Install driver version:WiFi-23.20.0-Driver64-Win10-Win11
Windows version: Server 2022 Version 21H2 (OS Build 20348.2322)
My server 2022 install BE200 driver fail, show "A service installation section in this INF is invalid."
The software Installer log:
[1B88:2524][2024-02-16T13:37:45]i001: Burn v3.11.1.2318, Windows v10.0 (Build 20348: Service Pack 0), path: C:\Windows\Temp\{D878C57F-24E8-4E7A-83D8-D327E6576F3C}\.cr\WirelessSetup.exe
[1B88:2524][2024-02-16T13:37:45]i000: Initializing numeric variable 'ModifyScreenEnabled' to value '0'
[1B88:2524][2024-02-16T13:37:45]i000: Initializing numeric variable 'GUIUninstallEnabled' to value '0'
[1B88:2524][2024-02-16T13:37:45]i000: Initializing numeric variable 'GUIComponentMultiSelectionEnabled' to value '0'
[1B88:2524][2024-02-16T13:37:45]i000: Initializing numeric variable 'GUIShowSummaryPopup' to value '0'
[1B88:2524][2024-02-16T13:37:45]i000: Initializing numeric variable 'GUIShowFinalSummary' to value '0'
[1B88:2524][2024-02-16T13:37:45]i000: Initializing numeric variable 'DowngradeEnabled' to value '0'
[1B88:2524][2024-02-16T13:37:45]i000: Initializing numeric variable 'ElevationRequired' to value '0'
[1B88:2524][2024-02-16T13:37:45]i009: Command Line: '-burn.clean.room=C:\Windows\Temp\{34ED47C7-A93B-4E8D-89DB-BF46C6A1D18E}\WirelessSetup.exe -burn.filehandle.attached=588 -burn.filehandle.self=696'
[1B88:2524][2024-02-16T13:37:45]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Windows\Temp\{34ED47C7-A93B-4E8D-89DB-BF46C6A1D18E}\WirelessSetup.exe'
[1B88:2524][2024-02-16T13:37:45]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Windows\Temp\{34ED47C7-A93B-4E8D-89DB-BF46C6A1D18E}\'
[1B88:2524][2024-02-16T13:37:45]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\ADMINI~1\AppData\Local\Temp\Intel®_Software_Installer_20240216133745.log'
[1B88:2524][2024-02-16T13:37:45]i052: Condition 'VersionNT >= v10.0' evaluates to true.
[1B88:2524][2024-02-16T13:37:45]i000: Setting string variable 'WixBundleName' to value 'Intel® Software Installer'
[1B88:2524][2024-02-16T13:37:45]i000: Setting string variable 'WixBundleManufacturer' to value 'Intel Corporation'
[1B88:2524][2024-02-16T13:37:45]i000: Loading managed bootstrapper application.
[1B88:2524][2024-02-16T13:37:46]i000: Creating BA thread to run asynchronously.
[1B88:3254][2024-02-16T13:37:46]i000: Entry point of WiX - Run method
[1B88:3254][2024-02-16T13:37:46]i000: Changing InstallAction from Unknown to Install
[1B88:3254][2024-02-16T13:37:46]i000: InstallAction = Install
[1B88:3254][2024-02-16T13:37:46]i000: Current locale: en-US
[1B88:3254][2024-02-16T13:37:46]i000: Setting numeric variable 'WixBundleUpgradeAction' to value 0
[1B88:3254][2024-02-16T13:37:46]i000: Setting numeric variable 'WixBundleRelationType' to value 0
[1B88:3254][2024-02-16T13:37:46]i000: Setting string variable 'Documentation_DisplayName' to value 'Documentation'
[1B88:3254][2024-02-16T13:37:46]i000: Setting string variable 'MinSupportedOsVersion' to value '10.0.17763.0'
[1B88:3254][2024-02-16T13:37:46]i000: Setting string variable 'ProductName' to value 'Intel® PROSet/Wireless Wi-Fi Software'
[1B88:3254][2024-02-16T13:37:46]i000: RebootRequired: Setting to False.
[1B88:2524][2024-02-16T13:37:48]i100: Detect begin, 4 packages
[1B88:2524][2024-02-16T13:37:48]i000: OnDetectBegin: Installed=False, PackageCount=4, Result=None
[1B88:2524][2024-02-16T13:37:48]i000: Setting string variable 'NETFRAMEWORK45' to value '528449'
[1B88:2524][2024-02-16T13:37:48]i000: OnDetectPackageBegin: PackageId=NetFx462Web, Result=None
[1B88:2524][2024-02-16T13:37:48]i000: Setting numeric variable 'NetFx462Web_Installed' to value 0
[1B88:2524][2024-02-16T13:37:48]i000: Setting numeric variable 'NetFx462Web_Install' to value 0
[1B88:2524][2024-02-16T13:37:48]i052: Condition 'NETFRAMEWORK45 >= 394802' evaluates to true.
