Wireless
9030 Discussions
Problem Driver, HardWare Wifi Card?
HugoSB
Wifi Driver or Hardware Problem?
I have a Realtek wifi card. And I relate these errors to screen freezes that restart my PC. And I'm not using Wifi.
In the event viewer I have two errors,
First error when turning on the computer.
Could not load driver \Driver\WudfRd for device PCI\VEN_8086&DEV_1903&SUBSYS_8653103C&REV_07\3&11583659&0&20.
Second error if I leave enabled the driver that corresponds to the address PCI\VEN_8086&DEV_1903&SUBSYS_8653103C&REV_07, which is Realtek RTL8822CE 802.11ac PCIe Adapter
Hardware bug fixed.
Component: PCI Express Endpoint
Error source: Advanced Error Reporting (PCI Express)
Main Bus:Device:Function: 0x3:0x0:0x0
Secondary Bus:Device:Function: 0x0:0x0:0x0
Parent device name: PCI\VEN_10EC&DEV_C822&SUBSYS_85F7103C&REV_00
Secondary device name:
This second mistake is repeated a lot.
Alberto_R_Intel
HugoSB, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
What is the model of the motherboard?
If this is a laptop, what is the model of it?
Is this a new computer?
Was it working fine before without showing the error messages?
If yes, when did the issue start?
Did you make any recent hardware/software changes that might cause this issue?
Even though you mention you are not using Wi-Fi, the wireless card, did you purchase it separately or did it come installed on the computer?
Which Windows* version are you using?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
DesomZues
Albert R.
Aww, Thamkyou Moderator, I try according to your given Link and my issue has been fixed. Actually, I'm aslo suffering from the same issue recent few days. Thanks for helping Us.
If I face this issue again, then I follow the same guidence or need anything else?
HugoSB
Microsoft (R) Windows Debugger Version 10.0.22621.1 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Bitmap Dump File: Kernel address space is available, User address space may not be available.
Dump completed successfully, progress percentage: 85
Symbol search path is: srv*
Executable search path is:
Missing image name, possible paged-out or corrupt data.
Unable to load image Unknown_Module_00000000`00000000, Win32 error 0n2
*** WARNING: Unable to verify timestamp for Unknown_Module_00000000`00000000
*** ERROR: Module load completed but symbols could not be loaded for Unknown_Module_00000000`00000000
Unable to add module at 00000000`00000000
WARNING: .reload failed, module list may be incomplete
Debugger can not determine kernel base address
Windows 10 Kernel Version 22000 MP (6 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Edition build lab: 22000.1.amd64fre.co_release.210604-1628
Machine Name:
Kernel base = 0xfffff804`59800000 PsLoadedModuleList = 0xfffff804`5a4296b0
Debug session time: Tue Aug 23 01:45:53.315 2022 (UTC + 2:00)
System Uptime: 0 days 0:14:57.962
Loading Kernel Symbols
.Unable to load image Unknown_Module_00000000`00000000, Win32 error 0n2
Unable to read KLDR_DATA_TABLE_ENTRY at 00000000`00000000 - HRESULT 0x80004002
Loading unloaded module list
GetContextState failed, 0xD0000147
CS descriptor lookup failed
For analysis of this file, run !analyze -v
0: kd> analyze -v
Couldn't resolve error at 'nalyze -v'
0: kd> !analyze -v
Unable to get program counter
Unable to get current machine context, NTSTATUS 0xC0000147
* Bugcheck Analysis *
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: ffffca8a00f17460, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff80487a41b20, The pointer into responsible device driver module (e.g. owner tag).
Arg3: ffffffffc000009a, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 0000000000000004, Optional internal context dependent data.
Debugging Details:
***** Debugger could not find nt in module list, module list might be corrupt, error 0x80070057.
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 15
Key : Analysis.DebugAnalysisManager
Value: Create
Key : Analysis.Elapsed.mSec
Value: 72
Key : Analysis.Init.CPU.mSec
Value: 2327
Key : Analysis.Init.Elapsed.mSec
Value: 54058
Key : Analysis.Memory.CommitPeak.Mb
Value: 43
Key : WER.CorruptModuleList
Value: 1
Key : WER.OS.Branch
Value: co_release
Key : WER.OS.Timestamp
Value: 2021-06-04T16:28:00Z
Key : WER.OS.Version
Value: 10.0.22000.1
FILE_IN_CAB: MEMORY.DMP
DUMP_FILE_ATTRIBUTES: 0x1000
BUGCHECK_CODE: 116
BUGCHECK_P1: ffffca8a00f17460
BUGCHECK_P2: fffff80487a41b20
BUGCHECK_P3: ffffffffc000009a
BUGCHECK_P4: 4
IP_IN_FREE_BLOCK: 0
STACK_TEXT:
SYMBOL_NAME: ANALYSIS_INCONCLUSIVE
MODULE_NAME: Unknown_Module
IMAGE_NAME: Unknown_Image
STACK_COMMAND: .cxr; .ecxr ; kb
FAILURE_BUCKET_ID: ZEROED_STACK_0x116
OS_VERSION: 10.0.22000.1
BUILDLAB_STR: co_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {3154f8e6-c4fa-03b5-6330-e2df673f8bf4}
Followup: MachineOwner
WARNING: Unable to reset page directories
0: kd> lmvm Unknown_Module
Browse full module list
start end module name
0: kd> lmDv
Unloaded modules:
fffff804`7ab90000 fffff804`7abba000 MpKslDrv.sys
Timestamp: unavailable (00000000)
Checksum: 00000000
ImageSize: 0002A000
fffff804`74200000 fffff804`74211000 dump_storport.sys
Checksum: 00000000
ImageSize: 00011000
fffff804`77c40000 fffff804`78826000 dump_iaStorAC.sys
Checksum: 00000000
ImageSize: 00BE6000
fffff804`78850000 fffff804`7886e000 dump_dumpfve.sys
Checksum: 00000000
ImageSize: 0001E000
fffff804`86200000 fffff804`86268000 esif_lf.sys
Checksum: 00000000
ImageSize: 00068000
fffff804`861e0000 fffff804`861f3000 dptf_cpu.sys
Checksum: 00000000
ImageSize: 00013000
fffff804`86270000 fffff804`862c7000 WUDFRd.sys
Checksum: 00000000
ImageSize: 00057000
fffff804`76e70000 fffff804`76e8f000 dam.sys
Checksum: 00000000
ImageSize: 0001F000
fffff804`77bf0000 fffff804`77bff000 KMPDC.sys
Checksum: 00000000
ImageSize: 0000F000
fffff804`5df30000 fffff804`5df41000 WdBoot.sys
Checksum: 00000000
ImageSize: 00011000
fffff804`5fc10000 fffff804`5fc22000 hwpolicy.sys
Checksum: 00000000
ImageSize: 00012000
0: kd> lmDvsm
Unloaded modules:
Checksum: 00000000
ImageSize: 0002A000
Checksum: 00000000
ImageSize: 00011000
Checksum: 00000000
ImageSize: 00BE6000
Checksum: 00000000
ImageSize: 0001E000
Checksum: 00000000
ImageSize: 00068000
Checksum: 00000000
ImageSize: 00013000
Checksum: 00000000
ImageSize: 00057000
Checksum: 00000000
ImageSize: 0001F000
Checksum: 00000000
ImageSize: 0000F000
Checksum: 00000000
ImageSize: 00011000
Checksum: 00000000
ImageSize: 00012000
0: kd> lmDvsm
Unloaded modules:
Checksum: 00000000
ImageSize: 0002A000
Checksum: 00000000
ImageSize: 00011000
Checksum: 00000000
ImageSize: 00BE6000
Checksum: 00000000
ImageSize: 0001E000
Checksum: 00000000
ImageSize: 00068000
Checksum: 00000000
ImageSize: 00013000
Checksum: 00000000
ImageSize: 00057000
Checksum: 00000000
ImageSize: 0001F000
Checksum: 00000000
ImageSize: 0000F000
Checksum: 00000000
ImageSize: 00011000
Checksum: 00000000
ImageSize: 00012000
0: kd> lmDv
Unloaded modules:
Checksum: 00000000
ImageSize: 0002A000
Checksum: 00000000
ImageSize: 00011000
Checksum: 00000000
ImageSize: 00BE6000
Checksum: 00000000
ImageSize: 0001E000
Checksum: 00000000
ImageSize: 00068000
Checksum: 00000000
ImageSize: 00013000
Checksum: 00000000
ImageSize: 00057000
Checksum: 00000000
ImageSize: 0001F000
Checksum: 00000000
ImageSize: 0000F000
Checksum: 00000000
ImageSize: 00011000
Checksum: 00000000
ImageSize: 00012000
Alberto_R_Intel
Hello HugoSB, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Steven_Intel
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
