What USB adapter are you using?
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
You do not know the manufacturer and model number of your USB adapter? Just look at it.
The error message you posted (which you took a photo of) says you have a usb adapter.
Take a photo of the usb adapter (top and bottom) and post those.
Now, a usb adapter plugs into a usb port. So, you should see something sticking out of the laptop/desktop.
Beyond that, I can no longer help you.
Physical Memory (Installed): 8 GB
Processor: Intel(R) Celeron(R) CPU G1840 @ 2.80GHz
System Type: x64-based PC
Total Installed Updates: 27 Updates - See Detailed View for more information
Display Adapter(s): Intel(R) HD Graphics 20.19.15.5144
System Manufacturer: Hewlett-Packard
System Model: 18E9
Network Adapter(s): 802.11n USB Wireless LAN Card 10.0.2.52
Realtek PCIe GbE Family Controller 9.1.410.2015
Disk(s): ST3500413AS 396.48 GB (available) 10.0.19041.1865
System Messages: Included
Direct-X Diagnostics: Included
David C. Willner
Hello @Dave444
Before we proceed with the assistance, please provide us with the following information:
1. What is the symptom of the issue?
2. Are you having issues on Wifi or Bluetooth or both?
3. Do you remember if this issue happened after a new OS update or Wireless driver update?
4. Is this issue happening at home, office environment or both?
5. Have you checked with your system's OEM for validated drivers or support on known issues related to the symptoms experienced?
6. What adapter model do you have?
7. Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
8. Have you checked if this issue happens on different networks?
9. Are you able to reproduce the same issue while on hardwired connection?
10. What steps do you take to reproduce your issue?
11. Were you able to have you wireless connection in a normal/expected performance before?
12. Have tried a roll back to a previous driver version for testing?
Thanks to @AlHill for helping us requesting the SSU, it will make the process easier.
However, it will be necessary the entire file, not just the information in the previous post. For that please, follow the instruction:
· Please download and scan your system using our tool, Intel® System Support Utility so we can help check your system info first. Once finished downloading, open the tool, click on scan 'Everything', click next, then save the system information to a .txt file. Please provide the .txt file.
We need to know the Wireless adapter first, with that information it will be easier for us to help you. Also if your don't know how to get the Wireless adapter model, you can go to the Device manager>Network adapters> (model adapter). Send us a screenshot. And if your have and USB wireless adapter also, let us know.
Isaac Q.
Hello @Dave444
We hope you are doing fine.
Isaac Q.
Hello Dave444
Best regards.
Isaac Q.
![](/skins/images/D3C0B914909A6564BBB97F4AD1ED1973/responsive_peak/images/icon_anonymous_message.png)