[1B88:2524][2024-02-16T13:37:48]i000: OnDetectPackageComplete: PackageId=NetFx462Web, State=Present, Status=0
[1B88:2524][2024-02-16T13:37:48]i000: OnDetectPackageBegin: PackageId=Pre_Install, Result=None
[1B88:2524][2024-02-16T13:37:48]i000: Setting numeric variable 'Pre_Install_Installed' to value 0
[1B88:2524][2024-02-16T13:37:48]i000: Setting numeric variable 'Pre_Install_Install' to value 0
[1B88:2524][2024-02-16T13:37:48]i000: Setting numeric variable 'Pre_Install_Install' to value 1
[1B88:2524][2024-02-16T13:37:48]i052: Condition '0' evaluates to false.
[1B88:2524][2024-02-16T13:37:48]i000: OnDetectPackageComplete: PackageId=Pre_Install, State=Absent, Status=0
[1B88:2524][2024-02-16T13:37:48]i000: OnDetectPackageBegin: PackageId=WIFI_Driver, Result=None
[1B88:2524][2024-02-16T13:37:48]i000: Setting numeric variable 'WIFI_Driver_Installed' to value 0
[1B88:2524][2024-02-16T13:37:48]i000: Setting numeric variable 'WIFI_Driver_Install' to value 0
[1B88:2524][2024-02-16T13:37:48]i000: Setting numeric variable 'WIFI_Driver_Install' to value 1
[1B88:2524][2024-02-16T13:37:48]i052: Condition 'WixBundleInstalled AND WIFI_Driver_Installed' evaluates to false.
[1B88:2524][2024-02-16T13:37:48]i000: OnDetectPackageComplete: PackageId=WIFI_Driver, State=Absent, Status=0
[1B88:2524][2024-02-16T13:37:48]i000: OnDetectPackageBegin: PackageId=DocsManager, Result=None
[1B88:2524][2024-02-16T13:37:48]i000: Setting numeric variable 'DocsManager_Installed' to value 0
[1B88:2524][2024-02-16T13:37:48]i000: Setting numeric variable 'DocsManager_Install' to value 0
[1B88:2524][2024-02-16T13:37:48]i000: Setting numeric variable 'DocsManager_Install' to value 1
[1B88:2524][2024-02-16T13:37:48]i000: OnDetectPackageComplete: PackageId=DocsManager, State=Absent, Status=0
[1B88:2524][2024-02-16T13:37:48]i101: Detected package: NetFx462Web, state: Present, cached: None
[1B88:2524][2024-02-16T13:37:48]i101: Detected package: Pre_Install, state: Absent, cached: None
[1B88:2524][2024-02-16T13:37:48]i101: Detected package: WIFI_Driver, state: Absent, cached: None
[1B88:2524][2024-02-16T13:37:48]i101: Detected package: DocsManager, state: Absent, cached: Complete
[1B88:2524][2024-02-16T13:37:48]i000: OnDetectComplete: Status=0
[1B88:2524][2024-02-16T13:37:48]i199: Detect complete, result: 0x0
[1B88:3254][2024-02-16T13:37:51]i000: Apply - PlanAction=Install
[1B88:2524][2024-02-16T13:37:51]i200: Plan begin, 4 packages, action: Install
[1B88:2524][2024-02-16T13:37:51]i000: OnPlanBegin: PackageCount=4, Result=None
[1B88:2524][2024-02-16T13:37:51]i000: OnPlanPackageBegin: PackageId=NetFx462Web, Result=None, State=Present
[1B88:2524][2024-02-16T13:37:51]w321: Skipping dependency registration on package with no dependency providers: NetFx462Web
[1B88:2524][2024-02-16T13:37:51]i000: OnPlanPackageComplete: Execute=None, PackageId=NetFx462Web, Requested=None, Rollback=None, State=Present, Status=0
[1B88:2524][2024-02-16T13:37:51]i000: OnPlanPackageBegin: PackageId=Pre_Install, Result=None, State=Present
[1B88:2524][2024-02-16T13:37:51]i000: PlanPackage(Pre_Install, Present)
[1B88:2524][2024-02-16T13:37:51]i000: Setting string variable 'Pre_Install_InstallCommand' to value '-preinstall -b "C:\Windows\Temp\{34ED47C7-A93B-4E8D-89DB-BF46C6A1D18E}\WirelessSetup.exe" -c "C:\ProgramData\Package Cache\{acc5d32f-fbf7-4d75-8943-2f70e698123d}" -pc "C:\ProgramData\Package Cache\{acc5d32f-fbf7-4d75-8943-2f70e698123d}\InstalledPackages.xml" -l "[WixBundleLog_Pre_Install]" -ip WIFI_Driver -mp DocsManager '
[1B88:2524][2024-02-16T13:37:51]w321: Skipping dependency registration on package with no dependency providers: Pre_Install
[1B88:2524][2024-02-16T13:37:51]i000: Setting string variable 'WixBundleLog_Pre_Install' to value 'C:\Users\ADMINI~1\AppData\Local\Temp\Intel®_Software_Installer_20240216133745_000_Pre_Install.log'
[1B88:2524][2024-02-16T13:37:51]i000: Setting string variable 'WixBundleRollbackLog_Pre_Install' to value 'C:\Users\ADMINI~1\AppData\Local\Temp\Intel®_Software_Installer_20240216133745_000_Pre_Install_rollback.log'
[1B88:2524][2024-02-16T13:37:51]i000: OnPlanPackageComplete: Execute=Install, PackageId=Pre_Install, Requested=Present, Rollback=Uninstall, State=Absent, Status=0
[1B88:2524][2024-02-16T13:37:51]i052: Condition 'WIFI_Driver_Install' evaluates to true.
