Wireless
8526 Discussions
Random disconnects on Wifi on Linux Ubuntu 18.04 laptop with a Dual Band Wireless-AC 8265 module - message is "deauthenticating from...by local choice (Reason: 3=DEAUTH_LEAVING)"
MIon0
The Wifi randomly stops with the above message in the logs.
The company who sold me the laptop has replaced the WiFi module - so it seems not to be a hardware problem.
I have modified the /etc/modprobe.d/iwlwifi.conf file and added
options iwlwifi bt_coex_active=0
but it didn't change anything.
However I noticed that after higher activity (watching TV live) the Wifi is disconnected more quickly than when no activity is performed (excepting system activity: checking if new packages are available, if mail has arrived,...).
Generally if I am watching TV (using a streaming application like https://www.molotov.tv/) in 10-20 minutes the Wifi is cut, while doing nothing it may keep the WiFi even more than an hour.
What should be done? what options may I activate to gather more information?
netdriverinfo.sh script displayed the following information:
: 02:00.0
   Make/Model = Intel Corporation Dual Band Wireless-AC 8265
   Ethernet controller = Intel Corporation Wireless 8265 / 8275
   VenID:DevID = 8086:24fd
   Driver name = No driver loaded
   Driver version = No driver loaded
dmesg displayed the following messages concerning the iwlwifi module
[ ...] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
[ ] iwlwifi 0000:02:00.0: Found debug destination: EXTERNAL_DRAM
[  ] iwlwifi 0000:02:00.0: Found debug configuration: 0
[  ] iwlwifi 0000:02:00.0: loaded firmware version 36.77d01142.0 op_mode iwlmvm
[ ] iwlwifi 0000:02:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
[ ] iwlwifi 0000:02:00.0: Applying debug destination EXTERNAL_DRAM
[ ] iwlwifi 0000:02:00.0: Allocated 0x00400000 bytes for firmware monitor.
[ ] iwlwifi 0000:02:00.0: base HW address: dc:8b:28:64:32:d2
[ ] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
[ ] iwlwifi 0000:02:00.0: FW already configured (0) - re-configuring
[ ] iwlwifi 0000:02:00.0: BIOS contains WGDS but no WRDS
MIon0
I shall try to install Windows to see if the problem persists there - or maybe I shall try firstly to run Ubuntu or another live distribution from a CD/DVD to see if the problem persists. I don't think is the router - other computers or smartphones using the same router do not exhibit this problem.
If I understand correctly, among all Linux driver's options there is none to be used at least to get more information when disconnecting ?
AlHill
Take it back to the company that sold it to you.
Doc
MIon0
The company in question has already replaced the module, I don't think 2 different modules may experience the same hardware problem, it should really be a very strange coincidence.
AlHill
I am talking about the entire laptop.
Doc
MIon0
OK, thank you.
LeonWaksman
Try to ask this question on Linux Ubuntu forum. Probably you did already, however, it is O.S. or Router problem.
Leon
MIon0
I tried, but none of the solutions found worked for me! :-(
LeonWaksman
  1. Try to update the Ubuntu to newer/latest version.
  2. Backup your drive and install Windows. Check if this problem exists with Windows.
Leon
MIon0
MIon0
Yes, that was a good clue, and I thank you very much for it.
So, using a live Xubuntu 19.10 DVD I did not experience any network cut, so I may presume that is something different.
And in fact coming back to my normal Ubuntu installation I noticed a program "recommended" by the company that sold me the computer - deleting it (tuxedofancontrol) made my computer more usable ; in fact, in order to cut the network now I have to use my TV stream program and run glxgears at the same time to stress the CPU (the fans are working, even without tuxedofancontrol). But... more rarely, there are some network interrupts! :-(
The biggest difference with respect to Xubuntu 19.10 is the kernel version - I even noticed that the latest kernel version (5.4.7) has in its changelog a fix for iwlwifi! (see https://cdn.kernel.org/pub/linux/kernel/v5.x/ChangeLog-5.4.7).
MIon0
The messages that are now are
[ven. janv. 3 21:43:36 2020] mce: CPU3: Core temperature above threshold, cpu clock throttled (total events = 1197)
[ven. janv. 3 21:43:36 2020] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 1587)
[ven. janv. 3 21:43:36 2020] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 1587)
[ven. janv. 3 21:43:36 2020] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 1587)
[ven. janv. 3 21:43:36 2020] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 1587)
[ven. janv. 3 21:43:36 2020] mce: CPU3: Core temperature/speed normal
[ven. janv. 3 21:43:36 2020] mce: CPU1: Package temperature/speed normal
[ven. janv. 3 21:43:36 2020] mce: CPU3: Package temperature/speed normal
[ven. janv. 3 21:43:36 2020] mce: CPU0: Package temperature/speed normal
[ven. janv. 3 21:43:36 2020] mce: CPU2: Package temperature/speed normal
[ven. janv. 3 21:45:08 2020] wlp2s0: deauthenticating from 18:a6:f7:2b:78:3e by local choice (Reason: 3=DEAUTH_LEAVING)
Mike_Intel
Hello MIon0,
Base on your inquiry, we have specific forum for these issues and I will be transferring this thread for faster response.
Michael L.
Intel Customer Support Technicians
A Contingent Worker at Intel
MIon0
OK, thank you very much -> what is then this thread's address?
