Wireless
8874 Discussions
latest driver 23.80.1.3 causing issues on Intel(R) Wi-Fi 6 AX201 160MHz
NickSC
the latest driver 23.80.1.3 causing issues on (my) Intel(R) Wi-Fi 6 AX201 160MHz.
This is info just to say , after installing I couldn't log into any of my online gaming. World of Warcraft , Diablo IV, and Second Life would either not even connect at the very start or connect and be very very slow or freezing, and ultimately disconnecting and in the case of SL disconnecting my Wi-fi.
I managed to roll back to 23.70.2  and everything is working as it was a week ago before I installed 2380.1.3.
JK747
Hi NickSC , indeed this release has some bugs in the connection sequence.  I can no longer connect to open unencrypted Wifi networks with this driver.   I will also attempt to rollback to a previous release.
