Wireless
9042 Discussions
Sound problems with equalizer
Barsik346
Hello. I'm a newbie having Intel components, and I'm facing a problem with sound. The problem is that the sound "wheezes" when the equalizer is turned on. Below I added pictures with available devices characteristics. I tried to update the drivers for bluetooth equipment, rebooted the device, but the problem remained. This is not a problem in the headphones or the equalizer (Equalizer APO). On my other device the equalizer works great, without interference. The only thing is that that device did not have a built-in bluetooth adapter. Has anyone encountered this problem or maybe knows how to solve it? Thanks in advance for responding to help!
[changed]
I have added a .txt document of the Intel System Support Utility output
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[Fear and the desire for control are primary motivators for shadow dwellers. ]