[1B88:2524][2024-02-16T13:37:51]i000: OnPlanPackageBegin: PackageId=WIFI_Driver, Result=None, State=Present
[1B88:2524][2024-02-16T13:37:51]i000: PlanPackage(WIFI_Driver, Present)
[1B88:2524][2024-02-16T13:37:51]i000: Setting string variable 'WIFI_Driver_InstallCommand' to value '-i -l "[WixBundleLog_WIFI_Driver]" -pc "C:\ProgramData\Package Cache\{acc5d32f-fbf7-4d75-8943-2f70e698123d}\InstalledPackages.xml" -pi "WIFI_Driver" -f "'Components\WiFiDriver\Netwtw04.INF','Components\WiFiDriver\Netwtw08.INF','Components\WiFiDriver\Netwtw6e.INF'"'
[1B88:2524][2024-02-16T13:37:51]i000: Setting string variable 'WIFI_Driver_RepairCommand' to value '-r -l "[WixBundleLog_WIFI_Driver]" -pc "C:\ProgramData\Package Cache\{acc5d32f-fbf7-4d75-8943-2f70e698123d}\InstalledPackages.xml" -pi "WIFI_Driver" -f "'Components\WiFiDriver\Netwtw04.INF','Components\WiFiDriver\Netwtw08.INF','Components\WiFiDriver\Netwtw6e.INF'"'
[1B88:2524][2024-02-16T13:37:51]i000: Setting string variable 'WIFI_Driver_UninstallCommand' to value '-u -l "[WixBundleLog_WIFI_Driver]" -pc "C:\ProgramData\Package Cache\{acc5d32f-fbf7-4d75-8943-2f70e698123d}\InstalledPackages.xml" -pi "WIFI_Driver" -f "'Components\WiFiDriver\Netwtw04.INF','Components\WiFiDriver\Netwtw08.INF','Components\WiFiDriver\Netwtw6e.INF'"'
[1B88:2524][2024-02-16T13:37:51]w321: Skipping dependency registration on package with no dependency providers: WIFI_Driver
[1B88:2524][2024-02-16T13:37:51]i000: Setting string variable 'WixBundleLog_WIFI_Driver' to value 'C:\Users\ADMINI~1\AppData\Local\Temp\Intel®_Software_Installer_20240216133745_001_WIFI_Driver.log'
[1B88:2524][2024-02-16T13:37:51]i000: Setting string variable 'WixBundleRollbackLog_WIFI_Driver' to value 'C:\Users\ADMINI~1\AppData\Local\Temp\Intel®_Software_Installer_20240216133745_001_WIFI_Driver_rollback.log'
[1B88:2524][2024-02-16T13:37:51]i000: OnPlanPackageComplete: Execute=Install, PackageId=WIFI_Driver, Requested=Present, Rollback=Uninstall, State=Absent, Status=0
[1B88:2524][2024-02-16T13:37:51]i000: OnPlanPackageBegin: PackageId=DocsManager, Result=None, State=Present
[1B88:2524][2024-02-16T13:37:51]i000: PlanPackage(DocsManager, Present)
[1B88:2524][2024-02-16T13:37:51]i000: Setting string variable 'WixBundleRollbackLog_DocsManager' to value 'C:\Users\ADMINI~1\AppData\Local\Temp\Intel®_Software_Installer_20240216133745_002_DocsManager_rollback.log'
[1B88:2524][2024-02-16T13:37:51]i000: Setting string variable 'WixBundleLog_DocsManager' to value 'C:\Users\ADMINI~1\AppData\Local\Temp\Intel®_Software_Installer_20240216133745_002_DocsManager.log'
[1B88:2524][2024-02-16T13:37:51]i000: OnPlanPackageComplete: Execute=Install, PackageId=DocsManager, Requested=Present, Rollback=Uninstall, State=Absent, Status=0
[1B88:2524][2024-02-16T13:37:51]i201: Planned package: NetFx462Web, state: Present, default requested: Present, ba requested: None, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1B88:2524][2024-02-16T13:37:51]i201: Planned package: Pre_Install, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: Yes, dependency: None
[1B88:2524][2024-02-16T13:37:51]i201: Planned package: WIFI_Driver, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: Yes, dependency: None
[1B88:2524][2024-02-16T13:37:51]i201: Planned package: DocsManager, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[1B88:2524][2024-02-16T13:37:51]i000: OnPlanComplete: Status=0
[1B88:2524][2024-02-16T13:37:51]i299: Plan complete, result: 0x0
[1B88:2524][2024-02-16T13:37:51]i300: Apply begin
[1B88:2524][2024-02-16T13:37:51]i000: OnApplyBegin: Result=None
[1B88:2524][2024-02-16T13:37:51]i000: OnElevate
[1B88:2524][2024-02-16T13:37:51]i010: Launching elevated engine process.
