.118518] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-44.ucode (-2)
[ 5.118527] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-44.ucode failed with error -2
[ 5.118530] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-43.ucode (-2)
[ 5.118539] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-43.ucode failed with error -2
[ 5.118542] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-42.ucode (-2)
[ 5.118550] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-42.ucode failed with error -2
[ 5.118553] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-41.ucode (-2)
[ 5.118563] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-41.ucode failed with error -2
[ 5.118566] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-40.ucode (-2)
[ 5.118574] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-40.ucode failed with error -2
[ 5.118577] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-so-a0-hr-b0-39.ucode (-2)
[ 5.118587] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-39.ucode failed with error -2
[ 5.118587] iwlwifi 0000:00:14.3: minimum version required: iwlwifi-so-a0-hr-b0-39
[ 5.118596] iwlwifi 0000:00:14.3: maximum version supported: iwlwifi-so-a0-hr-b0-67
[ 5.118605] iwlwifi 0000:00:14.3: check git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
The repo https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/ does not have the required iwlwifi-*.ucode files.
Could you please provide the firmware???
P.S.
I also have Intel Wireless Bluetooth (I guess it's on the same chip as Wi-Fi, maybe?). But I was able to find the firmware files for it at the above repo (files: ibt-1040-4150.ddc, ibt-1040-4150.sfi). But Wi-Fi firmware is not there.
