Wireless
8506 Discussions
No funciona bien mi tarjeta Intel Dual Band Wireless AC-316
JAGC
Hola, tengo esta tarjeta que me da problemas para detectar WiFi 6 desde que actualicé mi sistema a Windows 10.
Antes de la actualización a Windows 10 sí detectaba WiFi 6, pero después ha dejado de hacerlo.
Como Intel ya no da soporte sobre esa tarjeta estoy valorando si la cambio por la siguiente:
Intel 3165 3165NGW 3165AC doble banda Wireless AC + Bluetooth4.0 Mini NGFF wifi tarjeta 802.11AC 3165 Wireless Wifi Card
Mi Laptop es un Lenovo G50-80
La pregunta es si es compatible y resulta fácil cambiarla, soy neófito en estos asuntos.
Gracias
n_scott_pearson
What card to you currently have? There's no such thing as AC-316. There is AC-3160, AC-3165 and AC-3168.
JAGC
n_scott_pearson
So, before anything else, I would install the very latest (and final) driver and see if it fixes your problem. Now, as you have probably seen, intel has dropped support for the download of drivers for discontinued adapters. All is not lost; I track the discontinuation notices and ensure I have the final driver packages saved in my archive. I also have a OneDrive share where you can download the final driver packages supporting the various adapters. Use this link: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T to access my share. Use the appropriate subfolder to access the driver package for your adapter.
Hope this helps - and let us know if this alleviated your problem.
JAGC
Dear  "n_scott_pearson", I can´t find the right way to give thankyou. Yor link indicate to me the right driver to perform in my computer. Using your information I found the following page  https://www.catalog.update.microsoft.com/Search.aspx?q=Dual%20Band%20Wireless%20AC-3160  and  ( https://www.catalog.update.microsoft.com/home.aspx as entry gate) where it was the right driver, and also a lot of drivers. My computer now works fine.
There is no way I would found this information without your help.
I reiterate my gratitude and <i hope that the information we now have can be useful to others users with this problem.
A very cordial greeting.
Deeksha_S_Intel
Hi Jose, we would like to inform you that we are routing your query to the dedicated team for further assistance.