[1B88:2524][2024-02-16T13:37:51]i011: Launched elevated engine process.
[1B88:2524][2024-02-16T13:37:52]i012: Connected to elevated engine.
[33E4:2638][2024-02-16T13:37:52]i358: Pausing automatic updates.
[33E4:2638][2024-02-16T13:37:52]i359: Paused automatic updates.
[33E4:2638][2024-02-16T13:37:52]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{acc5d32f-fbf7-4d75-8943-2f70e698123d}, options: 0x7, disable resume: No
[33E4:2638][2024-02-16T13:37:52]i000: Caching bundle from: 'C:\Windows\Temp\{E7EE0EB3-A4C1-46C1-B32A-C27AE9649363}\.be\WirelessSetup.exe' to: 'C:\ProgramData\Package Cache\{acc5d32f-fbf7-4d75-8943-2f70e698123d}\WirelessSetup.exe'
[33E4:2638][2024-02-16T13:37:52]i320: Registering bundle dependency provider: {acc5d32f-fbf7-4d75-8943-2f70e698123d}, version: 23.20.0.4
[33E4:2638][2024-02-16T13:37:52]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{acc5d32f-fbf7-4d75-8943-2f70e698123d}, resume: Active, restart initiated: No, disable resume: No
[1B88:2AE0][2024-02-16T13:37:52]i000: OnCacheBegin: Result=None
[1B88:2AE0][2024-02-16T13:37:52]i000: OnCachePackageBegin: CachePayloads=3, PackageCacheSize=140040, PackageId=Pre_Install, Result=None
[1B88:2AE0][2024-02-16T13:37:53]i000: OnCacheVerifyBegin: PackageId=Pre_Install, PayloadId=Pre_Install, Result=None
[33E4:1774][2024-02-16T13:37:53]i305: Verified acquired payload: Pre_Install at path: C:\ProgramData\Package Cache\.unverified\Pre_Install, moving to: C:\ProgramData\Package Cache\3B0D3FD8D9482E8C2949C544E4BB696AAE6429BF\BootstrapperUtilityApp.exe.
[1B88:2AE0][2024-02-16T13:37:53]i000: OnCacheVerifyComplete: PackageId=Pre_Install, PayloadId=Pre_Install, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:53]i000: OnCacheVerifyBegin: PackageId=Pre_Install, PayloadId=Pre_Install_CommonUtils, Result=None
[33E4:1774][2024-02-16T13:37:53]i305: Verified acquired payload: Pre_Install_CommonUtils at path: C:\ProgramData\Package Cache\.unverified\Pre_Install_CommonUtils, moving to: C:\ProgramData\Package Cache\3B0D3FD8D9482E8C2949C544E4BB696AAE6429BF\CommonUtils.dll.
[1B88:2AE0][2024-02-16T13:37:53]i000: OnCacheVerifyComplete: PackageId=Pre_Install, PayloadId=Pre_Install_CommonUtils, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:53]i000: OnCacheVerifyBegin: PackageId=Pre_Install, PayloadId=Pre_Install_UWDBootstrapper_Common, Result=None
[33E4:1774][2024-02-16T13:37:53]i305: Verified acquired payload: Pre_Install_UWDBootstrapper_Common at path: C:\ProgramData\Package Cache\.unverified\Pre_Install_UWDBootstrapper_Common, moving to: C:\ProgramData\Package Cache\3B0D3FD8D9482E8C2949C544E4BB696AAE6429BF\UWDBootstrapper_Common.dll.
[1B88:2AE0][2024-02-16T13:37:53]i000: OnCacheVerifyComplete: PackageId=Pre_Install, PayloadId=Pre_Install_UWDBootstrapper_Common, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:53]i000: OnCachePackageComplete: PackageId=Pre_Install, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:53]i000: OnCachePackageBegin: CachePayloads=22, PackageCacheSize=93420071, PackageId=WIFI_Driver, Result=None
[1B88:2AE0][2024-02-16T13:37:53]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=WIFI_Driver, Result=None
[33E4:1774][2024-02-16T13:37:53]i305: Verified acquired payload: WIFI_Driver at path: C:\ProgramData\Package Cache\.unverified\WIFI_Driver, moving to: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\PnPInstaller.exe.
[1B88:2AE0][2024-02-16T13:37:53]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=WIFI_Driver, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:53]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=WIFI_Driver_CommonUtils, Result=None
[33E4:1774][2024-02-16T13:37:53]i305: Verified acquired payload: WIFI_Driver_CommonUtils at path: C:\ProgramData\Package Cache\.unverified\WIFI_Driver_CommonUtils, moving to: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\CommonUtils.dll.
[1B88:2AE0][2024-02-16T13:37:53]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=WIFI_Driver_CommonUtils, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:53]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=WIFI_Driver_UWDBootstrapper_Common, Result=None
[33E4:1774][2024-02-16T13:37:53]i305: Verified acquired payload: WIFI_Driver_UWDBootstrapper_Common at path: C:\ProgramData\Package Cache\.unverified\WIFI_Driver_UWDBootstrapper_Common, moving to: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\UWDBootstrapper_Common.dll.
