Wireless
8619 Discussions
RF Certification for AX200NGW on ARM Linux 5.4.24
svink
Hi, We are preparing for RF certification testing of our product consisting of AX200 on an ARM Linux (5.4.24) based IoT Gateway. Currently I am looking for information on fixing the BLE Tx channel (low/med/high) and also setting up BLE Tx power at maximum using hcitool preferably or any other way. Could you kindly help us please?
Thank you & Regards,
     Svink
DeividA_Intel
Hello svink,
Thank you for posting on the Intel® communities. I understand you are having issues with your Intel® Wi-Fi 6 AX200 (Gig+).
1. Are you using a laptop or desktop computer?
2. Why do you need this certification? Can you provide more details?
3. Can you provide more details about the issue that you are having?
Deivid A.
svink
Hi Deivid A,
   Thank you for the reply.
  Ans: we are building an embedded IoT Gateway product. We use AX200 based M.2 card inside it for WiFI/BT/BLE.
  Ans: We have to certify our product to be in compliance & as per the mandatory requirement.
  Ans:
    1. I use hcitool in Linux to set BLE Tx power to Maximum. As it is manufacturer specific, I am looking for the exact command to set BLE Tx power to max.
   2. For Transmission on specific channel, I use below command. however I don't see it getting transmitted. I use a scanner searching for bd_address (mac address) of the Ax200.
       reset module
       hcitool -i hci0 cmd 0x03 0x003
       transmit at 2402MHz
       hcitool -i hci0 cmd 0x08 0x1e 0x00 0x25 0x00
       now I scan for the device from another BLE scanner.
   Svink
DeividA_Intel
Hello svink,
Thank you for the information provided
Deivid A.
DeividA_Intel
Hello svink,
Based on the investigation performed, I recommend asking for these certifications from Dekra since they are the only way to get them. I will send you the contact information to the e-mail address associated with your community profile.
However, the ARM-based platform is not in Intel wireless support scope. In this case, you will need to work with your Intel Sales representative directly to review this request.
Also, you may need to check the Intel® Resource and Documentation Center (RDC), you can find details in the following link.
https://www.intel.com/content/www/us/en/support/articles/000058073.html
Thanks for your time and comprehension.
Deivid A.
svink
Hi Deivid,
   Thank you for your reply & details shared. Appreciate your quick response.
   Not sure whether I confused you or not! Accept my sincere apologies if so.... I am not looking for any ARM related support and also not any certification. I am mainly looking for couple of commands on Linux (hcitool) to change the transmission power of BLE of AX200 & also to fix the frequency while transmission for certification testing purpose. Do you still think Dekra or RDC can help me in this regard?
Thank you & Best Regards,
   Svink
