Wireless
8695 Discussions
Trouble with 6ghz signal strength reporting with both a BE200 and ax210
M8kItWrk
Can't get my head around this one - hope you all can help, or maybe it's a bug?
I'm setting up a new wireless network (first Wifi 7 network for me) and now working to balance the AP transmits for smooth roaming.  2.4 ghz & 5 ghz - no problem, smooth as butter across bands and AP's; 6 ghz band also fine.... on an Android and iOS device.  I have a laptop with a BE200 card (updated Win 11, latest drivers, no band preferences set) I'm using for the survey, hit bad roaming decisions with the 6 ghz band, and added a different device with an ax210 card to my testing (also updated & latest drivers, no band preferences).  Both have the exact same issue, are <1 year old, w/o other issues; that said, they both otherwise operate in a non-6 ghz network so this could have been lurking undiscovered.
Connected to any of the three AP's, the 6 ghz signal is measuring ~10 dbm stronger by the intel cards than I expect and compared to the android/ios devices measurements.  With equivalent (17 dbm) transit power on the 5 & 6 ghz bands, the devices held 3ft, no obstructions or interference, from the AP's, the clients report (client-perspective) -46 dbm for the 5 ghz band, and -36 dbm for the 6 ghz band; right-away, -36 dbm is off.  The mobile devices in the same location report -45 dbm (5 ghz) and -45 dbm (6 ghz); that's what I'd expect.  Different locations/distances, the numbers change but the variance from what I'll call "accurate" is <> the same, the variance seems to be greater at more distant/obstructed locations (i.e. -53 dbm reported where -66 dbm is expected), but the area isn't large enough to test that thoroughly.
I have tried fresh driver installs.
I have not yet taken the devices to an established network to compare; I may have to find a comparable network to be my next move.
Any input or thoughts from the community and/or Intel would be very much appreciated.
M8kItWrk
and by "<> the same", I mean "more-or-less the same".
JeanetteC_Intel
Hello M8kItWrk,
To get a better understanding of the issue and be able to provide an effective recommendation, please provide the missing key information here:
  1. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
  2. When did it start to happen?
  3. Do you remember if this issue happened after a new OS update or Wireless driver update?
  4. Are you having issues on Wi-Fi or Bluetooth or both?
  5. Check if there are pending Windows Updates.
  6. Please share an SSU log file so I can check your system configuration and be able to provide an accurate fix?
I will wait for your reply.
JeanetteC.
M8kItWrk
    1. BE200 is stock from the manufacturer,
    2. AX210 is an upgrade (~4/5 months ago), it has caused me no other trouble than potentially this,
    1. As stated, this is a brand new network configuration.  I have not had these devices on a 6ghz network previously.  The devices have never functioned as expected on a 6 ghz band as this is my first use case.
    1. Nothing to do with that - I'm setting up a new network and doing a site-survey in order to properly configure the AP transmit power.  The iOS and Android devices function as expected.
    1. No bluetooth issues
    1. Also as stated, all OS, driver, and firmware updates have been completed.
    1. see attached.
Thank you for your input.
JeanetteC_Intel
Hello M8kItWrk,
Thanks for the thorough information and SSU logs.
I'll review your system setup and return with our analysis.
JeanetteC.
JeanetteC_Intel
Hello M8kItWrk,
This issue is still under investigation and requires the following additional information:
For Intel® Wi-Fi 7 BE200:
Based on your previous report that Intel cards show 6 GHz signal strength approximately 10 dBm higher than expected when compared to Android/iOS devices across all three APs, and your mention of testing a comparable network, please confirm:
  1. Are all three APs currently being tested part of your home network?
  2. Regarding the "comparable network" for comparison testing - is this a different network (non-personal/non-home) that you plan to test, or have you already attempted connecting to it?
For Intel® Wi-Fi 6E AX210:
As this involves an upgrade component, please refer to the following resource: [Regulatory Information Regarding Wireless Hardware Installation or Upgrade]
We recommend contacting your system manufacturer's support team for guidance on this component.
We look forward to your response.
JeanetteC.
M8kItWrk
Your questions are confusing to me given what I have provided.
1. All three APs are on the same network. All three APs are functioning exactly as expected in all regards, except that there is this unexplained signal strength variance on both of my Intel wireless cards exclusively. The consequence is bad roaming decisions; there are not any other connectivity problems.
2. I suggested that I might need to find a comparable network to test, but I do not have one now so I cannot provide you any information about it.
Not requested, but perhaps of use: all three AP's are Unifi U7Pro-XG devices running the latest firmware.
JeanetteC_Intel
Hello M8kItWrk,
Thank you for the additional details and clarification.
Please perform a clean installation of the latest OEM drivers (version 23.60.1.2):
  • Select OS version: 24H2
  • Navigate to Driver-Network section
  • Install Intel WLAN Driver version 23.60.1.2 Rev.A
Also, please review our Recommended Settings for 802.11ax Connectivity guide.