[1B88:2AE0][2024-02-16T13:37:53]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=WIFI_Driver_UWDBootstrapper_Common, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:53]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay0C25D2615A12278D5763CD1450B31A64, Result=None
[33E4:1774][2024-02-16T13:37:53]i305: Verified acquired payload: pay0C25D2615A12278D5763CD1450B31A64 at path: C:\ProgramData\Package Cache\.unverified\pay0C25D2615A12278D5763CD1450B31A64, moving to: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\Components\WiFiDriver\netwtw6e.cat.
[1B88:2AE0][2024-02-16T13:37:53]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay0C25D2615A12278D5763CD1450B31A64, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:53]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay0FF28B755EE810BF09AF2DC94EDB160A, Result=None
[33E4:1774][2024-02-16T13:37:54]i305: Verified acquired payload: pay0FF28B755EE810BF09AF2DC94EDB160A at path: C:\ProgramData\Package Cache\.unverified\pay0FF28B755EE810BF09AF2DC94EDB160A, moving to: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\Components\WiFiDriver\IntelIhvRouter14.dll.
[1B88:2AE0][2024-02-16T13:37:54]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay0FF28B755EE810BF09AF2DC94EDB160A, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:54]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay2E00116BC3BE97F8BD632F3E1FA1AA58, Result=None
[33E4:1774][2024-02-16T13:37:54]i305: Verified acquired payload: pay2E00116BC3BE97F8BD632F3E1FA1AA58 at path: C:\ProgramData\Package Cache\.unverified\pay2E00116BC3BE97F8BD632F3E1FA1AA58, moving to: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\Components\WiFiDriver\NETwtw04.sys.
[1B88:2AE0][2024-02-16T13:37:54]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay2E00116BC3BE97F8BD632F3E1FA1AA58, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:54]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay3064279EBC4A1EF27E2EB10F6A527A4D, Result=None
[33E4:1774][2024-02-16T13:37:54]i305: Verified acquired payload: pay3064279EBC4A1EF27E2EB10F6A527A4D at path: C:\ProgramData\Package Cache\.unverified\pay3064279EBC4A1EF27E2EB10F6A527A4D, moving to: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\Components\WiFiDriver\netwtw08.cat.
[1B88:2AE0][2024-02-16T13:37:54]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay3064279EBC4A1EF27E2EB10F6A527A4D, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:54]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay360CBBD7F5950F50C4DABA99CD03F476, Result=None
[33E4:1774][2024-02-16T13:37:54]i305: Verified acquired payload: pay360CBBD7F5950F50C4DABA99CD03F476 at path: C:\ProgramData\Package Cache\.unverified\pay360CBBD7F5950F50C4DABA99CD03F476, moving to: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\Components\WiFiDriver\Netwfw14.dat.
[1B88:2AE0][2024-02-16T13:37:54]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay360CBBD7F5950F50C4DABA99CD03F476, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:54]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay4D413FBE1CBF82247552AC5417955D25, Result=None
[33E4:1774][2024-02-16T13:37:54]i305: Verified acquired payload: pay4D413FBE1CBF82247552AC5417955D25 at path: C:\ProgramData\Package Cache\.unverified\pay4D413FBE1CBF82247552AC5417955D25, moving to: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\Components\WiFiDriver\IntelIhvRouter08.dll.
[1B88:2AE0][2024-02-16T13:37:54]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay4D413FBE1CBF82247552AC5417955D25, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:54]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay59E129C94760DB7479DD6F0720605C09, Result=None
[33E4:1774][2024-02-16T13:37:54]i305: Verified acquired payload: pay59E129C94760DB7479DD6F0720605C09 at path: C:\ProgramData\Package Cache\.unverified\pay59E129C94760DB7479DD6F0720605C09, moving to: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\Components\WiFiDriver\NETwtw10.sys.
[1B88:2AE0][2024-02-16T13:37:54]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay59E129C94760DB7479DD6F0720605C09, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:54]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay696167ED591B22AA84989DAB29CE917F, Result=None
[33E4:1774][2024-02-16T13:37:54]i305: Verified acquired payload: pay696167ED591B22AA84989DAB29CE917F at path: C:\ProgramData\Package Cache\.unverified\pay696167ED591B22AA84989DAB29CE917F, moving to: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\Components\WiFiDriver\NETwtw14.sys.
[1B88:2AE0][2024-02-16T13:37:54]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay696167ED591B22AA84989DAB29CE917F, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:54]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay8D9E4AF1454298074121A23DDA80A78F, Result=None
[33E4:1774][2024-02-16T13:37:54]i305: Verified acquired payload: pay8D9E4AF1454298074121A23DDA80A78F at path: C:\ProgramData\Package Cache\.unverified\pay8D9E4AF1454298074121A23DDA80A78F, moving to: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\Components\WiFiDriver\NETwtw08.sys.
