Wireless
9030 Discussions
Remove
RGlos
n_scott_pearson
The Wireless-N 2230 supports up to 300Mb/s. The Wireless-AC 3165 supports up to 433Mb/s. Have you enabled and are you using the 5GHz band? If not, you should.
BTW, WPA mode has no bearing on this at all.
n_scott_pearson
Hhmmm, are your antennas attached properly? If they seem to be, try swapping them.
Hope this helps,
RGlos
I'm using a century link modem. No antennas. Glossin
n_scott_pearson
Modem? Nobody said anything about your modem.
The Wireless-AC 3165 card, like the Wireless-N 2230 before it, requires antennas to be connected​ to it.