Once you've tested with a comparable network setup, please share your results so we can better isolate this issue.
Looking forward to your update.
JeanetteC.
JedG_Intel
Hi M8kItWrk,
I'm just checking to see if you were able to review the recommendations that @JeanetteC_Intel shared. Please let us know if the issue persists so we can proceed accordingly.
Jed G.
JeanetteC_Intel
Hi M8kItWrk,
I wanted to follow up on your case. Please try a clean installation of our latest driver version 23.170.0.1 and let me know if the issue continues.
JeanetteC.
M8kItWrk
Sorry for the delay.  Thank you for your continued support.
After performing the clean install, on both devices, and installing the driver suggested I have no change in my experience.  The 6ghz signal is still reporting incorrectly in the same way previously described.
I still do not have a comparable network to test, so any other advice would be appreciated.
JeanetteC_Intel
Hello M8kItWrk,
Thank you for the update and for performing the clean install on both devices with the suggested driver.
I understand that the 6GHz signal is still reporting incorrectly despite these troubleshooting steps. Since the issue persists, I'll escalate this internally with our team for further investigation.
I'll get back to you once I have additional guidance or potential solutions to try.
Best regards
JeanetteC.
JeanetteC_Intel
Hello M8kItWrk,
I'm still working on the issue you reported.
Could you please provide the following information:
  1. What router or access point are you currently using?
  2. What software/application are you using to measure the frequency or signal strength of your system?
This information will help me better understand your setup and provide more targeted assistance.
JeanetteC.
JeanetteC_Intel
Hello M8kItWrk,
Please review the following analysis:
For AX210 SSU log - I notice AP is 2.4GHz - Tx Power is set to Highest.
For BE200 SSU log - I notice AP is 5GHz - Tx Power is set to Highest.
The 10 dBm stronger reception potentially indicates - AP is set to Higher Tx Power in 6GHz than is recommended.
Please verify that your AP's 6GHz transmission power complies with the regulatory limits in your region.
An improved RSSI is actually better as far as the connection speed indicates. One should expect that from a 6GHz band - as it has better (lesser interference) than 5GHz and 2.4GHz.
I hope this analysis is helpful.
JeanetteC.
JeanetteC_Intel
Hello M8kItWrk,
Did you get a chance to review the previous post?
Please let us know if you have any questions.
JeanetteC.
M8kItWrk
Sorry for my delay on this.
The network is using Ubiquiti U7 Pro-XG AP's (poe, 10G wired uplinks). I have used several pieces of software, but for example Wifiman.
JeanetteC_Intel
Hello M8kItWrk,
Thank you for acknowledging the network infrastructure details.
Based on my previous analysis of your SSU logs, I identified some key findings regarding your Ubiquiti U7 Pro-XG access points that require your attention:
Key Observations:
  • AX210 connecting to 2.4GHz with maximum transmission power
  • BE200 connecting to 5GHz with maximum transmission power
  • 10 dBm stronger signal reception suggesting potentially excessive 6GHz transmission power
Please verify that your access points' 6GHz transmission power settings comply with regulatory limits in your region. The significantly stronger RSSI readings may indicate the AP is configured beyond recommended power levels. I recommend contacting Ubiquiti support for proper verification of these settings.
Could you please check your Ubiquiti controller settings and confirm, whether auto power adjustment is enabled?
While improved RSSI typically enhances connection speeds (especially on 6GHz with reduced interference), excessive transmission power can cause regulatory compliance issues and potentially impact network stability.
Please share these configuration details so we can proceed with the appropriate recommendations.
Bests regards,
JeanetteC.
M8kItWrk
I clearly should have reviewed the SSU file before providing it and tried to figure out why 2.4 ghz was reporting first, but alas I did not.
The SSID is only broadcasting 5ghz and 6ghz.  The report of a 2.4ghz connection is simply incorrect, I wish I could explain.  There is a 2nd SSID for IoT devices that the AP is broadcasting on 2.4ghz, but not the network in use by the devices in question.  I have uploaded a new SSU file that's properly demonstrating the connection this time.
To answer your inquiry:  The AP transmit power is configurable and configured to be well below maximum transmit power; I am currently transmitting the 5ghz and 6ghz bands at a fixed 16 dBm.  These settings are also well within the regional allowances.
That said, I am confident you are conflating the "running or full power" value in the SSU to mean that the AP is broadcasting at full power, but that value is referring to the clients wifi adapter's power settings where full power is desirable.
With any obstructions and the same Tx, the 6ghz band should always be reporting lower Rx by the clients - for these two devices ONLY, it is not.  If I were experiencing this problem on all devices in the network your suggestion of an excessive 6ghz Tx power by the AP would be quite likely, but that is not the situation here.
ArchieD_Intel
Hello M8kItWrk,
Thank you for your update. I've sent an email to your active email address for the next step of the process.
Please check both your Inbox and Spam folder for my email, and once received, kindly acknowledge it.
Bests regard,
Archie D.
