Wireless
8697 Discussions
Suddenly wifi (AX211) is unstable and crashes after suspend/resume on Linux
klausagnoletti
I have a Samsung Galaxy Book 2 pro with AX211 running Linux. It has done so for the last two years with various distros. No problems what so ever. Until a couple of weeks ago..
First symptom I saw was that there was no wifi but later managed to get it back. Then I reinstalled to Omarchy Linux trying virtually all kernel versions from 6.7 - 6.17. Same problem on all:
- Wifi crashes randomly
- And if it hasn't died already, it will crash after suspension/resume (Not when just doing S2idle but deeper than that).
I have attached a couple of different dmesg log along with other relevant information about the distro and kernel which I hope will provide the information needed to identify the issue - and fix it.
Thanks!
/klaus
klausagnoletti
Here's a full kernel log from the system I'm currently using running 6.17.6. The others are just excempts.
JeanetteC_Intel
Hello klausagnoletti,
Before proceeding with the investigation, I need to verify the following:
These details, along with your dmesg logs, will enable a thorough analysis of the random WiFi crashes and suspend/resume problems you're experiencing.
Best regards
JeanetteC.
klausagnoletti
Hi Jeanette and thanks for your reply.
Yes, AX211 is built-in on my laptop. As a temp workaround I've been using a realtek usb wifi thingy so you'll see that in my log too. Just ignore that.
**bleep** I look forward to hearing your verdict. The current state is quite crippling.
/k
JeanetteC_Intel
Thanks for verifying the AX211 configuration and providing the SSU log. analyze the log data and follow up with our assessment and suggested solutions for the connectivity issues.
Best regards
JeanetteC.
klausagnoletti
Hi Jeanette
Reading your reply I’m a little unsure whether you need anything else from me. I don’t think so but please let me know if I’m wrong
klausagnoletti
@JeanetteC_Intel Could you please give me a reply and a heads up on the status and what I can expect, in terms of timeline for a fix? I am really sick of the current situation so really looking forward to an improvement.
Thanks!
/k
JeanetteC_Intel
Thank you for contacting us. I completely understand your urgency to get this issue resolved, and we're dedicated to finding a solution for you.
To provide you with an accurate status update and timeline, I need to examine logs containing sensitive personal data. For privacy and security protection, we should move our discussion to email rather than continuing on this public platform.
I'll be sending you a direct email momentarily to discuss the specifics of your case and give you a detailed resolution timeline. Please monitor your inbox and also check your spam/junk folders in case the email gets filtered there.
I appreciate your patience and am committed to resolving this matter swiftly.
JeanetteC.
JeanetteC_Intel
Did you have a chance to review the previous post and email?
Please feel free to reach out if you have any questions.
JeanetteC.
klausagnoletti
Sorry but I just saw the email now as it had ended up in my spam folder and I saw it completely by incident
I'll reply to it right away.
JeanetteC_Intel
Thank you for letting me know! No worries about the delay - emails do sometimes end up in spam folders.
I'll wait for your update via email, and we can proceed from there.
JeanetteC.
JonathanMergy
I can confirm this is happening as well recently for me.
AX211 in a Lenovo Thinkpad X1 Carbon Gen 12 running Linux Mint 22
Linux 6.14.0-1018-oem #18-Ubuntu SMP PREEMPT_DYNAMIC Wed Dec 10 09:33:29 UTC 2025 x86_64 x86_64 x86_64 GNU/Linux
Tried all purges of settings and bluetooth packages along with device resets, etc. The only fix has been to go with a USB bluetooth adapter and I've been solid for the last week since I did that after a month of trying to get the AX211 BT stable again. It had been for a long time.
I've tried various kernels and latest linux-firmware at https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/ and even older linux-firmware from August 2025 in the hopes that whatever changes were made could have been avoided. No dice. I'm bypassing it now for sanity sake. But, seems like something that should be able to continue to work but it's not.
[ 1.233212] intel_pstate: Intel P-state driver initializing
[ 1.235387] intel_pstate: HWP enabled
[ 1.437521] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[ 1.456614] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[ 18.244143] intel_vsec 0000:00:0a.0: enabling device (0000 -> 0002)
[ 18.312880] intel_pmc_core INT33A1:00: Assuming a default substate order for this platform
[ 18.313017] intel_pmc_core INT33A1:00: initialized
[ 18.315363] intel_vpu 0000:00:0b.0: enabling device (0000 -> 0002)
[ 18.317134] intel-ipu6 0000:00:05.0: enabling device (0000 -> 0002)
[ 18.324532] intel_vpu 0000:00:0b.0: [drm] Firmware: intel/vpu/vpu_37xx_v1.bin, version: 20251016*MTL_CLIENT_SILICON-release*1600*ci_tag_ud202544_vpu_rc_20251016_1600*74b0ef77ba8
[ 18.324536] intel_vpu 0000:00:0b.0: [drm] Scheduler mode: OS
[ 18.346537] intel-ipu6 0000:00:05.0: Found supported sensor OVTI08F4:00
[ 18.346694] intel-ipu6 0000:00:05.0: Connected 1 cameras
[ 18.353693] intel-ipu6 0000:00:05.0: Sending BOOT_LOAD to CSE
[ 18.393750] intel-ipu6 0000:00:05.0: Sending AUTHENTICATE_RUN to CSE
[ 18.406162] intel_rapl_common: Found RAPL domain package
[ 18.449457] intel-ipu6 0000:00:05.0: CSE authenticate_run done
[ 18.449463] intel-ipu6 0000:00:05.0: IPU6-v4[7d19] hardware version 6
[ 18.505698] [drm] Initialized intel_vpu 1.0.0 for 0000:00:0b.0 on minor 0
[ 18.826049] intel_rapl_msr: PL4 support detected.