[1B88:2AE0][2024-02-16T13:37:54]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay8D9E4AF1454298074121A23DDA80A78F, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:54]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay8E53BAC9ABE5083D447AF8CC32EBEF1A, Result=None
[33E4:1774][2024-02-16T13:37:54]i305: Verified acquired payload: pay8E53BAC9ABE5083D447AF8CC32EBEF1A at path: C:\ProgramData\Package Cache\.unverified\pay8E53BAC9ABE5083D447AF8CC32EBEF1A, moving to: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\Components\WiFiDriver\Netwfw04.dat.
[1B88:2AE0][2024-02-16T13:37:54]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay8E53BAC9ABE5083D447AF8CC32EBEF1A, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:54]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay8F34AB9DFA504E7DEE5B65A1F53E2D39, Result=None
[33E4:1774][2024-02-16T13:37:55]i305: Verified acquired payload: pay8F34AB9DFA504E7DEE5B65A1F53E2D39 at path: C:\ProgramData\Package Cache\.unverified\pay8F34AB9DFA504E7DEE5B65A1F53E2D39, moving to: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\Components\WiFiDriver\IntelIhvRouter04.dll.
[1B88:2AE0][2024-02-16T13:37:55]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay8F34AB9DFA504E7DEE5B65A1F53E2D39, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:55]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay912AD28B15A7B5DB271B91F2CDAA9D42, Result=None
[33E4:1774][2024-02-16T13:37:55]i305: Verified acquired payload: pay912AD28B15A7B5DB271B91F2CDAA9D42 at path: C:\ProgramData\Package Cache\.unverified\pay912AD28B15A7B5DB271B91F2CDAA9D42, moving to: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\Components\WiFiDriver\IntelIhvRouter10.dll.
[1B88:2AE0][2024-02-16T13:37:55]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay912AD28B15A7B5DB271B91F2CDAA9D42, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:55]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay91CFF053EB3406BE63AE27E4355ECE18, Result=None
[33E4:1774][2024-02-16T13:37:55]i305: Verified acquired payload: pay91CFF053EB3406BE63AE27E4355ECE18 at path: C:\ProgramData\Package Cache\.unverified\pay91CFF053EB3406BE63AE27E4355ECE18, moving to: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\Components\WiFiDriver\Netwtw04.INF.
[1B88:2AE0][2024-02-16T13:37:55]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay91CFF053EB3406BE63AE27E4355ECE18, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:55]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payB03F62838E7EAEDCA6261A8E61C1A59D, Result=None
[33E4:1774][2024-02-16T13:37:55]i305: Verified acquired payload: payB03F62838E7EAEDCA6261A8E61C1A59D at path: C:\ProgramData\Package Cache\.unverified\payB03F62838E7EAEDCA6261A8E61C1A59D, moving to: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\Components\WiFiDriver\Netwfw08.dat.
[1B88:2AE0][2024-02-16T13:37:55]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payB03F62838E7EAEDCA6261A8E61C1A59D, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:55]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payB07C5469F61D63EBCED3FF07F7D6B1A6, Result=None
[33E4:1774][2024-02-16T13:37:55]i305: Verified acquired payload: payB07C5469F61D63EBCED3FF07F7D6B1A6 at path: C:\ProgramData\Package Cache\.unverified\payB07C5469F61D63EBCED3FF07F7D6B1A6, moving to: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\Components\WiFiDriver\Netwtw08.INF.
[1B88:2AE0][2024-02-16T13:37:55]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payB07C5469F61D63EBCED3FF07F7D6B1A6, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:55]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payBCCAFF4A57CDE9BA3DE76ED30D6B45B4, Result=None
[33E4:1774][2024-02-16T13:37:55]i305: Verified acquired payload: payBCCAFF4A57CDE9BA3DE76ED30D6B45B4 at path: C:\ProgramData\Package Cache\.unverified\payBCCAFF4A57CDE9BA3DE76ED30D6B45B4, moving to: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\Components\WiFiDriver\NETwaw14.sys.
[1B88:2AE0][2024-02-16T13:37:55]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payBCCAFF4A57CDE9BA3DE76ED30D6B45B4, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:55]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payCE14E16746815B310C278509CBA931AC, Result=None
[33E4:1774][2024-02-16T13:37:55]i305: Verified acquired payload: payCE14E16746815B310C278509CBA931AC at path: C:\ProgramData\Package Cache\.unverified\payCE14E16746815B310C278509CBA931AC, moving to: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\Components\WiFiDriver\Netwfw10.dat.
[1B88:2AE0][2024-02-16T13:37:55]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payCE14E16746815B310C278509CBA931AC, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:55]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payDD4BCF2159AE54A08B411659BBBD0BB7, Result=None
[33E4:1774][2024-02-16T13:37:55]i305: Verified acquired payload: payDD4BCF2159AE54A08B411659BBBD0BB7 at path: C:\ProgramData\Package Cache\.unverified\payDD4BCF2159AE54A08B411659BBBD0BB7, moving to: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\Components\WiFiDriver\Netwtw6e.INF.
[1B88:2AE0][2024-02-16T13:37:55]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payDD4BCF2159AE54A08B411659BBBD0BB7, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:55]i000: OnCacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payFC6C5A6444F9C7E4A6F25D37020BB4EB, Result=None
[33E4:1774][2024-02-16T13:37:55]i305: Verified acquired payload: payFC6C5A6444F9C7E4A6F25D37020BB4EB at path: C:\ProgramData\Package Cache\.unverified\payFC6C5A6444F9C7E4A6F25D37020BB4EB, moving to: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\Components\WiFiDriver\netwtw04.cat.
