- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
I’d like to report a recurring issue I experienced with my Windows 11 laptop (Intel Wi-Fi 6E AX211). Every time I put the system to sleep — whether manually or automatically — it would enter sleep mode briefly, then crash or shut down completely after a few minutes. I had to press the power button to restart, and the Event Viewer consistently showed Kernel-Power (ID 41) and EventLog (ID 6008) errors indicating unexpected shutdowns.
After extensive troubleshooting, I discovered that the issue was caused by the Intel® Connectivity Performance Suite (ICPS) and Intel® Connectivity Manager (ICM). Once I uninstalled both programs, the sleep function began working perfectly, even after 10–20 minutes, the system remains in sleep mode without crashing.
I believe these Intel utilities interfere with Modern Standby or power management, possibly by keeping network services active during sleep. I recommend investigating compatibility between ICPS/ICM and Intel AX211 drivers under Windows 11.
Let me know if you need logs or further details — I’d be happy to help.
Thanks!
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Swodniw,
- What is the brand and model of the system?
- When did you start having this issue?
- Did you change any settings before the issue started?
- Please send the logs or dump files that you have.
- Please help generate the SSU logs of your system for me to review the hardware and the installed drivers. Kindly refer to the link below for the steps.
Michael L.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
