Wireless
8606 Discussions
Replacement WiFi card Dell XPS 1300
Maplewood
What is the most up to date WiFi card for a Dell XPS 1300 latop?
n_scott_pearson
Well, as I said, the AX200 should, in theory, work. The module is fairly cheap (~US$20 on Amazon: https://www.amazon.com/Intel-Network-AX200-NGWG-NV-AX2002230-Retail/dp/B07ZVYKRW9), so not a huge outlay to try...
n_scott_pearson
What is the full model number for your Dell laptop? 'XPS 1300' matches nothing on their site.
Maplewood
Dell XPS 13 9300
Thanks for your assistance
n_scott_pearson
According to the Dell site, this laptop has a Killer™ Wi-Fi 6 AX1650 card (which is a fine card). The equivalent to this from Intel would be the AX200 card. You can find out more about it here: https://www.intel.com/content/www/us/en/products/wireless/wi-fi-6-series/wi-fi-6-ax200.html.
Maplewood
The Killer keeps going to sleep and the Power Management option for the card appear in Device Manager.  Dell suggested this swap.
n_scott_pearson
Ask them what version of the AX1650 is installed. If it's (just) the AX1650x, then the AX200 is a valid replacement. If it's the AX1650i, we have to be careful. In theory, there shouldn't be any problem, but I have seen reports of the AX200 not working with certain motherboards (it has something to do with the M.2 connector's support for CNVio on that motherboard).
Maplewood
n_scott_pearson
Maplewood
thanks for your generous assistance.