[1B88:2AE0][2024-02-16T13:37:55]i000: OnCacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payFC6C5A6444F9C7E4A6F25D37020BB4EB, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:55]i000: OnCachePackageComplete: PackageId=WIFI_Driver, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:55]i000: OnCachePackageBegin: CachePayloads=1, PackageCacheSize=3985408, PackageId=DocsManager, Result=None
[1B88:2AE0][2024-02-16T13:37:55]i000: OnCacheVerifyBegin: PackageId=DocsManager, PayloadId=DocsManager, Result=None
[33E4:1774][2024-02-16T13:37:56]i304: Verified existing payload: DocsManager at path: C:\ProgramData\Package Cache\{C8ACA6BC-A7AF-4FAA-AE86-90E4AB2535C4}v23.20.0.4\DocsManager.msi.
[1B88:2AE0][2024-02-16T13:37:56]i000: OnCacheVerifyComplete: PackageId=DocsManager, PayloadId=DocsManager, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:56]i000: OnCachePackageComplete: PackageId=DocsManager, Result=None, Status=0
[1B88:2AE0][2024-02-16T13:37:56]i000: OnCacheComplete: Status=0
[1B88:2524][2024-02-16T13:37:56]i000: OnExecuteBegin: PackageCount=3, Result=None
[1B88:2524][2024-02-16T13:37:56]i000: OnExecutePackageBegin: PackageId=Pre_Install, Result=None, ShouldExecute=True
[1B88:2524][2024-02-16T13:37:56]i000: OnExecuteProgress: OverallPercentage=0, PackageId=Pre_Install, ProgressPercentage=0, Result=None
[33E4:2638][2024-02-16T13:37:56]i301: Applying execute package: Pre_Install, action: Install, path: C:\ProgramData\Package Cache\3B0D3FD8D9482E8C2949C544E4BB696AAE6429BF\BootstrapperUtilityApp.exe, arguments: '"C:\ProgramData\Package Cache\3B0D3FD8D9482E8C2949C544E4BB696AAE6429BF\BootstrapperUtilityApp.exe" -preinstall -b "C:\Windows\Temp\{34ED47C7-A93B-4E8D-89DB-BF46C6A1D18E}\WirelessSetup.exe" -c "C:\ProgramData\Package Cache\{acc5d32f-fbf7-4d75-8943-2f70e698123d}" -pc "C:\ProgramData\Package Cache\{acc5d32f-fbf7-4d75-8943-2f70e698123d}\InstalledPackages.xml" -l "C:\Users\ADMINI~1\AppData\Local\Temp\Intel®_Software_Installer_20240216133745_000_Pre_Install.log" -ip WIFI_Driver -mp DocsManager '
[1B88:2524][2024-02-16T13:37:56]i000: OnExecuteProgress: OverallPercentage=16, PackageId=Pre_Install, ProgressPercentage=50, Result=None
[1B88:2524][2024-02-16T13:37:56]i000: OnExecuteProgress: OverallPercentage=33, PackageId=Pre_Install, ProgressPercentage=100, Result=None
[1B88:2524][2024-02-16T13:37:56]i000: OnExecutePackageComplete: PackageId=Pre_Install, Restart=None, Result=None, Status=0
[1B88:2524][2024-02-16T13:37:56]i319: Applied execute package: Pre_Install, result: 0x0, restart: None
[1B88:2524][2024-02-16T13:37:56]i000: OnExecutePackageBegin: PackageId=WIFI_Driver, Result=None, ShouldExecute=True
[1B88:2524][2024-02-16T13:37:56]i000: OnExecuteProgress: OverallPercentage=33, PackageId=WIFI_Driver, ProgressPercentage=0, Result=None
[33E4:2638][2024-02-16T13:37:56]i301: Applying execute package: WIFI_Driver, action: Install, path: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\PnPInstaller.exe, arguments: '"C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\PnPInstaller.exe" -i -l "C:\Users\ADMINI~1\AppData\Local\Temp\Intel®_Software_Installer_20240216133745_001_WIFI_Driver.log" -pc "C:\ProgramData\Package Cache\{acc5d32f-fbf7-4d75-8943-2f70e698123d}\InstalledPackages.xml" -pi "WIFI_Driver" -f "'Components\WiFiDriver\Netwtw04.INF','Components\WiFiDriver\Netwtw08.INF','Components\WiFiDriver\Netwtw6e.INF'"'
[1B88:2524][2024-02-16T13:37:56]i000: OnExecuteProgress: OverallPercentage=50, PackageId=WIFI_Driver, ProgressPercentage=50, Result=None
[1B88:2524][2024-02-16T13:37:57]i000: OnExecuteProgress: OverallPercentage=50, PackageId=WIFI_Driver, ProgressPercentage=50, Result=None
[1B88:2524][2024-02-16T13:37:58]i000: OnExecuteProgress: OverallPercentage=50, PackageId=WIFI_Driver, ProgressPercentage=50, Result=None
[1B88:2524][2024-02-16T13:37:59]i000: OnExecuteProgress: OverallPercentage=50, PackageId=WIFI_Driver, ProgressPercentage=50, Result=None
[1B88:2524][2024-02-16T13:38:00]i000: OnExecuteProgress: OverallPercentage=50, PackageId=WIFI_Driver, ProgressPercentage=50, Result=None
[33E4:2638][2024-02-16T13:38:00]e000: Error 0x80070001: Process returned error: 0x1
[33E4:2638][2024-02-16T13:38:00]e000: Error 0x80070001: Failed to execute EXE package.
