Wireless
8536 Discussions
Re: Intel Driver & Support Assistant failing to scan
Sanguine
OK all sorted, a friend suggested uninstalling DSA, deleting the associated DSA folder in ProgramData/Intel/DSA and then running a DSA uninstaller tool (Download Intel® Driver & Support Assistant Uninstaller). After a full reboot, DSA is working good as new.
I hope this helps others.
DeividA_Intel
Hello Sanguine,
I do appreciate the information provided, the steps that you mentioned will help anyone that may be facing the same issue. Thanks for sharing the steps that you performed to solved the issue.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
