Hello. I currently have a wireless 7260 in a pcie 1x slot (HMC form factor) and I bought a Wireless Desktop 6 adapter set and naturally its an M2 form factor not HMC. Does anyone know of a good m.2 NGFF adapter for PCIe? I would like to be able to replace this card but I've hit a wall so far.
My motherboard has an M2 slot on it but apparently its not the same M2 as this NGFF one because I couldn't get it to fit. I assume its dedicated to an M2 drive use only.
Your board probably has M.2 slot(s) of Type B or (more likely) Type M. These are used to support SATA and/or NVMe SSDs. The wireless cards need an M.2 slot of Type A or (more likely) Type E.
There are a whole slew of adapters available. Here is an example of one that offers the compatibility and features needed: https://www.amazon.com/Desktop-Wireless-Network-Converter-Including/dp/B01MFGYAX6. It provides the M.2 Type E connector and it also provides the link to a motherboard USB connector to support the card's Bluetooth capability as well. I am, in fact, entering this response on a PC that has one of these cards installed. It has an Intel AX200 (Wireless-AX/WiFi 6) module on it.
Hope this helps,
P.S. This page https://en.wikipedia.org/wiki/M.2 provides a good introduction to M.2 and its slot types.
Hope this helps,
Scott, that is EXACTLY what I needed sir, thank you for your post. I thought "m.2=m.2, why isn't this fitting?"
I ordered that card and I hope to put it in next week when it comes in. A huge thank you!
Dennis
Went ahead and installed it. 100% stable and throughput through the roof. Loving it and so is my wife, which everybody knows is the real win. Thanks again for the rec. Scott, worked like a champ.
Thanks. As vaudevillian Joe Frisco used to say, "No Applause - Just Throw Money!" ;^)
![](/skins/images/7B0AB6865064EAE32B30EC9A4E94B48A/responsive_peak/images/icon_anonymous_message.png)
