Wireless
8871 Discussions
Reformatting to WINXP (NEED WLAN DRIVER) - Please help
I've just reformatted my Acer Aspire One (D257) from Windows 7 to Windows XP. I've found drivers for all my hardware except one, my WLAN. Through searching the model number on the netbook's sticker, I've ascertained that the wireless network card loaded is an intel centrino wireless-n 100. After much exhaustive searching I am quite worried now that this model has no Windows XP driver??? http://www.intel.com/support/wireless/wlan/sb/CS-031641.htm http://www.intel.com/support/wireless/wlan/sb/CS-031641.htm
Please help me find a driver that will enable my hardware to function on XP. If the appropriate one does not work, perhaps there is some workaround or other compatible driver software? I'm desperate, this light laptop is almost nonfunctional under Windows 7, so reverting to the factory OS is not an option. For reference here is the acer support page, which would provide me with the perfect drivers if only I was running W7. http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=3659 http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=3659
Thanks!
where did u get the other drivers ,,,am getting hard time for the XP drivers for this machine...pls share
To all those who currently searching a working driver for Acer Aspire One D257,
You can find the driver here > http://laptop-problem.blogspot.com/2012/01/acer-aspire-one-d257-1890-windows-xp.html http://laptop-problem.blogspot.com/2012/01/acer-aspire-one-d257-1890-windows-xp.html
Regarding the wireless problem, somesay they fix it by resetting their netbook to factory setting.
Hope this helps!
