Wireless
8586 Discussions
Troubleshooting Wi-Fi Icon Disappearance and Code 43 Error on Intel Wi-Fi 6 AX201 Adapter
Mehina
I have a problem with the Wi-Fi icon. It keeps disappearing while I'm using my laptop.
After scanning the Intel Wi-Fi 6 ax201 160MHz, while the icon disappears, I get this error:
"Windows has stopped this device because it has reported problems. (Code 43)"
This error only appears while the icon disappears.
How do I deal with the problem?
1- Uninstall the device
2- Scan for hardware changes
This is a temporary solution. The icon appears and I use the internet for a while, then disappears again. I repeat the process throughout my use. This is very annoying.
My attempts:
1- Installed the latest version of the driver
2- Ensure the latest system updates are installed
Some informations:
1- OS Name: Microsoft Windows 11 Home Single Language
2-
What I want to do now is first confirm that the problem is software-related, not hardware-related.
Mike_Intel
Hello Mehina,
  1. What is the brand and model of your system?
  2. Was it working fine before?
  3. What was the last change made in the system before the issue started?
  4. What are the troubleshooting steps that you tried so far?
  5. For me to review the hardware and the installed drivers, please help generate the SSU logs of your system. Kindly refer to the link below for the steps:
Michael L.
Anshuman1
I have the same issue and here's the log file. Please help
Mike_Intel
Hello Mehina,
@Anshuman1
If you need assistance, please create a new thread for us to assist you on your own thread and gather the details of your systems.
Michael L.
3Fees
Your power tab is missing, most likely a power management issue. There are several way to repair this. Google search power tab missing from wifi adapter in device manager.
Odds are you have it enabled to allow windows to shut down the wifi to save power, remove the check in the box on the power tab and
the icon will stay visible and you'll stay connected. Might try reset the network adapter in windows and when its running uncheck the box to allow windows to shut off the wifi adapter to save power.
This has happened in other devices and other people. The repair is uncheck the box so the device is staying powered up.
Cheers
3Fees
Mike_Intel
Hello Mehina,
I am sending another follow up on the information that I requested.
@3Fees
Thank you for information that you shared.
Michael L.