[ 18.826278] intel_rapl_common: Found RAPL domain package
[ 18.826281] intel_rapl_common: Found RAPL domain core
[ 18.826283] intel_rapl_common: Found RAPL domain psys
[ 18.834004] snd_hda_intel 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 18.852261] Bluetooth: hci0: Found device firmware: intel/ibt-0180-0041.sfi
[ 18.934097] intel_ipu6_psys.psys intel_ipu6.psys.40: pkg_dir entry count:8
[ 18.935770] intel_ipu6_psys.psys intel_ipu6.psys.40: psys probe minor: 0
[ 19.034454] sof-audio-pci-intel-mtl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040380
[ 19.110316] sof-audio-pci-intel-mtl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 19.117030] sof-audio-pci-intel-mtl 0000:00:1f.3: use msi interrupt mode
[ 19.140457] sof-audio-pci-intel-mtl 0000:00:1f.3: hda codecs found, mask 5
[ 19.140466] sof-audio-pci-intel-mtl 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
[ 19.140468] sof-audio-pci-intel-mtl 0000:00:1f.3: NHLT device BT(0) detected, ssp_mask 0x4
[ 19.140470] sof-audio-pci-intel-mtl 0000:00:1f.3: BT link detected in NHLT tables: 0x4
[ 19.140472] sof-audio-pci-intel-mtl 0000:00:1f.3: DMICs detected in NHLT tables: 2
[ 19.146085] sof-audio-pci-intel-mtl 0000:00:1f.3: Firmware paths/files for ipc type 1:
[ 19.146090] sof-audio-pci-intel-mtl 0000:00:1f.3: Firmware file: intel/sof-ipc4/mtl/sof-mtl.ri
[ 19.146091] sof-audio-pci-intel-mtl 0000:00:1f.3: Firmware lib path: intel/sof-ipc4-lib/mtl
[ 19.146092] sof-audio-pci-intel-mtl 0000:00:1f.3: Topology file: intel/sof-ace-tplg/sof-hda-generic-2ch.tplg
[ 19.148770] sof-audio-pci-intel-mtl 0000:00:1f.3: Loaded firmware library: ADSPFW, version: 2.13.0.1
[ 19.339410] sof-audio-pci-intel-mtl 0000:00:1f.3: Booted firmware version: 2.13.0.1
[ 19.349556] sof-audio-pci-intel-mtl 0000:00:1f.3: Topology: ABI 3:29:1 Kernel ABI 3:23:1
[ 20.405940] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-0180-0041.ddc
[23618.820416] intel-ipu6 0000:00:05.0: IPU6 in secure mode
[23622.871390] intel_atomic_check+0x10f/0xbf0 [i915]
[67282.260961] intel-ipu6 0000:00:05.0: IPU6 in secure mode
[159234.848575] intel-ipu6 0000:00:05.0: IPU6 in secure mode
[244909.883994] intel-ipu6 0000:00:05.0: IPU6 in secure mode
klausagnoletti
Hey! Sorry to hear you have the same problem. But also happy as I just got an email from the intel team saying they don’t think it’s a driver issue but related to power management. So if nothing else we’re two to scratch our heads not understanding anything..
JonathanMergy
ha!
If it's not drivers, then maybe something can be corrected in BIOS? It's not any power management settings in Linux is it?
klausagnoletti
I did some research with Gemini at some point with the conclusion that it might be related to the various power states around suspend and resume. It ended up suggesting a ton of different things but nothing worked. Also I am NOT an expert in ACPI and power states so idk
JonathanMergy
I can tell you I looked into all my options in BIOS a while back to disable or whatever. I could see it could maybe be related to Intel CPU setting in BIOS? I can play with that I suppose. I am not doing really any granular power saving --usually full-tilt power performance mode when plugged-in on the laptop and docked, and that was fine for many months until the last few weeks.
I have done BIOS updates from Lenovo though and no one really knows what they do - the docs are very sparse. The AX211 linux-firmware drivers haven't really changed either in a long time although the linking in the /intel directory has shifted over the last few months to symlinks vs. specific files
ibt-0180-0041.sfi for example, is now getting linked to
which tells me, I think, that be referenced as a common driver for families of chips vs just the AX211
Back in August 2025 linux-firmware there is a different structure it seems where there are files for each separate device.
Yeah, I dunno. I just hope some updates can correct this. I'm out of ideas and the other bluetooth via USB is solid as this was a month or so ago.
klausagnoletti
Just to elaborate could you talk a abot about exactly what your problem is? How doesn't wifi work?
I thought it's easier to compare notes if we're completely certain that our problems are the same.
/k
JonathanMergy
Sure - not a full crash or drop on the wifi, but bluetooth does drop after suspend or even just after an extended period of time.
klausagnoletti
Allright. Thanks for the elboration. Truth be told I don’t know it bluetooth is affected since I don’t use it much. But I’ll investigate and let you know if I also have that problem.
klausagnoletti
@JeanetteC_Intel Could you please provide me more information on why you think this is a power management issue and not a driver issue? Whatever information you can provide makes it easier for me to find a solution. Since, you know, obviously I need this thing fixed no matter what the root cause is.
JonathanMergy
I have disabled Intel AMT in the BIOs and rolled back to an earlier version of linux-firmware for
ibt-0180-0041.ddc
so will see how it goes since Intel have been of zero help.
We'll see.
