I am working with dell latitude 5411 laptop. With dual boot windows 11 ubuntu and ubuntu 22.04 and kernel 6.8. There is no wifi in my ubuntu 22 (working normally on windows 11).
sudo lshw -class network
*-network:0 UNCLAIMED
description: Network controller
product: Comet Lake PCH CNVi WiFi
vendor: Intel Corporation
physical id: 14.3
bus info: pci@0000:00:14.3
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix cap_list
configuration: latency=0
resources: memory:ed33c000-ed33ffff
sudo lsmod | grep iwl
iwlwifi 606208 0
cfg80211 1368064 1 iwlwifi
uname -r
6.8.0-107-generic
abdelrahman@Abdelrahman:~$ sudo dmesg | grep iwlwi
[ 42.412389] iwlwifi 0000:00:14.3: CSR_RESET = 0x10
[ 42.412396] iwlwifi 0000:00:14.3: Host monitor block 0x0 vector 0x0
[ 42.412480] iwlwifi 0000:00:14.3: value [iter 0]: 0x00000000
[ 42.412482] iwlwifi 0000:00:14.3: value [iter 1]: 0x00000000
[ 42.412485] iwlwifi 0000:00:14.3: value [iter 2]: 0x00000000
[ 42.412487] iwlwifi 0000:00:14.3: value [iter 3]: 0x00000000
[ 42.412489] iwlwifi 0000:00:14.3: value [iter 4]: 0x00000000
[ 42.412491] iwlwifi 0000:00:14.3: value [iter 5]: 0x00000000
[ 42.412493] iwlwifi 0000:00:14.3: value [iter 6]: 0x00000000
[ 42.412495] iwlwifi 0000:00:14.3: value [iter 7]: 0x00000000
[ 42.412497] iwlwifi 0000:00:14.3: value [iter 8]: 0x00000000
[ 42.412499] iwlwifi 0000:00:14.3: value [iter 9]: 0x00000000
[ 42.412501] iwlwifi 0000:00:14.3: value [iter 10]: 0x00000000
[ 42.412504] iwlwifi 0000:00:14.3: value [iter 11]: 0x00000000
[ 42.412506] iwlwifi 0000:00:14.3: value [iter 12]: 0x00000000
[ 42.412508] iwlwifi 0000:00:14.3: value [iter 13]: 0x00000000
[ 42.412510] iwlwifi 0000:00:14.3: value [iter 14]: 0x00000000
[ 42.412511] iwlwifi 0000:00:14.3: Host monitor block 0x0 vector 0x1
[ 42.412599] iwlwifi 0000:00:14.3: value [iter 0]: 0x00000000
[ 42.412602] iwlwifi 0000:00:14.3: value [iter 1]: 0x00000000
[ 42.412604] iwlwifi 0000:00:14.3: value [iter 2]: 0x00000000
[ 42.412606] iwlwifi 0000:00:14.3: value [iter 3]: 0x00000000
[ 42.412608] iwlwifi 0000:00:14.3: value [iter 4]: 0x00000000
[ 42.412610] iwlwifi 0000:00:14.3: value [iter 5]: 0x00000000
[ 42.412612] iwlwifi 0000:00:14.3: value [iter 6]: 0x00000000
[ 42.412614] iwlwifi 0000:00:14.3: value [iter 7]: 0x00000000
[ 42.412616] iwlwifi 0000:00:14.3: value [iter 8]: 0x00000000
[ 42.412618] iwlwifi 0000:00:14.3: value [iter 9]: 0x00000000
[ 42.412620] iwlwifi 0000:00:14.3: value [iter 10]: 0x00000000
[ 42.412622] iwlwifi 0000:00:14.3: value [iter 11]: 0x00000000
[ 42.412625] iwlwifi 0000:00:14.3: value [iter 12]: 0x00000000
[ 42.412627] iwlwifi 0000:00:14.3: value [iter 13]: 0x00000000
[ 42.412629] iwlwifi 0000:00:14.3: value [iter 14]: 0x00000000
[ 42.412630] iwlwifi 0000:00:14.3: Host monitor block 0x0 vector 0x6
[ 42.412718] iwlwifi 0000:00:14.3: value [iter 0]: 0x00000000
[ 42.412720] iwlwifi 0000:00:14.3: value [iter 1]: 0x00000000
[ 42.412722] iwlwifi 0000:00:14.3: value [iter 2]: 0x00000000
[ 42.412724] iwlwifi 0000:00:14.3: value [iter 3]: 0x00000000
[ 42.412727] iwlwifi 0000:00:14.3: value [iter 4]: 0x00000000
[ 42.412729] iwlwifi 0000:00:14.3: value [iter 5]: 0x00000000
[ 42.412731] iwlwifi 0000:00:14.3: value [iter 6]: 0x00000000
[ 42.412733] iwlwifi 0000:00:14.3: value [iter 7]: 0x00000000
[ 42.412735] iwlwifi 0000:00:14.3: value [iter 8]: 0x00000000