[1B88:2524][2024-02-16T13:38:00]e000: Error 0x80070001: Failed to configure per-machine EXE package.
[1B88:2524][2024-02-16T13:38:00]i000: OnExecutePackageComplete: PackageId=WIFI_Driver, Restart=None, Result=None, Status=-2147024895
[1B88:2524][2024-02-16T13:38:00]i319: Applied execute package: WIFI_Driver, result: 0x80070001, restart: None
[1B88:2524][2024-02-16T13:38:00]e000: Error 0x80070001: Failed to execute EXE package.
[33E4:2638][2024-02-16T13:38:00]i351: Removing cached package: WIFI_Driver, from path: C:\ProgramData\Package Cache\1C459494C11AD680FEC94CF67558564047D1CE47\
[1B88:2524][2024-02-16T13:38:00]i000: OnExecutePackageBegin: PackageId=Pre_Install, Result=None, ShouldExecute=False
[1B88:2524][2024-02-16T13:38:00]i000: OnExecuteProgress: OverallPercentage=66, PackageId=Pre_Install, ProgressPercentage=100, Result=None
[33E4:2638][2024-02-16T13:38:00]i301: Applying rollback package: Pre_Install, action: Uninstall, path: C:\ProgramData\Package Cache\3B0D3FD8D9482E8C2949C544E4BB696AAE6429BF\BootstrapperUtilityApp.exe, arguments: '"C:\ProgramData\Package Cache\3B0D3FD8D9482E8C2949C544E4BB696AAE6429BF\BootstrapperUtilityApp.exe" -l "C:\Users\ADMINI~1\AppData\Local\Temp\Intel®_Software_Installer_20240216133745_000_Pre_Install.log"'
[1B88:2524][2024-02-16T13:38:00]i000: OnExecuteProgress: OverallPercentage=50, PackageId=Pre_Install, ProgressPercentage=50, Result=None
[1B88:2524][2024-02-16T13:38:00]i000: OnExecuteProgress: OverallPercentage=33, PackageId=Pre_Install, ProgressPercentage=0, Result=None
[1B88:2524][2024-02-16T13:38:00]i000: OnExecutePackageComplete: PackageId=Pre_Install, Restart=None, Result=None, Status=0
[1B88:2524][2024-02-16T13:38:00]i319: Applied rollback package: Pre_Install, result: 0x0, restart: None
[33E4:2638][2024-02-16T13:38:00]i351: Removing cached package: Pre_Install, from path: C:\ProgramData\Package Cache\3B0D3FD8D9482E8C2949C544E4BB696AAE6429BF\
[1B88:2524][2024-02-16T13:38:00]i000: OnExecuteComplete: Status=-2147024895
[33E4:2638][2024-02-16T13:38:00]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{acc5d32f-fbf7-4d75-8943-2f70e698123d}, resume: None, restart: None, disable resume: No
[33E4:2638][2024-02-16T13:38:00]i330: Removed bundle dependency provider: {acc5d32f-fbf7-4d75-8943-2f70e698123d}
[33E4:2638][2024-02-16T13:38:00]i352: Removing cached bundle: {acc5d32f-fbf7-4d75-8943-2f70e698123d}, from path: C:\ProgramData\Package Cache\{acc5d32f-fbf7-4d75-8943-2f70e698123d}\
[33E4:2638][2024-02-16T13:38:00]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{acc5d32f-fbf7-4d75-8943-2f70e698123d}, resume: None, restart initiated: No, disable resume: No
[1B88:2524][2024-02-16T13:38:00]i000: OnApplyComplete: Restart=None, Result=None, Status=-2147024895
[1B88:2524][2024-02-16T13:38:00]i000: Setting ReturnCode to ERROR
[1B88:2524][2024-02-16T13:38:00]i399: Apply complete, result: 0x80070001, restart: None, ba requested restart: No
[1B88:3254][2024-02-16T13:38:02]i000: LogFolderLink_RequestNavigate()
Hi, SataMao.
Thank you for posting in our Intel communities.
I would like to know the following:
- When did the error message, "A service installation section in this INF is invalid." occur?
- Is the system working before and no error messages in Windows Server 2022 version?
Morover, If you have done any steps to fix this issue before contacting us please give me those details so we don't repeat any unnecessary steps.
Von M.
Hi, SataMao.
I hope you are doing fine.
Kindly let us know if you still need assistance.
Von M.
Hi, SataMao.
I trust you're doing well.
I have not heard back from you we will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
