Wireless
8787 Discussions
Toshiba Satellite C55-B5200
MTric
I down graded the Laptop from Windows 8.1 to Windows 7 32Bit. I Believe it has an Intel Wi-Fi Card but I can't locate the correct Driver.
ASouz7
mtricarico66,
In order for us to assist you properly we need to know the exact name of the Intel(R) Wireless Adapter you have, so we can check if there is any updated drivers for it in case you need to use the drivers in our support webpage, however, Intel recommends that you always use your OEM drivers. In this link you can find the contact number of your OEM ( TOSHIBA*) http://www.intel.com/support/oems.htm Computer Manufacturer Support