[ 42.412737] iwlwifi 0000:00:14.3: value [iter 9]: 0x00000000
[ 42.412739] iwlwifi 0000:00:14.3: value [iter 10]: 0x00000000
[ 42.412741] iwlwifi 0000:00:14.3: value [iter 11]: 0x00000000
[ 42.412744] iwlwifi 0000:00:14.3: value [iter 12]: 0x00000000
[ 42.412746] iwlwifi 0000:00:14.3: value [iter 13]: 0x00000000
[ 42.412748] iwlwifi 0000:00:14.3: value [iter 14]: 0x00000000
[ 42.412749] iwlwifi 0000:00:14.3: Host monitor block 0x22 vector 0x0
[ 42.412837] iwlwifi 0000:00:14.3: value [iter 0]: 0x00000000
[ 42.412871] iwlwifi: probe of 0000:00:14.3 failed with error -110
Hi abdelrahman7991,
Based on your system information, I can see you're experiencing a Linux wireless connectivity issue with your Dell Latitude 5411.
To assist you effectively, please share the information below.
1. What is the full model of your wireless adapter?
2. Did you make any recent changes to the system?
3. Did Wi-Fi work in Ubuntu 22.04 before, or has it never worked?
I also recommend that you install the latest stable Kernel 6.19 which can be downloaded at The Linux Kernel Archives.
Best regards
Jed G.
the wifi adapter model is: Intel Wireless AX201 WLAN WiFi 802.11ax.
I didn't do anything new to the system. I had windows 11 with working wifi. When I installed ubuntu 22 the wifi didn't work at all (still working on windows normally).
Note that, I tried ubuntu 20 and the wifi worked normally.
Hi abdelrahman7991,
Thank you for sharing all the requested information. To further troubleshoot the issue, please follow the steps outlined below:
1. Ensure that you are using the latest stable version of the Linux kernel (version 6.19.13).
Kernel Download:
2. Install the most up-to-date wireless firmware using the link below:
Firmware Download: https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/intel/iwlwifi
Required firmware versions:
iwlwifi-Qu-b0-hr-b0-77
iwlwifi-Qu-c0-hr-b0-77
iwlwifi-QuZ-a0-hr-b0-77
You may also find our public articles helpful:
Intel® Wireless Card Not Detected in Linux*
Linux* Support for Intel® Wireless Adapters
If you have any questions, please let me know.
Jed G.
I installed Linux kernel (version 6.19.13) using mainline. Then cloned the linux-firmware repo, then I ran the following:
cd linux-firmware/intel/iwlwifi
sudo cp * /lib/firmware
Still nothing is working. Also I want to assure that there is an error when I read kernel messages:
sudo dmesg | grep iwlwi:
[42.412871] iwlwifi: probe of 0000:00:14.3 failed with error -110
Which is something related to loading the firmware to the wifi module (based on AI search)
Final note, it is working on windows 11 and ubuntu 20.04 and the dell latitude 5411 bios is the latest version
Hi abdelrahman7991,
Thank you for sharing your feedback. I will investigate this issue further and provide you with an update as soon as possible.
Best regards
Jed G.
Hello JedG_Intel,
The problem was partially solved by installed very old kernel (5.15). But every once in a while the, when i turn on the laptop, the same problem appears again "There is no wifi adapter". But it is solved again as soon as i restart the laptop. So if there any better solution, please let me know. Thank you
Hi abdelrahman7991,
I’ve sent you an email to gather additional information and to continue providing support. Please check your inbox at your earliest convenience.
Best regards
Jed G.
